YJ Hardtop quick release hardware suggestions? - Page 2 - JeepForum.com
post #16 of 27 Old 10-05-2011, 04:11 PM
ejeeperguy
1982 CJ7
The welding clamps are a bit much some small c-clamps would be easier to put in and not stick out as much.
I have kwit kit that I was going to use for my cj.The top went away so I am going to use it on the wife's yj.
ejeeperguy is offline
post #17 of 27 Old 10-06-2011, 09:46 AM
TWZTD
I don't see a problem with reviving old threads with current ideas, after all that is what keeps forums going right?
TWZTD is offline
post #18 of 27 Old 10-06-2011, 02:26 PM
jmmorgan82
2009 JK Wrangler
I just used hex bolts, washers, and wing nuts. The wing nuts are the perfect size under the rails so that they catch and do not spin when tightening the bolt. I believe I went with 3/8x1.5.
jmmorgan82 is offline
post #19 of 27 Old 10-06-2011, 03:16 PM
superj
good idea
I don't feel like working on anything at this time so i sold my yj.
superj is offline
post #20 of 27 Old 10-07-2011, 05:53 AM
mfalik
mfalik's Avatar
Originally Posted by Mean Max View Post
This Kwik kit part number is specifically for your YJ.
http://www.quadratec.com/products/13022_00.htm
The quadratec kit costs $57.
You should be able to make your own for less than that. The latches are $9 each from McMaster Carr (www.mcmaster.com), PN 1864A23. The rest of the hardware (pip rivots, nuts and bolts) should be less than $20.
MichiganTech Mechanical Engineer Alumni
1994 Wrangler Sahara - Jeep Project
2003 Dodge Ram 1500 (new truck)
2007 Mazda CX-7 (the new commuter car)
2005 Mitsubishi Lancer (Rear Ended - TOTALED)
1998 VW Beetle (SOLD)
1988 Jeep Cherokee Limited - (SOLD)
mfalik is offline
post #21 of 27 Old 10-07-2011, 10:35 AM
purdueme06
Originally Posted by bunkrdfool View Post
http://cgi.ebay.com/ebaymotors/Unive...Q5fAccessories
ive been pondering getting some for my hardtop ... they look easy enough
I got these shortly after I bought my Jeep. If anyone ends up getting them, just dab a little anti-seize on the threads before you tighten them down. Mine oxidized just enough that it made each of them a bear to get off.
Lesson learned...other than that they are great. Mine came with washers that were coated with rubber on one side to go against the lip of the hardtop.
purdueme06 is offline
post #22 of 27 Old 10-07-2011, 01:39 PM
Matt The Hammer
Thanks. You can get the Lange instructions here to install these:
http://www.langeoriginals.com/langeZ...products_id=56
I just installed the windshield clamps (from McM) and use regular old bolts, washers and factory rectangle nuts from the softop in the rear.
2013 JKU
1995 YJ
Matt The Hammer is offline
post #23 of 27 Old 11-29-2011, 08:40 AM
Matt The Hammer
Found that Fastenal carries these latches, in stainless steel, for $6 each.
http://www.fastenal.com/web/products...0719421&ucst=t
Little cheaper than the McM ones. Plus stainless rather than nickle plated. For us NE guys who store their hard tops outside...
2013 JKU
1995 YJ
post #24 of 27 Old 11-29-2011, 08:50 AM
ThomasYJ
As stated before, I use the wing nut hex bolt method. would have went with EYE bolts but couldnt find the right ones.
The Toy:93 YJ
The DD:00 F250 7.3
Build:
ThomasYJ is offline
post #25 of 27 Old 03-21-2012, 09:36 AM
spyder98
old thread I know. But would TJ latches work on the YJ hard top?
spyder98 is offline
post #26 of 27 Old 09-03-2013, 04:16 PM
94jeepman
2005 WK
has any body seen just the clamps for the windshield part i already have the quick bolts
94jeepman is offline
post #27 of 27 Old 09-03-2013, 05:41 PM
Kdeome
Would these quick latches effect in anyway a summer soft top mounting?
Kdeome is offline
sman26
Quick Release clamps soupy1957 JK Wrangler Technical Forum 3 04-22-2009 03:03 PM
Quick Release Hardware for Powertank Bracket? rastadog TJ Wrangler Technical Forum 1 03-24-2009 07:53 AM
Hardtop Quick Release recommendations? jr1966 TJ Wrangler Technical Forum 5 01-24-2009 09:15 PM
Quick release knobs for top rayzordee JK Wrangler Technical Forum 1 10-25-2007 07:11 PM
Hardtop Quick Release Kit Anyone?? saint152 YJ Wrangler Technical Forum 0 10-02-2003 08:45 PM
