YJ Full Steel Door hoop bottoms; Repairable? - JeepForum.com
post #1 of 5 Old 10-31-2012, 02:34 PM Thread Starter
J-Quad
Hi Fellas,
The bottom of the window hoop portion of my '95 full steel doors just above the outer handle has rotted out BADLY!
Can a 'novice body repair guy' repair this section of the doors or is door replacement the only option?
Thanks in advance for any & all opinions, Guys!
J-Quad
-- '95 YJ, 4-cyl, 5-speed.
From Dec-Mar, it wears an 80" snowplow. From Apr-Nov, it gets muddy on the 2-tracks!
"War does not determine who is right, war determines who is left."
J-Quad is offline
post #2 of 5 Old 10-31-2012, 04:22 PM
beemerkid
Im going to try to do mine. Theyre pretty bad as outside the window they arent even connected to the bottom. Just a big hole. I dont see why you couldnt just cut out the cancer and re weld new sheet metal in there.
beemerkid is offline
post #3 of 5 Old 10-31-2012, 05:40 PM
jokerchief462
Post some pics for more advice!!
jokerchief462 is offline
post #4 of 5 Old 10-31-2012, 06:55 PM
PA_YJ19
If u can weld, u can repair it...if not find a buddy that can...
PA_YJ19 is offline
post #5 of 5 Old 10-31-2012, 08:09 PM
laybackman
Bikini Bridge Inspector
laybackman's Avatar
2010 JK Wrangler
I have some expereince with door repair. Not in the area where you have problems but I can tell you one thing for sure. Fabricate the patches before you cut the doors open. Then mark the doors using your patches as a template.
Oh just a worrd of caution....If you have not welded then doors are a 'challange' because the door skins are thin.....real thin.
1st version. http://www.jeepforum.com/forum/f260/...nture-1017411/
2nd version http://www.jeepforum.com/forum/f260/...t-2-a-1401807/
Do you know what was good about the good old days? I wasn't good, And I wasn't old!
Senators and Congressman should wear uniforms like NASCAR drivers so we could identify their corporate sponsors....
laybackman is offline
