YJ GenRight EXT Tank Install - JeepForum.com
post #1 of 58 Old 07-21-2012, 08:32 AM Thread Starter
trailrider787
I typed searched for a detail build thread for a GenRight EXT Tank and didn't come up with anything. Decided I would try one and hopefully helps others out, will also show moving back axle 1", but with this tank, axle can be moved back up to 5".
trailrider787 is offline
post #2 of 58 Old 07-21-2012, 08:37 AM Thread Starter
trailrider787
remove the gas tank nozzle insert, by removing the three screws holding it on the body.
post #3 of 58 Old 07-21-2012, 08:39 AM
Louie4
"You pass butter"
Louie4's Avatar
You might as well do a flush LED tail light conversion while you're at it.
Lou
YJOTM July 2012
YJOTM February 2014
Louie4 is offline
post #4 of 58 Old 07-21-2012, 08:41 AM Thread Starter
trailrider787
remove the plastic mud flap below the rear quarter panel to get to the filler and vent hoses, then loosen the hose clamps and remove the hoses from both the tank and the filler neck.
remove the filler neck and it should look like this
post #5 of 58 Old 07-21-2012, 08:43 AM Thread Starter
trailrider787
cut exhaust pipe just before tank skid plate, to allow tank to drop down easily. If anyone has tried dropping the tank without cutting the exhaust, you know what a pain it is.
You will need to re-route the exhaust later due to the shape of the new GenRight EXT tank.
post #6 of 58 Old 07-21-2012, 08:49 AM Thread Starter
trailrider787
Place jack under center of gas tank and place some pressure on tank.
loosen four bolts at the rear of the gas tank and three bolts on the front of the gas tank. I used a 1/2" socket and 1/2" box end wrench.
remove all seven bolts and begin to lower tank very slowly.
remove the vent lines - there are two, or you can leave them connected and remove at t-connector
disconnect the electrical plug that goes to the sending unit, be careful not to break plastic clip.
use flat head screw driver to remove gas lines from sending unit. you can release gas pressure at the fuel rail like the instructions say,
or you can do what i did, before i ready the instructions, and pull lines, and catch gas into can.
now you are ready to completely lower the tank and remove.
post #7 of 58 Old 07-21-2012, 08:52 AM Thread Starter
trailrider787
now would be a good time to clean or do anything else you need to do while the tank is removed.
I plan to move my axle back 1" so i will do that first before i install the new tank.
post #8 of 58 Old 07-21-2012, 08:55 AM Thread Starter
trailrider787
here is the new GenRight EXT tank with Skid...pretty beefy. It is supposed to except the stock sending unit.
The skid is 3/16" steel i believe, and should provide 1" of extra ground clearance over stock.
post #9 of 58 Old 07-21-2012, 08:56 AM Thread Starter
trailrider787
here is my 8.8 diff cover, and you can see where it was rubbing by the gunk on it when the suspension cycled upward.
shouldn't be an issue with the new GenRight tank.
post #10 of 58 Old 07-21-2012, 08:57 AM Thread Starter
trailrider787
genright sends you all then necessary hardware, and includes new hose clamps for filler and vent hoses.
post #11 of 58 Old 07-21-2012, 09:00 AM Thread Starter
trailrider787
Now it is at this point, that i have to do some other modifications before i finish the tank install.
1) i need to move the axle back.
2) i am going to do a tailgate drop-down conversion, which will require getting to the tub near the gas tank.
I thought about documenting moving the axle back in this thread, since it relates to the tank, but don't know if it will help many people.
I may just detail that in my build thread.
My 92 YJ Build
post #12 of 58 Old 07-21-2012, 09:03 AM Thread Starter
trailrider787
My 92 YJ Buildhttp://http://www.jeepforum.com/foru...build-1340938/
THIS ONE DOESN'T WORK, GO TO THE NEXT POST.
post #13 of 58 Old 07-21-2012, 09:07 AM Thread Starter
trailrider787
post #14 of 58 Old 07-21-2012, 09:22 AM
Louie4
"You pass butter"
Louie4's Avatar
Steven's Beastal '92 YJ Build
Duh.
Lou
YJOTM July 2012
YJOTM February 2014
Louie4 is offline
post #15 of 58 Old 07-22-2012, 07:31 PM
crb577
I did this install in May along with a bunch of other stretch stuff from gen-right. I was able to get 4" out of this particular tank with an 8.8 and SOLID diff cover just as an FYI for others. Very good product though! goodluck
1993 Jeep Wrangler
4.0L Tom Woods rear HD shaft
D30 w/yukon alloys, lock right, jb4x4 bracket, Rusty's HD tie rod 8.8w/ LSD,SOA xj rear 100" wheelbase, homemade greasable boomerang shackles, SS braided lines, 1" prothane body lift, 35" TrXus M/T, smitty built XRC.
lots of gen right armor and rear stinger.
crb577 is offline
Genright tank and evap install, 04 rubi mudb8 TJ Wrangler Technical Forum 21 09-21-2012 11:18 AM
genright comp tank issues ssyj94 YJ Wrangler Technical Forum 4 03-04-2012 08:09 PM
Genright tank installed...what do I do with the old one? TealJ87 TJ Wrangler Technical Forum 20 12-06-2008 07:34 PM
No start after Genright Tank install smurison14 TJ Wrangler Technical Forum 13 07-16-2008 11:33 PM
Anyone here running a Genright gas tank? 1992 renagade YJ Wrangler Technical Forum 6 03-26-2008 10:46 PM
