YJ has trouble starting - Page 2 - JeepForum.com
post #16 of 24 Old 07-09-2013, 10:33 AM
Siva283
SOunds like you may be chasing down a bad wire between the column and starter. The only thing shaking the stick could do is possibly jiggle a wire. Our Jeeps are made to be able to start in gear. THere is a reason for it but I wont go into it here.
Ask me how I know...
Siva283 is offline
post #17 of 24 Old 07-09-2013, 10:39 AM
Luuca
Typical /f12 Hooligan
Luuca's Avatar
My thoughts as well. If you are good at electrical, have a it. I'm not, so I have to sit and watch from this point. Sorry man
91 YJ "Alice" 4.0L, AX-15, NP 231 w/HnT Flange, Adams Driveshafts F/R, 2.5" OME 36Rs, 5/8" /f12 Booms, 32" Yoko ATs, 4.10 D30/35 Aussie Lockers F/R
YJOTM never
05 LJ Rubicon "Ghost"
Luck Favours The Prepared
Luuca is offline
post #18 of 24 Old 07-09-2013, 10:45 AM
keithd1
I don't know if this will help, but I have a 94 and there is a wire that goes from the throttle position sensor down to the motor. Mine got on the exhaust and fused the wires together. I fixed the wires and it stopped that problem.
keithd1 is offline
post #19 of 24 Old 07-09-2013, 11:59 AM
Siva283
Since nothing happens you can rulle out the pump wiring which is what grounds at the ebrake. It shares a ground with the fuel gauge so if thats working it should be good. Can you jump the starter relay with a screwdriver and get it to start. Lets start at the starter and work our way bacl logically. I know the big parts but if it gets detailed we will need idahoboy in here since Que is still on the injured list. Idahoboy can keep pace with Que though.
Siva283 is offline
post #20 of 24 Old 07-09-2013, 12:00 PM
Siva283
Crap I missed a post. Before jumping the starter you should consider replacing the pos and neg that fo from the battery to the starter relay. They can coorode inside the sheathing/insulation where you cant see and cause these issues.
Siva283 is offline
post #21 of 24 Old 07-09-2013, 12:01 PM
Siva283
That wouldnt keep the starter from spinning. It is on its own circut
Siva283 is offline
post #22 of 24 Old 07-10-2013, 08:43 AM Thread Starter
ylojelo
one thing that was unrelated, but keeps crossing my mind because things are often related: a month or so ago while driving in the rain, my intermittent wiper switch stopped working, then started working backwards (the faster the setting the slower the arms moved). I havent had the problem since.
'12 JKU Rubicon
'93 YJ stock
'01 XJ + 2" OME
ylojelo is offline
post #23 of 24 Old 07-11-2013, 10:20 AM Thread Starter
ylojelo
is the steering column easy to take apart or are there some tricks to it?
'12 JKU Rubicon
'93 YJ stock
'01 XJ + 2" OME
ylojelo is offline
post #24 of 24 Old 07-16-2013, 11:35 AM Thread Starter
ylojelo
well, it hasn't had any trouble starting since then, so Im just going to wait to see if it happens again
'12 JKU Rubicon
'93 YJ stock
'01 XJ + 2" OME
ylojelo is offline
