12-16-2011, 11:48 AM
#1
The needle is broken in my voltmeter and Im getting kind of sick of looking at a dead gauge. What years was the gauge pack (4wd/gas/temp/oil/volt) the same, so I can find one to replace it? Thanks for the help.
1992 YJ 2.5L
Engine Mods:4.0L TB, Ford Design III 19lb Injectors, Firepower Ignition System, Ford TBird Electric Fan, Pacesetter Header, Magnaflow Cat, Dynomax Super Turbo Exhaust
Suspension Mods:BDS 2" Lift, M.O.R.E. 5/8" HD Shackles, 1" Brown Dog MML
Other:LED Tails and Herculined
12-16-2011, 12:18 PM
#2
It was the same for 87 thru 95, but they changed sometimes depending on the options. Like an "Islander" is different from a "renegade" is different from the "sahara" or a base-model YJ. For example mine has the clock instead of the 4WD light. All gauges fit into the cluster regardless what options the jeep had. I think they all had the volt gauge, so You could get one off anything and put it in your cluster, and it should work.
12-16-2011, 12:19 PM
#3
I want to say 1991-1995, but not 100% on that though.
12-16-2011, 12:27 PM
#4
Try Daveysjeeps.com
They should be able to help you out and they are close by.
12-16-2011, 12:40 PM
#5
ebay.com you can swap out just the gauge itself, i just had ll mine apart i had a bad ribbon and got a new one and fixed it.
12-16-2011, 12:47 PM
#6
That was a really good question. Looks like I was close. Appears to be 1992-1995. This is a good discussion on this in this thread.
http://www.jeepforum.com/forum/f12/w...89-yj-1097539/
12-16-2011, 01:25 PM
#7
I've got a cluster that I purchased for parts, still has the voltmeter in place. If you want the voltmeter its yours for postage. Send me a pm.
12-16-2011, 01:42 PM
#8
87-91 are the same, 92-95 they fixed a few problems
[url]http://www.militaryjeepers.com/community/index.phpreferrerid=5532[/url]
12-16-2011, 02:39 PM
#9
Thanks for all the info. A junkyard near me is selling me the gauge pack for $20. If they arent the same gauges now I know I can at least swap out the volt gauge from it.
Bernie- If it doesnt look like its in good condition when I go to pick it up I will shoot you a PM. Thanks for the offer.
1992 YJ 2.5L
12-16-2011, 02:58 PM
#10
What year is your YJ? I changed all my gauges out so I have a cluster. It came out of my '87. The PO painted the inside trim blue. If you want it PM me.
[COLOR="Black"][CENTER][SIZE="4"][FONT="Showcard Gothic"][COLOR="Black"][URL="http://groups.jeepforum.com/built-not-bought/"][COLOR="Black"]Built Not Bought #562[/COLOR][/URL][/FONT][/SIZE][/COLOR][/CENTER][/COLOR]
12-16-2011, 03:41 PM
#11
$20 is a damn good price! I just saw one sell on ebay for $120!
12-16-2011, 04:24 PM
#12
ISO 9001 Compliant
12-31-2011, 01:25 PM
#13
Bringing this back to life. Thanks to bernie for hooking me up with a voltmeter, but it was for the previous version of the gauges. If anyone out there has a 92-95 voltmeter for sale I would be very grateful. Thanks a lot
1992 YJ 2.5L
12-31-2011, 01:59 PM
#14
Try Daveys that I posted and see how much they want. If no luck there I know someone local that parts out Jeeps that should be able to help.
12-31-2011, 02:24 PM
#15
Ill give them a try on monday que. I need a whole new gauge because I broke the shaft to the needle on my old one.
1992 YJ 2.5L
