YJ Full Hard Doors - JeepForum.com
post #1 of 3 Old 03-16-2008, 01:24 PM Thread Starter
dukesnyder
YJ Full Hard Doors
I have a '92 YJ, and the full hard doors I have don't quite line up with the frame and hardtop. The hinges line up just fine, but there is a fairly large gap at the top of both doors, and they rattle and bang around pretty badly. The passenger side door doesn't even really close the whole way and the rubber door seal sticks out along the edge. I know it's not the hinges on the frame of the Jeep because the half doors fit fine with the softtop on. I heard somewhere that CJ doors almost fit YJs...could this be the problem?
Thanks!
dukesnyder is offline
post #2 of 3 Old 03-16-2008, 01:32 PM
obsessedjeeper
obsessedjeeper's Avatar
2013 WK
the cj doors will fit just fine if they are aligned properly. you most likely need to loosen the bolts on the door and align it properly then retighten the bolts
Keep on Jeepin
95 YJ
98 ZJ
obsessedjeeper is offline
post #3 of 3 Old 03-16-2008, 02:42 PM
Burnerman
Burnerman's Avatar
Just loosen the torx screws on the door side of the hinge and adjust them. If you don't want them though I'll drive up and pick them up. Seriously though, the doors can be adjusted to get rid of the gap and the striker can be adjusted to seal the door tight to the body. I had a gap I could see thru on my stock full doors, after adjustment....none.
96 ZJ.
05' Grand Cherokee Limited, 2"OME lift
Burnerman is offline
Half Hard Doors vs Full Hard....Key Cylinders Swappable? Hunta TJ Wrangler Technical Forum 17 05-13-2009 03:57 PM
Full Doors and Hard Top LST022752 YJ Wrangler Technical Forum 4 12-16-2008 09:14 PM
Full hard doors 95YJRookie YJ Wrangler Technical Forum 9 04-21-2006 02:16 PM
Full doors and Hard Top gsdpwd TJ Wrangler Technical Forum 1 11-26-2005 05:14 PM
Soft top? full hard doors vs. half doors jgarden TJ Wrangler Technical Forum 8 10-17-2004 03:00 PM
