yj fuel tank??????? - JeepForum.com
post #1 of 3 Old 11-06-2012, 03:13 AM Thread Starter
zxrider
yj fuel tank???????
I searched this and found the same question i have. There was no answer.
Will the fuel tank from a 87-90 work in a 95?
After reading a few threads i assume that it wont. Assuming 91-95 are fi and the pump is different. My tank is plastic. The one from quadratec is metal. I dont mind using metal if it can save me $100.
So.... Can I use a tank from 87-90?
Is there a way to make it work?
zxrider is offline
post #2 of 3 Old 11-06-2012, 05:23 AM
Louie4
I'm sure there is but as you know the electric fuel pump is in the tank on the '95 model and I believe the '95's are 19 gallon while the early models are 15. I could be wrong on that but that's what I think.
So if the 87-90 tank doesn't have a fuel pump but you can always put an external one in. Then again you have to worry about if it will fit or not. I'd be inclined to getting a stock replacement but that's just me.
Lou
YJOTM July 2012
YJOTM February 2014
Louie4 is offline
post #3 of 3 Old 11-06-2012, 05:30 AM
Que89YJ
You don't want to use the metal tank in the 91-95. The skid and straps as well as the fuel pump mount is different. The plastic tank is really easy to find used. No dont use the metal tank.
Que89YJ is online now
