yj gets some coilovers - Page 7 - JeepForum.com
 5Likes
post #91 of 230 Old 08-28-2012, 02:52 PM Thread Starter
ssyj94
Looks like a lot of fun. I always think your YJ is more like a sleeper with the body relatively stock.
Thanks yea thats how I see it too. On sunday you wouldnt believe how many people figured it was just a long armed tj and even asked me how I swapped the older dash in.
We will have to meet up at Rausch one day, looks like you are willing to run the fun trials. Any plans to go down to bog dogs in sept?
That'd be cool pm me next time your headed out to RC. I've been debating big dogs but I dont really want to have to worry about driving the 5hrs home. So unless I can find a last minute spot on a trailer I doubt I'll make it down.
My build:
ssyj94 is offline
post #92 of 230 Old 08-28-2012, 05:31 PM
1 ton yj
1 ton yj's Avatar
The Cove is the best spot in the northeast! Definitely go if you can find a ride! If I had something to wheel right now I'd have already signed up and began prepping.
1 ton yj is offline
post #93 of 230 Old 08-29-2012, 07:47 AM
YJames90
YJames90's Avatar
Ive been there
My 2.5 to 4.3 swap thread
YJames90 is offline
post #94 of 230 Old 08-29-2012, 08:50 AM
caddyman
Originally Posted by ssyj94 View Post
I got both my front driveshaft shortened and lengthed the rear shaft this weekend. My rear shaft is a 1350cv out of a 90's dodge 2500 I cut it down to about 25" running length.
I also threw the stock tank in the back of the jeep with a couple ratchet straps for now. Just have to extend the fuel pump wiring and it'll run again.
The brakes are almost done and I've got a couple ideas for the exhaust. I changed springs on my coilovers to 170/250 and it looks to work alot better.
I was curious what you ended up doing with your exhaust? I see you had a couple idea's but never posted anything?
Do you get exhaust smell in the Jeep?
91 Jeep YJ Linked, Stretched, C/O's, Atlas, 39" Krawlers, ton's 60/14 bolt, ARB'S, GenRight's poster child!
My Build:
caddyman is offline
post #95 of 230 Old 08-29-2012, 09:20 AM
Poke
runtime error = 0
Poke's Avatar
2015 YJ Wrangler
I'll let you know if one of the 30ft-ers happens to open up.
Poke is offline
post #96 of 230 Old 08-29-2012, 05:56 PM Thread Starter
ssyj94
I ended up throwing my old flowmaster muffler under the belly skid with a turndown just about where that peice of exhaust pipe ends in the picture. There really isnt much room for a tailpipe on mine everything just about hits at full bump. I did eyeball a way to get a tailpipe to just in front of the rear axle but didnt feel it was worth the effort with 5 bends in 2'. I've had the hardtop/doors on and havent hardly smelled exhuast inside the cab.
James I think you were there that day ha. I'm looking forward to the next outing over there. You drop that ledge yet?
My build:
ssyj94 is offline
post #97 of 230 Old 08-29-2012, 07:40 PM
1 ton yj
1 ton yj's Avatar
There is an exhaust smell, but it's because it has no cat, and I think it might be a little on the rich side for some reason. Not objectionable at all. Even with the top off.
It was like that with a full tailpipe out the back too, so the turndown didn't change much.
1 ton yj is offline
post #98 of 230 Old 08-30-2012, 03:27 AM
YJames90
YJames90's Avatar
Not yet but maybe this time. The club is going to be there on the 15th of September.
The gorge from the water tower up to the house is now doable and crazy!
YJames90 is offline
post #99 of 230 Old 09-07-2012, 03:59 PM Thread Starter
ssyj94
Is this an official invite?
My build:
ssyj94 is offline
post #100 of 230 Old 09-11-2012, 10:34 AM
YJames90
YJames90's Avatar
If it was up to me and my property I would say yes . Im not sure if Im going now.
YJames90 is offline
post #101 of 230 Old 09-22-2012, 07:41 PM Thread Starter
ssyj94
We've been working on setting up the coilovers better and realized I was way over sprung. The previous 200/300 front and 175/250 rear rates are just to high and with the triple rates I'm loosing usable sprung travel. After crunching some numbers and measurements I'm goin 175/200 front and 165/175 rear with some valving adjustments down the road.
At the moment I've picked up some used coils to go 200/200 and 175/175 and the ride is way better than before. The jeep is much smoother in the rough stuff and with the dual rates slid down isnt bad at all on the highway. Now I've got to order some shim kits and a set of 165's to finish off some of the tuning.
My build:
ssyj94 is offline
post #102 of 230 Old 09-23-2012, 08:54 PM
ldso
Very cool YJ man, unique axle combo!
1995 YJ "Mabel", 2.5L Muncie SM465 np231j 4.88's HP30 Lockright JK 44 Detroit 33s CJ clip
Actually, it's pronounced "mill-e-wah-que" which is Algonquin for "the good land."
ldso is offline
post #103 of 230 Old 10-27-2012, 11:34 AM Thread Starter
ssyj94
Thanks they seem to be holding up well to 35's
My build:
ssyj94 is offline
post #104 of 230 Old 11-13-2012, 10:29 AM
1 ton yj
1 ton yj's Avatar
Well we found the weak link this weekend. It's the tires. Cut one of the KM2's pretty bad. Rest of the truck worked flawlessly on all black and red trails. Axles are holding up very well. Front XJ driveshaft needs some attention before it can get wheeled again, but it held together all weekend despite some of the scary noises it was making.
Now it's not only on the same trails as the buggies but taking many of the same lines.
Here's a video from Shoot the Moon in the quarry at Raucsh Creek.
1 ton yj is offline
post #105 of 230 Old 11-13-2012, 11:20 AM
Poke
runtime error = 0
Poke's Avatar
2015 YJ Wrangler
cool. It's fun to follow the buggies around in a jeep. We will have to pick a date this winter and all meet up at RC.
Poke is offline
tj coilovers? 0IIIIII0 TJ Wrangler Technical Forum 36 06-10-2014 06:53 PM
yj coilovers jeepwyj94 YJ Wrangler Technical Forum 18 06-20-2010 06:13 PM
Coilovers JCM TJ Wrangler Technical Forum 4 10-19-2006 07:18 AM
Coilovers TJJPNUT TJ Wrangler Technical Forum 1 12-08-2004 09:48 AM
Coilovers? Who What When Where???? stjjames TJ Wrangler Technical Forum 15 12-06-2004 05:16 PM
