YJ Fuel Tank Removal Problem - JeepForum.com
post #1 of 9 Old 10-19-2009, 06:55 AM Thread Starter
Matt53
1987 YJ Wrangler
I dropped my fuel tank and broke a part. Not sure what the part is, I cant see where or if it even attaches to the fuel tank. All hoses were intacked and electrical connections. The part in question is connected to a line that runs with the fuel supply and return. It is smaller and a more flexible hose connected to a white plastic and black rubber part that looks like an inline fuel filter. The hose runs through the metal loop on the top of the tank back over to the right rear side of the tank. Can anyone tell me what this part was attached to and what it is called before I remount my tank?
Matt53 is offline
post #2 of 9 Old 10-19-2009, 07:01 AM
Djsthe1
Is it a vacuum line?
Djsthe1 is offline
post #3 of 9 Old 10-19-2009, 07:13 AM
RebuildRookie
It goes under the right rear quarter panel. Remove (or just pull it back) your flap underneath the right rear and look up there. that is where it goes.
I'm a more proactive person.
You spray the ants before they get in your house.
You plant the crops before you starve.
And you keep the terrorists in check before you get your *** blowed off.
RebuildRookie is offline
post #4 of 9 Old 10-26-2009, 08:58 AM Thread Starter
Matt53
1987 YJ Wrangler
Not sure if vacuum line, how would I tell?
Matt53 is offline
post #5 of 9 Old 10-26-2009, 08:59 AM Thread Starter
Matt53
1987 YJ Wrangler
I will check, what does it go to? Can I just tie it back up and leave it or does it return fuel or something like that?
Matt53 is offline
post #6 of 9 Old 10-26-2009, 09:44 AM
RebuildRookie
I think it is something like a rollover check valve, vent tube. Something along those lines
post #7 of 9 Old 10-26-2009, 09:52 AM
scottsea
Yes its your rollover valve / vent tube. Like mentioned before it runs from your passenger side of the tank up under the pass. side rear qtr panel. Then runs back over the fuel tank and to the engine comparment to the charcoal canister. Mine was pretty much gone so I replaced it and ran it down the passenger side to the canister, used metal tube near the cat. other then that used fuel line the rest of the way. Hope this helps.
scottsea is offline
post #8 of 9 Old 10-26-2009, 09:55 AM
Reverb
x2 rollover check valve - you can pick them up on ebay now and again - had a hell of a time finding them anywhere else
EDIT: here you go
Reverb is offline
post #9 of 9 Old 11-04-2009, 08:22 AM Thread Starter
Matt53
1987 YJ Wrangler
Thanks big help
Matt53 is offline
1/4 tank fuel problem 87TPIYJ YJ Wrangler Technical Forum 9 04-24-2009 10:23 PM
Need help with fuel tank removal? nickstix YJ Wrangler Technical Forum 4 04-08-2009 10:10 AM
95 Wrangler Fuel tank problem orgullodemexico YJ Wrangler Technical Forum 1 06-04-2007 09:15 AM
TJ Fuel Tank Problem Again!!! Stasis TJ Wrangler Technical Forum 7 07-27-2006 10:58 AM
Gas Gauge/ Fuel Tank Problem muddyforeman TJ Wrangler Technical Forum 0 12-11-2005 01:02 PM
