Yj half steel door vs full steel doors - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > Yj half steel door vs full steel doors
ROCKRIDGE4WD Introduces a NEW Jeep Wrangler JK *led* tail Nitro Gear Packages Now Available at Rockridge 4wdMarch Madness LOCKER SALE + FREE SHIPPING + $30-$50 REBATE
Unread 01-15-2015, 04:47 PM   #1
JROLIVER
My 1989 yj is a soft top with half steel doors. I bought a pair of full (1993) steel doors from a local salvage yard with anticipation of a hard top in the future. However, the full doors do not line up with the striker at its current location, aprox 3" higher than the latch on the doors. Do i have the wrong doors, or do i need additional parts to re-locate the striker on the body?
JROLIVER is offline   Reply With Quote Quick reply to this message
Unread 01-15-2015, 04:50 PM   #2
YJ4LIFE
I have both and there's a bit of adjusting going on in the hinges and the striker. If you put a little work into it you can make both work.
'89 YJ, 4.2L, ax-15, B&M shifter, 1" BL, TJ flares, '99 intake, '91 EFI, 5.0L explorer injectors, GenRight tank & stretch, 35" ProComp Xtreme muds, 52" chevy springs rear, 44044 Ranchos front.....
YJ4LIFE is offline   Reply With Quote Quick reply to this message
Unread 01-15-2015, 04:58 PM   #3
JROLIVER
32 years in collision repair. No amount of adjusting will move the striker that far. I guess my question really is what year models are interchangeable. My understanding was 1987-95 yj were the same, correct?
Unread 01-15-2015, 05:46 PM   #4
NW4wheeler
I thought all yj doors were interchangeable. Maybe a picture will help.
NW4wheeler is offline   Reply With Quote Quick reply to this message
Unread 01-15-2015, 05:47 PM   #5
NW4wheeler
I wonder if he got tj doors.
Unread 01-15-2015, 07:14 PM   #6
Biohazard294
Maybe you have some reason for wanting a hard top and full doors, if you wanted to lock your jeep to make it more secure maybe. For me though I have a soft top and half doors year round up in michigan, everyone seems to complain about the soft top Being too loud but it's worth it come summer time when I can take off the soft top and use the top of the half door as an armrest. I guess that what I'm really getting at is that you might just want to pick one setup to go with and then stay with it, at least that's what I do.
Biohazard294 is offline   Reply With Quote Quick reply to this message
Unread 01-15-2015, 09:40 PM   #7
cwein23
I have full steel doors, but Ive looked into buying half doors since I prefer the look of them over the full doors
Everything Ive looked into has said that all YJ doors are interchangeable, maybe loosen the hinge bolts on the doors, get them to close and then tighten them down?
Ive heard of doors shifting for whatever reason.. Never done it but its worth looking into..
Goodluck, and if you dont want to keep the half steel doors, shoot me a pm!
cwein23 is offline   Reply With Quote Quick reply to this message
Unread 01-15-2015, 10:34 PM   #8
Anticanman
The Thunder Chunky
Anticanman's Avatar
I had to make the (free) half doors work. It took a set of new hinges to get the adjustment just right. It takes time but they'll fit.
Luck Favours The Prepared
"Whiskey is for drinking, Water is for fighting over" - Mark Twain
Anticanman is offline   Reply With Quote Quick reply to this message
Unread 01-16-2015, 06:09 AM   #9
fishadventure
If they are 3" off..... something's not right. That doesn't make sense at all. And yes 87-95 should be the same enough to only need adjusting. 3" is not an adjustment IMHO. Unless you are exaggerating for theatrical effect.
How many old threads actually convince *you* to read all 36 pages? http://www.jeepforum.com/forum/f12/length-envy-build-thread-629700/
fishadventure is offline   Reply With Quote Quick reply to this message
Unread 01-16-2015, 06:17 AM   #10
Jeepfreak81
CJ7 doors should even fit without issue, I have CJ7 doors on my YJ.
Loosen the 6 bolts and lift the door up until it latches, I don't think it will move 3" worth though.
94 V8 YJ, SOA, H1's, 37's, HP D44, D60, 4.88's, winch and some other goodies
1946 CJ2A, 225 V6, T98 D18, Warn OD, D30/D44. Dual winches mild lift & 34's
1966 M416 1/4 ton Military Trailer Expo Trailer
Full Page Club member #004
Green Jeep Club Member #005
Jeepfreak81 is offline   Reply With Quote Quick reply to this message
Unread 01-16-2015, 08:43 AM   #11
Mike Romain
Location: Off the Grid in Chester Grant, Nova Scotia, Canada
You gotta have the wrong doors... As mentioned, late CJ doors even fit all the YJ line.
Mike
Some Canadian Bush Jeep Runs and Build Photos: http://mikeromainjeeptrips.shutterfly.com (10 new albums added Sept 16/10)
Mike Romain is offline   Reply With Quote Quick reply to this message
Unread 01-16-2015, 09:43 AM   #12
Matt The Hammer
TJs used a loop instead of the striker pins that the YJs and CJs had. So the pin wouldn't even fit into the slot on the TJ door.
Who knows what's going on...
YJ:
TJ:
There's a ton of info out there to switch them over to either one. So if the OP has this issue, search how to switch door striker pins.
2013 JKU
1995 YJ
Matt The Hammer is offline   Reply With Quote Quick reply to this message
Unread 01-16-2015, 07:58 PM   #13
jred
This is definitely one of those times that a picture would really help.
jred is offline   Reply With Quote Quick reply to this message
