YJ Hardtop quick release hardware suggestions? - JeepForum.com
post #1 of 27 Old 11-06-2008, 02:04 PM Thread Starter
kayslaw
I am looking for ideas to secure my hardtop on my YJ with hardware that doesn't require torx bits and a wrench. Something that will not require tools everytime I take it off and put it on. Checked out Q-tech and it looks like Lange Originals Kwik Kit Hardtop Hardware might do the trick, but not sure if they will work on a YJ.
any ideas?
kayslaw is offline
post #2 of 27 Old 11-06-2008, 02:10 PM
Toms87
1987 YJ Wrangler
sometime in the next few weeks i'm going to put my hard top back on and see if it's possible to convert all the hardware to wingnuts or something similar
Toms87 is offline
post #3 of 27 Old 11-06-2008, 02:18 PM
chadroc
I have the kwik kit on mine and it works pretty nice. At the most, you might need a coin if you want to tighten it up a little more than you can with your fingers. The front clips work especially nice to draw the front down tight. It reduces wind noise. I think its worth the price.
chadroc is offline
post #4 of 27 Old 11-06-2008, 02:35 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
any ideas?
This Kwik kit part number is specifically for your YJ.
http://www.quadratec.com/products/13022_00.htm
Originally Posted by UltimatE View Post
Max has a picture of every Jeep part ever made.
Originally Posted by Benderff View Post
No one here knows what they are talking about. You should try Pirate 4x4 they will be happy to help you.
There is no situation that cannot be improved with a small but well-placed explosive.
Mean Max is offline
post #5 of 27 Old 11-06-2008, 02:40 PM
Alfons
This subject runs it's cycle every year or so & the last time I was reading about hard top latches I believe most settled on the type of fastener used on tool boxes - put 4 or 5 across the top and that seems to work. You can get that type of fastener with an adjustment mechanism on it & this removes some of the tolerance problem of installing these latches.
Alfons is offline
post #6 of 27 Old 11-06-2008, 02:45 PM
timatoe
timatoe's Avatar
My buddy also runs the Kwit Kit and it works well, I've been saying for at least two summers now that I'm gonna put it on before I put the top back on. Maybe next summer.
timatoe is offline
post #7 of 27 Old 11-06-2008, 03:03 PM Thread Starter
kayslaw
Thanks for the input!
kayslaw is offline
post #8 of 27 Old 11-06-2008, 03:03 PM
AthruC
What about a peg w/ a hole for a cotter pin?
If you wanted to get fancy, you could have a peg machined that would have a thread at the top to fasten to the body and the top would just slide right onto it...? Put in the pin and voila!
AthruC is offline
post #9 of 27 Old 11-06-2008, 03:43 PM
sprowley
I use wingnuts on hex bolts - bolts up through the bottom and wingnuts on the top - very very quick and easy.
If you really wanted ease of use, you could weld the bolts into the tub, so you'd just have the wingnuts to deal with.
92 YJ Islander Sold!
97 TJ Sport black on black with MT/R Kevlars and lots of new parts coming!
Canon EOS-1D Mark III, Canon EF 70-200mm f/2.8L USM, Canon EF 17-35/2.8L USM, Sigma 50mm f/2.8 EX USM
sprowley is offline
post #10 of 27 Old 11-06-2008, 03:52 PM
Alfons
Even if it fit, it wouldn't pull the top tight against the windshield, causing a lot of clatter and whistling.
Alfons is offline
post #11 of 27 Old 11-06-2008, 04:03 PM
AthruC
You've got the spring-loaded clips for that though...
(the ones at the top in the center...)
Speaking of which, one of mine broke - can you get those clips individually?
AthruC is offline
post #12 of 27 Old 11-06-2008, 07:30 PM
jay-h
You can get wingnuts and wing bolts from home depot. Works great
jay-h is offline
post #13 of 27 Old 11-06-2008, 07:33 PM
bunkrdfool
http://cgi.ebay.com/ebaymotors/Unive...Q5fAccessories
ive been pondering getting some for my hardtop ... they look easy enough
USAF Security Forces. Keeping your chair safe since 2009.
bunkrdfool is offline
post #14 of 27 Old 10-05-2011, 03:28 PM
TWZTD
Use " I " bolts with washers. This way you have an anchor point for bungy cords to strap your cooler on the back seat. And you can install and remove them by hand.
TWZTD is offline
post #15 of 27 Old 10-05-2011, 03:38 PM
scubamc
These work good for the back.
scubamc is offline
Quick Release clamps soupy1957 JK Wrangler Technical Forum 3 04-22-2009 03:03 PM
Quick Release Hardware for Powertank Bracket? rastadog TJ Wrangler Technical Forum 1 03-24-2009 07:53 AM
Hardtop Quick Release recommendations? jr1966 TJ Wrangler Technical Forum 5 01-24-2009 09:15 PM
Quick release knobs for top rayzordee JK Wrangler Technical Forum 1 10-25-2007 07:11 PM
Hardtop Quick Release Kit Anyone?? saint152 YJ Wrangler Technical Forum 0 10-02-2003 08:45 PM
