YJ Hardtop and Soft Upper Doors? - JeepForum.com
post #1 of 3 Old 03-30-2004, 11:14 PM Thread Starter
herb101
I've got an '87 YJ that I bought with no top (and not much else). I've got a hardtop from an '88 YJ that I've put on it and I've got the factory half-doors. I live in Texas and have no AC - so I LOVE the half doors!
I absolutely hate upper door sliders and don't care much for full hard doors. I'd like to run the soft door uppers but I'm having trouble coming up with a solution to do that. I have a set of Bestot soft uppers, but the dimensions are 'off'. The shape is OK at the top corner, but the upper is about 1-1/2" too long. The rounded 'kickout' above the stricker is much less pronounced on the Bestop uppers than a factory hard door, but I'm less concerned about that. The rear upper corner fit good, but the windsheild angle seems to be off too (yes, I am sure they are for a YJ - not a TJ- they have a snap at the front flap). I'm looking for a solution that will be fairly weather-tight and affordable. The fiberglass slider uppers I've found are like 10% of the total build-up cost of my Jeep - no dice! (not to mention - I don't want those...)
Any ideas or has anyone else driven down this trail already?
Thanks,
Herb
(Wet in SA)
herb101 is offline
post #2 of 3 Old 03-31-2004, 08:19 AM
dsearcy
with soft uppers there is a plastic piece that is bolted to the windshield frame. the soft top, when up, is attached to it. The plastic piece allows for there to be a nice seal. so you will probably need to make something for the door to make a seal with.
dsearcy is offline
post #3 of 3 Old 03-31-2004, 08:35 AM
Bigbluejeep
Junior Member
If you can weld and feel like doing very little work. I found that TJ upper softdoors will fit perfectly on YJ half hard doors. THe only thing that is off is the Rods that stick in the door. They stick out a little too far. I was going to do this but then decided that maybe I just won't run doors anymore at all.
89 Yj 6cyl
Weber
4" Lift
Welded Tow Hooks Front & Rear
Soft Top (hard top got lost in a rollover)
KC Daylighters
55 watt running lights mounted in Frame for Night Rockin
33/12.50/15 Buckshot Mudders
Rear Lock-rite (best mod ever!)
Detroit Front Locker
Flowmaster
2" BL
Bigbluejeep is offline
YJ hardtop and TJ soft upper doors? squibload YJ Wrangler Technical Forum 3 10-28-2010 01:13 AM
will upper soft doors fit hardtop??? 98formulaLS1 YJ Wrangler Technical Forum 3 10-05-2006 01:46 PM
Soft Upper doors for hardtop?? backinblackz28 YJ Wrangler Technical Forum 1 10-22-2004 09:13 AM
soft upper doors for a hardtop? hufty YJ Wrangler Technical Forum 3 10-19-2004 03:40 PM
Soft upper doors on hardtop... jbrx7 YJ Wrangler Technical Forum 13 07-23-2004 11:37 AM
