YJ Hardtop Window Rubber - JeepForum.com
post #1 of 4 Old 05-09-2002, 08:59 AM Thread Starter
BORR
Does anybody know how to keep the window rubbers on the side glass of the hardtop from falling out?
BORR is offline
post #2 of 4 Old 05-09-2002, 10:36 AM
evilpsych
evilpsych's Avatar
umm.. well if they're already falling out, here's what i'd do, go ahead and pull them all the way out, clean the groove with alcohol or some other solvent to get the road grime and grit out, (make sure the glass doesnt fall out) then put a small bit of silicone sealant on the rubber trim piece and refit it back into the groove. When it cures, the window will also be re-sealed from water and wind noise from air leaks should go down as well.
A
So he wants to go OFF-ROAD does he????
'93 YJ, 4.0, K&N filter, Borla Header, Borla Cat-Back, Hi-Flo Cat, 3 Core Radiator, D-Rings, TruckNuts, MSD 6A, LockRite Locker in D30, Magnecors, Kickass Stereo, 1" daystar, 31" BFG AT's, Homemade Rocker Guards and Front/Rear air-tank bumpers with tire carrier, 15x8 AR-767 4"BS, BDS 3.5 HD lift, AMA A/C Kit, York OBA, GoFerIt 1" MML, 8,000lb HF/MM Winch, Magellan MAP 330 GPS, PRO-2067 500ch. Scanner, oh, and a CB capable of talking to SATURN!
"The Only Thing Necessary for Evil to Succeed is for Good Men to Do Nothing." - Edmund Burke
evilpsych is offline
post #3 of 4 Old 05-09-2002, 10:45 AM
93 Blue Demon YJ
I had the same problem. I went to a glass shop and got about 15 feet of that rubber weatherstripping, pulled out the old stuff, and got some silicone sealant and filled the gap b/w the window and top, and inserted the new seal. Good as new now!
Richard
'93 YJ 4.0 3" RC lift 15x10 wheels and 32" tires.
93 Blue Demon YJ is offline
post #4 of 4 Old 05-09-2002, 10:50 AM
JeeperJay
There's supposed to be seals in there???
When I bought my YJ there were no seals in the hardtop windows. I'm actually suprised that they haven't fallen out or leaked. I'm sure its just a matter of time though
1992 YJ, 2.5L 4-banger, 2" Lift, 31x10.5 BFG Mud Terrain, K&N Filter, Restrictor Removed, Hi-Lift, Custom bumpers, More to come...
JeeperJay is offline
Hardtop missing rubber bumpers? runtaroo2 JK Wrangler Technical Forum 0 06-10-2009 05:31 PM
CJ7 hardtop side window on YJ hardtop? Whistler YJ Wrangler Technical Forum 1 09-20-2007 09:21 AM
Hardtop Rubber/Steel ... Bumper? Gailon TJ Wrangler Technical Forum 9 07-19-2007 07:27 PM
Rubber liner around window problem. jameskjeep TJ Wrangler Technical Forum 3 07-05-2006 07:57 AM
Hardtop rubber seal Sidewalkman YJ Wrangler Technical Forum 2 09-09-2003 04:40 PM
