YJ has trouble starting - JeepForum.com
post #1 of 24 Old 06-25-2013, 02:19 PM Thread Starter
ylojelo
'93 YJ, 4.0 manual trans,
turn the key and nothing happens, no click, but battery etc is fine. I have been able to start it after moving the stick in and out of gears and turning the key. After a few times, it eventually starts normally. My guess is a neutral position sensor, if a manual has one.
Thanks
'12 JKU Rubicon
'93 YJ stock
'01 XJ + 2" OME
ylojelo is offline
post #2 of 24 Old 06-25-2013, 02:59 PM
dtn8tr
When you say nothing happens, no click...do you get any dash lights that come on? There isn't a Neutral Safety Switch in the manuals.
1997 TJ, 5" IRO front with 4.5" HD IRO WJ rear, 35x12.5x15 Mickey Thompson MTZ, JKS disconnects
dtn8tr is offline
post #3 of 24 Old 06-25-2013, 03:49 PM Thread Starter
ylojelo
dash is normal, all gauges come on. turn the key to start and nothing changes.
'12 JKU Rubicon
'93 YJ stock
'01 XJ + 2" OME
ylojelo is offline
post #4 of 24 Old 06-25-2013, 03:52 PM
ROTTEN
Starter perhaps? You try banging on it?
I'm new
ROTTEN is offline
post #5 of 24 Old 06-25-2013, 04:16 PM Thread Starter
ylojelo
but the starter isn't struggling. maybe the ignition switch?
'12 JKU Rubicon
'93 YJ stock
'01 XJ + 2" OME
ylojelo is offline
post #6 of 24 Old 06-25-2013, 04:35 PM
idaholtby
Does your check engine light come on when the ignition is first turned on? If not, does it after waiting a few minutes? There is no NSS switch on a manual.
idaholtby is offline
post #7 of 24 Old 06-27-2013, 11:16 AM Thread Starter
ylojelo
duh, it is the battery had to jump it lastnight.
'12 JKU Rubicon
'93 YJ stock
'01 XJ + 2" OME
ylojelo is offline
post #8 of 24 Old 06-27-2013, 12:34 PM
idaholtby
Love the simple fixes. Hopefully there is no underlying issue related to battery charging. Thanks for reporting back.
post #9 of 24 Old 06-28-2013, 02:01 PM Thread Starter
ylojelo
interesting it would just do nothing, no clicking, or slow churning of the starter. It is a redtop optima. It may be five years old, I'd have to check my notes. now to find a good battery
'12 JKU Rubicon
'93 YJ stock
'01 XJ + 2" OME
ylojelo is offline
post #10 of 24 Old 07-02-2013, 01:07 PM Thread Starter
ylojelo
well crap, I just dropped in a new battery and the same: nothin'. Oh well, just traded in a 7 year old optima red top. now what?
'12 JKU Rubicon
'93 YJ stock
'01 XJ + 2" OME
ylojelo is offline
post #11 of 24 Old 07-06-2013, 03:30 PM Thread Starter
ylojelo
could it be the ignition switch?
'12 JKU Rubicon
'93 YJ stock
'01 XJ + 2" OME
ylojelo is offline
post #12 of 24 Old 07-08-2013, 02:44 PM Thread Starter
ylojelo
bump
'12 JKU Rubicon
'93 YJ stock
'01 XJ + 2" OME
ylojelo is offline
post #13 of 24 Old 07-08-2013, 05:26 PM
Luuca
Typical /f12 Hooligan
Luuca's Avatar
OK.. long shot here, but on my 91 2.5l 5spd, there is a ground wire just left of the e-brake release lever. Our Jeep would turn, but not fire after that wire kept getting moved by clutch working while driving. Eventually the wire was barely hanging on. Once I replaced it, started every time. Your issue sounds more sinister because you have dash, but nothing else. Research the ignition switch on here. That's where I'd start.
91 YJ "Alice" 4.0L, AX-15, NP 231 Flange, Adams Driveshafts F/R, 2.5" OME 36Rs, 5/8" /f12 Booms, 32" Yoko ATs, 4.10 D30/35 AutoLockers F/R
YJOTM Sept. 2017
05 LJ Rubicon "Ghost"
Luck Favours The Prepared
Luuca is offline
post #14 of 24 Old 07-08-2013, 06:03 PM
Mobile_Homie
Desert Rat
Mobile_Homie's Avatar
Check the battery cables for corrosion, at the battery and at the starter. May need new cables...
Mark
Smoke em if you got em!
Mobile_Homie is offline
post #15 of 24 Old 07-09-2013, 10:49 AM Thread Starter
ylojelo
so last night I did just that, checked the cable from the + battery to the starter. It all looked fine. I disconnected and cleaned the starter end. Tried to start it but same thing, nothing. then after an hour messing with the lawn mower, I tried, nothing again, then I shook the stick in neutral back and forth, turned the key and it started right up
'12 JKU Rubicon
'93 YJ stock
'01 XJ + 2" OME
ylojelo is offline
