YJ Heater Upgrade Question - JeepForum.com
post #1 of 5 Old 01-16-2009, 12:46 AM Thread Starter
Snipeston
Looking at upgrading my blower motor in my 89 YJ. I have read all the write ups and several mention replacing the heater core while you are in there. What is the purpose and how much does it help? Do you use the Chevy Blazer on to match the blower motor?
Hey round eye...
Snipeston is offline
post #2 of 5 Old 01-16-2009, 03:06 AM
Solus
from what ive heard when you go in an order a wrangler blower motor it actually is the blazer motor. As far as the heater core goes. Its recommended that you replace it because chances are with an 89 its 23 years old. a new one should help the heat a little at least.
Solus is offline
post #3 of 5 Old 01-16-2009, 04:47 AM
rustywrangler
Got my eye on you.....
rustywrangler's Avatar
Part number PM102 at napa, advance auto, etc. As said above, most of the places have already replaced the part number in their system to reflect the bigger blower.
The heater core can help alot. First off, it is full of years of crud. Second, a new clean core will transfer heat more efficiently and faster than an old gumed up one.
Congenital Heart Disease is a reality for me, BOTH of my children have it. Please read up and become aware for future generations
Lydia Ann-Acquired 08/05/05 Open Heart surgery 08/10/05
Jacob Patrick-Acquired 01/17/08 Open Heart surgery 02/15/08
rustywrangler is offline
post #4 of 5 Old 01-16-2009, 06:07 AM
Brandon_YJ
1987 YJ Wrangler
As for the core, you just get a stock Jeep replacement core.
Originally Posted by Mean Max View Post
I think I'll keep the YJ. But can I talk you into taking the wife?
DISCLAIMER: I (usually) browse the web using
in a (text only)
. Which means I do not have image viewing support. So if you get confused by my seemingly inability to comment on your pictures, emoticons, etc; now you know why.
If you're still confused
to see how I view the forum.
Brandon_YJ is offline
post #5 of 5 Old 01-16-2009, 12:38 PM
timatoe
timatoe's Avatar
As mentioned the PM102 is the same for the Blazer and YJ now. I recommend people replace the core, because it's not very expensive and you're already in there. I didn't replace mine when I did the blower, then it went bad and started leaking a couple months later and had to pull all that out again.
timatoe is offline
heater motor upgrade (dont worry its not the usual question) speepdaedeesi YJ Wrangler Technical Forum 10 09-13-2009 08:48 AM
Heater upgrade (amazing) 92wrangler YJ Wrangler Technical Forum 22 08-20-2009 11:14 PM
Heater blower upgrade. Brandon_YJ YJ Wrangler Technical Forum 3 08-18-2008 02:13 PM
Heater upgrade? Millinski YJ Wrangler Technical Forum 3 11-26-2005 01:45 PM
Heater Control Upgrade...is it possible? SgtSki TJ Wrangler Technical Forum 10 09-11-2002 10:29 PM
