Yj has no power wont boost - JeepForum.com
post #1 of 18 Old 11-18-2012, 11:47 AM Thread Starter
Ciamonkey
Hey guys I was driving my jeep and let it sit for about an hour while at a meeting and came back and the jeep has no power to it and won't boost off anything. Ideas?
Ciamonkey is offline
post #2 of 18 Old 11-18-2012, 11:51 AM
Mark05059
remove the battery cables and clean them first. Then do you have lights horn etc? If you do try starting it.
1998 ZJ 5.2 Auto
1989 Wrangler Black Bone Stock 2.5l 5spd
/l , [____],
|---L--[]lllllll[]-
()_) ()_)==O=)_)
Mark05059 is offline
post #3 of 18 Old 11-18-2012, 12:00 PM Thread Starter
Ciamonkey
No horn lights or anything
post #4 of 18 Old 11-18-2012, 12:28 PM
ForestJeep89
If your connections are good then you may have a dead battery.Your charging system may be faulty thus leaving you open to parasitic draw complications. You may have been losing battery for some time and just now headed over the cliff.Test your alternator-you might be able to get a jump to get home.
ForestJeep89 is offline
post #5 of 18 Old 11-18-2012, 12:31 PM Thread Starter
Ciamonkey
Like I said it won't jump
post #6 of 18 Old 11-18-2012, 12:36 PM
Mark05059
like I said clean your terminals.. both ends
1998 ZJ 5.2 Auto
/l , [____],
|---L--[]lllllll[]-
()_) ()_)==O=)_)
post #7 of 18 Old 11-18-2012, 12:42 PM Thread Starter
Ciamonkey
Then ill get back.
post #8 of 18 Old 11-18-2012, 12:43 PM Thread Starter
Ciamonkey
* ill try that then I will get back.
post #9 of 18 Old 11-18-2012, 02:00 PM
Opihi59
from here it gets rough
Opihi59's Avatar
Your Jeep's white?
....I'm not smart, but I can lift heavy things.......
Fill out your PROFILE, and don't forget to look in the FAQ for writeups
I'm stuck on da Rock
Originally Posted by Brian4.2 View Post
We will be going Metric every inch of the way.
Originally Posted by 40dog View Post
yes I'm a some guy and have always put gasket sealer on my surfaces before mating
Originally Posted by Virjeep View Post
You should go to Pirate. I hear they are real smart over there. You'd fit right in.
Opihi59 is offline
post #10 of 18 Old 11-18-2012, 02:10 PM Thread Starter
Ciamonkey
No lol why
post #11 of 18 Old 11-18-2012, 02:11 PM Thread Starter
Ciamonkey
Oh hahahaha never mind
post #12 of 18 Old 11-18-2012, 02:13 PM
Opihi59
Opihi59's Avatar
Can't jump. ...Woody Harrelson, Wesley Snipes.....
Honestly, I can't imagine why a vehicle would run fine, then suddenly won't do anything after being shut off for an hour. Doesn't make sense. Pull the cover off the PDC in front of the battery, check all the big monster fuses in there. Can you test for voltage across your battery, see if it has ANY juice to it? Hope you're not freezing out there in the parking lot. Seems pretty nippy where I am even, brrrrrr.
Opihi59 is offline
post #13 of 18 Old 11-18-2012, 02:22 PM Thread Starter
Ciamonkey
Hah it might have just been a loose positive connection -.- I'm an idiot sometimes.. I live in Canada so she is pretty cold out lol.
post #14 of 18 Old 11-18-2012, 02:29 PM
Opihi59
Opihi59's Avatar
So you got it started? You're back in action? I'd give the Jeep an under the hood electrical clean-up if that's the case. Can't tell what else was a bad connection as well that is waiting to leave you stranded in the Great White North where frostbite rules. Things like the lines to your alternator, engine/battery ground points, terminal connectors, sometimes you even have to replace your main power/ground lines even though they look good on the outside. Clean all connectors to bright and shiney with sandpaper, put a dab of dielectric grease on them and tighten them back up. Don't forget terminals on the starter as well. First thing to do before going into all of this is to disconnect the battery........
And it was cold here as well last nite, musta got down into the upper 60's/low 70's. Brrrrrr. I had snotsicles hanging so had to even close a window. Couldn't find my sock cap though.
Opihi59 is offline
post #15 of 18 Old 11-18-2012, 02:49 PM
ROTTEN
Take it out and make sure it does burnouts
I'm new
ROTTEN is offline
