YJ Full Doors - Buying - JeepForum.com
post #1 of 6 Old 08-24-2011, 08:05 AM Thread Starter
LeJerk
2009 JK Wrangler
Someone has a set of full door for sale locally, and I was wondering what you guys thought of them. Are there things I need to look for when I see them in person? I've never used or owned hard doors before so I'm a bit cautious. THe seller says the windows roll up and down fine, but hasn't used them in the rain or anything to see if they leak.
I have attached some pictures.
LeJerk is offline
post #2 of 6 Old 08-24-2011, 08:16 AM
dadstoy
Looks like the drivers side will leak due to the bend in the top.
My advice is to look at the bottoms for rust. Also check around where the window frame meets the top of sthe door. The doors I sold last year had a little surface rust in those areas and the weld was broken on the passenger side of the frame/door point.
dadstoy is offline
post #3 of 6 Old 08-24-2011, 08:32 AM
Que89YJ
That bend in the door is definitely going to cause a leak. You could throw it on and see but unless you are buying them knowing fixing the window frame will be necessay then I would pass on it. what kind of price is he asking?
Que89YJ is offline
post #4 of 6 Old 08-24-2011, 09:58 AM
jmmorgan82
2009 JK Wrangler
I wouldn't pay more than about $150 for them, but they look like they will at least keep you dry.
jmmorgan82 is offline
post #5 of 6 Old 08-24-2011, 10:08 AM
19OlllllllO41
19OlllllllO41's Avatar
I say pass unless its a GREAT deal.... that is unless you want to try to fix that driver door, which is going to be a PITA to get perfectly back into shape to close/seal correctly.
The Present:
'05 TJ Rubicon (Electric Lime Green)
'04 WJ
'46 CJ2A
The Past:
'83 CJ7, '92 YJ, '00 XJ, '99 TJ, '05 TJ Rubicon (Impact Orange)
19OlllllllO41 is offline
post #6 of 6 Old 08-24-2011, 10:10 AM
Jeff88
Open the vent windows. Most commonly they will fall out when you try to.
This may help you get a discount from the seller.
Jeff88 is offline
buying full hard doors for 200 y/n? sherminator866 Wrangler General Discussion 2 01-11-2011 02:27 PM
Half doors to full steel doors - '94 body, '88 doors xponce YJ Wrangler Technical Forum 8 02-20-2010 03:29 PM
Full doors… worth buying after the fact? sulaco TJ Wrangler Technical Forum 18 11-25-2004 02:13 AM
A soft top compatible with full steel doors and full soft doors? 91yjmd YJ Wrangler Technical Forum 1 01-16-2004 10:30 PM
Buying TJ with hardtop & hard doors, but I want a soft top & half doors xxxxxxxxxxxxxxxxxxxgksspot TJ Wrangler Technical Forum 11 10-26-2003 09:16 AM
