YJ fuel issues after rebuild....help! - Page 3 - JeepForum.com
post #31 of 48 Old 06-03-2013, 07:51 AM Thread Starter
jakethemuss
I'm so glad your tying to help me. Thanks. How do I check the codes?
jakethemuss is offline
post #32 of 48 Old 06-03-2013, 08:58 AM
pete1991YJ
Its easy to get the diagnostic codes, all you need is the key! Here's a video that shows how. This is the first thing I do whenever there is any prob at all with mine.
***--- Wrecking Crew member ---***
"I've prolly been around longer than you think"
pete1991YJ is offline
post #33 of 48 Old 06-05-2013, 09:46 PM Thread Starter
jakethemuss
Ok. I will try that. The only issue I have is the stripped column from a theft issue years ago. Haha
post #34 of 48 Old 06-06-2013, 01:39 PM Thread Starter
jakethemuss
I'm getting a "33"code. CPS
post #35 of 48 Old 06-06-2013, 06:11 PM
Que89YJ
33 is normal ignore it. what do you mean by cps?
Que89YJ is offline
post #36 of 48 Old 06-06-2013, 06:25 PM Thread Starter
jakethemuss
33 is the cps
post #37 of 48 Old 06-06-2013, 06:53 PM Thread Starter
jakethemuss
I just looked that code up in the book and it said cps
post #38 of 48 Old 06-06-2013, 08:01 PM
Que89YJ
33 is the ac relay. not applicable
Que89YJ is offline
post #39 of 48 Old 06-06-2013, 08:50 PM Thread Starter
jakethemuss
It's not the crank position sensor?
post #40 of 48 Old 06-07-2013, 04:21 AM
Que89YJ
33 is the ac relay. 11 is the cps
Que89YJ is offline
post #41 of 48 Old 06-07-2013, 05:36 AM Thread Starter
jakethemuss
Damn
post #42 of 48 Old 06-07-2013, 05:46 AM
jsawduste
2006 YJ Wrangler
While there are plenty of good folks on this forum to help you along. The purchase of a Haynes manual or the link to the factory service manual would help YOU out immensely. With the manual YOU can become a bit more educated and MAYBE fix this and futrue issues on your own. It`s a learning curve and right now YOU do not that the tools required to learn.
Get them.
jsawduste is offline
post #43 of 48 Old 06-07-2013, 05:58 AM Thread Starter
jakethemuss
I have the Haynes. First time I ever did the codes and looks like I got it wrong. Thanks for YOUR condescending help.
post #44 of 48 Old 06-07-2013, 07:13 AM
jsawduste
2006 YJ Wrangler
I would read the manual from cover to cover and then again. Your questions could have all been answered by looking them up. 43 replies and plenty of time wasted on stuff YOU could have figured out with the manual in hand.
I will help a guy out but at some point they need to start helping themselves.
post #45 of 48 Old 06-07-2013, 07:51 AM
Que89YJ
5000 rpm is a crazy high idle. I dont know how it is even possible with the throttleplate closed. Can you start it up and out your hand over the throttlebody to stop any air from getting in and see if it is still able to run. With the butterfly closed inside the throttlebody there is no way, and I mean absolutely no way that it should be able to pull the air is takes to idle or run at that kind of rpm. Also Jack, if you would please fill in the info on your profile.
Que89YJ is offline
