-   -   YJ HD Steering (http://www.jeepforum.com/forum/f12/yj-hd-steering-1517992/)
Idaho_Chad 05-02-2013 08:22 PM
YJ HD Steering
I need help trying to figure out how I'm going to upgrade my steering.
Background: My YJ started to get some pretty bad death wobble a few weeks ago. I examined the steering and I found the TREs have quite a bit of play. Instead of just replacing them with stock TREs, I'd rather upgrade the tie rod and drag link with something that has a little bit more beaf. (I'm hoping to upgrade to 35s or 37s in the future)
Rugged Ridge has an HD steering kit, but I've heard a lot of complaints about a "dead spot" in the steering. But it looks like it's easy to install and not too expensive.
http://www.quadratec.com/products/56...FQ9dQgod-jYApg
MORE also a kit, but it's more expensive and doesn't have a bracket for a steering stabilizer. (I just bought an OME steering stabilizer)
http://www.mountainoffroad.com/_e/Je...y_87_95_YJ.htm
Has anybody tried either of these kits? Are there any other options out there?
-1989 YJ, 4.2, OME 36Rs all 4 corners, metalcloaks, 33s.
Anticanman 05-03-2013 12:51 AM
I've got the RR HD kit installed and other than the dead spot that is also prominent in the stock steering its been great so far. I still dd my Yj and it works well at 90 mph
Morris4x4Center 05-03-2013 08:02 AM
Either Rugged Ridge or M.O.R.E, Give us a call and we can make sure you get the best price!:2thumbsup:
Idaho_Chad 05-03-2013 08:27 AM
Thanks Atnicanman. It appears the dead spot occurs when the drag link rolls up and down as it pulls on the tie rod. Since I have a relatively small lift and a drop pitman arm, the angle between my drag link and tie rod is very small. Therefore, I believe the dead spot should be small on my Jeep (hopefully).
Morris - I sent you a PM.
calvynandhobbs 05-03-2013 08:45 AM
I haven't run the JCR steering on a YJ, but I've run it on a XJ and a TJ and was very happy with it on both of them. I'm thinking this is what's going on my YJ in the future.
http://www.jcroffroad.com/mm5/mercha...tegory_Code=S6
Abner_Ravenwood 05-03-2013 08:58 AM
+1 This is what i am going with too. With a PSC steering box. :cheers2:
Chris
jeepster93 05-03-2013 10:08 AM
i have the JCR steering.
Had it for about 5 years now, and have put 30,000 miles in it.
I have replaced one tie rod end but I set the jeep on a rock and the tie rod, so my fault.
It is not great for steering, I have the "dead spot".
VERY strong, very.
StanF 05-03-2013 12:16 PM
Originally Posted by Anticanman (Post 15382498)
snip...I still dd my Yj and it works well at 90 mph
Am I the only one who wants to call BullS**t on this? :D
90mph? Maybe down a steep mountain, with a hurricane tailwind! :D
SunDevilJeeper 05-03-2013 12:41 PM
50 Attachment(s)
He does it while the engine is off! Figure that one out!
beemerkid 05-03-2013 01:06 PM
I have the Ruuged Ridge, I like it just fine. I did mine in conjunction with the steering box adjustment and I already had a new steering shaft and bearings. There isnt a dead spot that I can really notice, and even if there were Im not sure you could attribute it solely to the RR system. Rather I would think any slop would be in the rest of the system or in the rolling of the drag link inherent to that type of a system. Whatever you do go get an alingment or do it yourselt, I didnt at first and it was no bueno. Just my $.02
Louie4 05-03-2013 01:11 PM
I've gotten to 80. I've aslo been to 90 before I changed my speedo gear.
USMCBuckWild 05-03-2013 01:12 PM
I have the MORE setup and no complaints. No dead spot, no issues. I also have an add-on dual steering stabilizer, which keeps the 38s straight. Mine sees 75 mph daily and no issues.
Anticanman 05-03-2013 01:27 PM
I just hit it again the other day. Steering was calm as a Hindu cow.
dukeryder 05-03-2013 02:44 PM
I have the Rusty's HD Steering Conversion
Went with this kit because it uses CJ5/7 TREs, which I can buy ANYWHERE, the Rugged Ridge supposedly uses some proprietary stuff and it's made in China.
I've only had the Rusty's kit on there for a few months and just a couple trail rides, but it still tracks straight down the road, and I have no issues at highway speeds either. I'm not sure what everyone was *****ing about it for (do search on here, I think the TJ or XJ forum). The thing is way beefier than the stock stuff and has a nice black powder coat on it.
I do have 1 gripe and that is that when the Alignment tech Aligned my steering wheel, he has the pitman arm way out of wack so at full lock in left turns I have a huge turning radius but in a right turn all is well. The track bar may be too long for my lift of only 2 5/8" (I'm going to try to get things straightened out this weekend). I did not know at the TIME but you can CALL Rusty's and they will custom make you a drag link of the length you need for an extra $20.
TSEJEEPERS 05-03-2013 08:22 PM
Something else to consider.
The MORE kit from what I can see is crossover steering.
You will also have to buy their knuckle bracket to be able to use it and I am not sure if you will be able to use it if you are SUA.
http://www.mountainoffroad.com/_e/Je...e_87_95_YJ.htm
Not saying that is a bad thing just something to consider.
(fill out your profile so we know what we are dealing with please)
The time now is 12:57 AM.
