YJ fuel issues after rebuild....help! - Page 2 - JeepForum.com
post #16 of 48 Old 04-18-2013, 07:02 PM Thread Starter
jakethemuss
I guess it might be time buy one. I tried to figure it out with jumpers. No luck.
jakethemuss is offline
post #17 of 48 Old 04-19-2013, 09:06 AM
Que89YJ
Vehicle harness connector wiring looking into the connector left to right:
Pin 1 Black/Orange - Ground
Pin 2 Dark Blue - Fuel level
Pin 3 Dark Green/Black - Power
Left to right looking at the connector
Here is a link to the on line Factory service manual:
http://www.jeep4x4center.com/knowled...ex.htm#service
And here are a couple threads:
http://www.jeepforum.com/forum/f12/a...oblem-1361262/
http://www.jeepforum.com/forum/f12/f...-wire-1320761/
Que89YJ is online now
post #18 of 48 Old 04-26-2013, 02:46 PM Thread Starter
jakethemuss
Ok. Wiring is handled. Now the issue. Pump runs but no fuel from outlet. I heard it spraying inside of the tank. Pulled the pump hatch and I really don't know what to look for. And should there be a gasket for the rectangle hatch?
post #19 of 48 Old 05-24-2013, 05:22 PM Thread Starter
jakethemuss
Ok. Found the fuel problem. The bottom of the fuel pump snapped off. I get fuel and starts right up. But it's racing at high RPM. Could it be a throttle position sensor? I did remove the fuel rail to install new exhaust headers. Any ideas?
post #20 of 48 Old 05-25-2013, 06:50 AM
Que89YJ
iac or a vacuum leak. remember to disconnect the battery after messing with any sensor.
Fault codes:
Mean Max pics of everything:
No Start:
post #21 of 48 Old 05-25-2013, 07:48 AM Thread Starter
jakethemuss
What's the "iac"?
post #22 of 48 Old 05-25-2013, 04:38 PM
Que89YJ
idle air controller. search the forum for the writeup on cleaning it.
Fault codes:
No Start:
post #23 of 48 Old 05-28-2013, 09:15 PM Thread Starter
jakethemuss
Ok. I did a pretty thorough cleaning and rebuilt the vacuum lines coming out of the valve cover. Did a few minute battery reset. Still the same thing. Starts but idles at over 5000rpm. Kinda scary. The fuel pump issue was a broken pick up tube. Replaced new pump again and that problem solved.
post #24 of 48 Old 05-28-2013, 10:20 PM
Que89YJ
That is a stuck throttle. I don't think a vacuum leak or an iac issue is capable of going over 3000 rpm
Fault codes:
No Start:
post #25 of 48 Old 06-01-2013, 07:38 AM Thread Starter
jakethemuss
Cable seems to move freely. Is it just time for a new one? Or take it out and clean and use dry slide(graphite)?
post #26 of 48 Old 06-01-2013, 09:05 AM
Que89YJ
is the throttle plate fully closed in the throttle body?
Fault codes:
No Start:
post #27 of 48 Old 06-01-2013, 09:16 AM Thread Starter
jakethemuss
Looks like it. I cleaned it pretty good, no change
post #28 of 48 Old 06-01-2013, 03:52 PM
Que89YJ
and you are idling at 5000 rpms still ?
Fault codes:
No Start:
post #29 of 48 Old 06-01-2013, 08:12 PM Thread Starter
jakethemuss
Yup. In going to replace the the IAC motor and the TPS and try again. All original parts I'm replacing on a 114000mi YJ.
post #30 of 48 Old 06-03-2013, 08:36 AM
Que89YJ
Dont throw parts at it. Check the codes. 5000 should never be set by electronic control. No sensor failure will cause an idle that high. Not for any reason. If the throttleplate is closed you should not have enough air through the throttlebody to run it at that high of an idle. To do that you must have a huge vacuum leak and even then I dont know how it is possible. Put your hand in front of the throttlebody and see if it stalls. Are you 100% sure that plate is closed? You need to look around for a vacuum leak. It has to be a major one. Brake booster, PVC, etc.
