-   -   YJ has trouble starting (http://www.jeepforum.com/forum/f12/yj-has-trouble-starting-1541235/)
ylojelo 06-25-2013 01:19 PM
'93 YJ, 4.0 manual trans,
turn the key and nothing happens, no click, but battery etc is fine. I have been able to start it after moving the stick in and out of gears and turning the key. After a few times, it eventually starts normally. My guess is a neutral position sensor, if a manual has one.
Thanks
dtn8tr 06-25-2013 01:59 PM
When you say nothing happens, no click...do you get any dash lights that come on? There isn't a Neutral Safety Switch in the manuals.
ylojelo 06-25-2013 02:49 PM
dash is normal, all gauges come on. turn the key to start and nothing changes.
ROTTEN 06-25-2013 02:52 PM
Starter perhaps? You try banging on it?
ylojelo 06-25-2013 03:16 PM
but the starter isn't struggling. maybe the ignition switch?
idaholtby 06-25-2013 03:35 PM
Does your check engine light come on when the ignition is first turned on? If not, does it after waiting a few minutes? There is no NSS switch on a manual.
ylojelo 06-27-2013 10:16 AM
duh, it is the battery:rolleyes: had to jump it lastnight.
idaholtby 06-27-2013 11:34 AM
Love the simple fixes. Hopefully there is no underlying issue related to battery charging. Thanks for reporting back.:thumbsup:
ylojelo 06-28-2013 01:01 PM
interesting it would just do nothing, no clicking, or slow churning of the starter. It is a redtop optima. It may be five years old, I'd have to check my notes. now to find a good battery
ylojelo 07-02-2013 12:07 PM
well crap, I just dropped in a new battery and the same: nothin'. Oh well, just traded in a 7 year old optima red top. now what?
ylojelo 07-06-2013 02:30 PM
could it be the ignition switch?
ylojelo 07-08-2013 01:44 PM
bump
Luuca 07-08-2013 04:26 PM
OK.. long shot here, but on my 91 2.5l 5spd, there is a ground wire just left of the e-brake release lever. Our Jeep would turn, but not fire after that wire kept getting moved by clutch working while driving. Eventually the wire was barely hanging on. Once I replaced it, started every time. Your issue sounds more sinister because you have dash, but nothing else. Research the ignition switch on here. That's where I'd start.
Mobile_Homie 07-08-2013 05:03 PM
Check the battery cables for corrosion, at the battery and at the starter. May need new cables...
ylojelo 07-09-2013 09:49 AM
so last night I did just that, checked the cable from the + battery to the starter. It all looked fine. I disconnected and cleaned the starter end. Tried to start it but same thing, nothing. then after an hour messing with the lawn mower, I tried, nothing again, then I shook the stick in neutral back and forth, turned the key and it started right up:confused:
The time now is 06:43 PM.
