Yj gas tank - JeepForum.com
post #1 of 9 Old 12-11-2011, 04:42 PM Thread Starter
Mrjones
Yj gas tank
all right so i recently purchased a 92 from someone from up sate NewYork which of course means a lot of rust while i was doing some trail riding the skid plate bent backwards which caused my fuel tank to fall off it is now held on with ratchet straps. what do i need to do to replace the fuel tank skid plate and how hard is it to do?
Mrjones is offline
post #2 of 9 Old 12-11-2011, 05:56 PM
DeTeR
tank mounts to skid, skid mounts to frame.
DeTeR is offline
post #3 of 9 Old 12-11-2011, 07:47 PM
scubamc
What you will need will depend on how much damage you have. Are the mounting points for the skid to the frame rusted away?
Horsepower is like a hot girl with STDs. You know you want to hit it but you're afraid of the consequences.
scubamc is offline
post #4 of 9 Old 12-14-2011, 07:59 PM Thread Starter
Mrjones
I took it to a local 4x4 shop was qouted 250 to fix it I hope that is all it will cost
Mrjones is offline
post #5 of 9 Old 12-14-2011, 09:22 PM
Mark455SD
1961 CJ5
I would change the fuel pump since you have the tank down already.
Mark455SD is offline
post #6 of 9 Old 12-15-2011, 04:20 AM
nickmonaco
Yes change the fuel pump while your at it. Order a free quadratec or jcwhitney catalog and buy a new.tank skid and as long as you have a decent socket set, a jack or a friend with a strong chest lol. put the tank on the skid then mount the skid to the frame. And the fuel pumps aren't that hard to do either. And if you do the pump, also do the filter. Its on the inside of the frame behind the drivers side seat under a little plate. Just follow the lines. I did a filter and pump for 90 bucks from Autozone. But if you just want to fix your tank, I suggest going online or go to a pick-a-part and get what.you need. Don't pay some dude 250 bones for that sh*t
WHITE JEEP CLUB #171
My other Jeep's not a Chrysler.
nickmonaco is offline
post #7 of 9 Old 12-16-2011, 12:38 AM Thread Starter
Mrjones
Well dangit I got yalls post to late I am going on pre deployement leave today so I was in a hurry to get my rig/baby fixrd so I payed 279 for a heavy duty skid plate to be installed but now that I know..... While I am ok n leave I am going to replace all said parts. Thank you for the advice it will be put to good use.
Mrjones is offline
post #8 of 9 Old 12-17-2011, 09:20 AM
nickmonaco
We'll atleast its fixed lol you out at riley? Where you deploying too? I recently got back from RC South around Kandahar.
post #9 of 9 Old 12-17-2011, 10:27 PM Thread Starter
Mrjones
Im going to rc east zhari im w/ 82nd
Mrjones is offline
Plastic tank VS metal tank Radiators...AGAIN hdsport TJ Wrangler Technical Forum 32 10-11-2011 08:31 AM
1990 steel gas tank vs 1991 plastic tank Firefyter-Emt YJ Wrangler Technical Forum 4 08-09-2011 07:51 AM
'87 YJ fuel tank pressurized after dropping tank? Gooch YJ Wrangler Technical Forum 9 11-10-2010 05:19 PM
gas tank skid bolts spin-cant drop tank dodgetk81 TJ Wrangler Technical Forum 0 04-08-2008 08:18 PM
Gas tank skid that requires no tank removal Thunderstrike TJ Wrangler Technical Forum 27 01-08-2006 11:41 PM
