YJ fuel issues after rebuild....help! - JeepForum.com
post #1 of 48 Old 04-05-2013, 05:13 PM Thread Starter
jakethemuss
I am trying to wrap up my rebuild on my '93. Clean fuel tank and new fuel pump. The engine will start with starter fluid then die. I am checking the fuel filter next. And ideas? 4.0 injected.
jakethemuss is offline
post #2 of 48 Old 04-05-2013, 05:33 PM
broken-wrangler
Check to see if your fuel lines are plugged. You can do that by putting a air compressor on one end and disconnecting the other and blow her through
Josh Ashley
broken-wrangler is offline
post #3 of 48 Old 04-08-2013, 06:37 PM Thread Starter
jakethemuss
No fuel to the fuel filter. I'm going to drop the tank and start over I guess. Maybe try switching the hoses from the fuel pump first. And I do hear the pump turning on. Is there a priming issue?
post #4 of 48 Old 04-08-2013, 07:09 PM
jokerchief462
No priming issue the feed and return lines may be backwards. Ask me how I know.
89YJ 2.5L TBI, AX-5, NP231 SYE, Ford 8.8, Yukon Grizzly, Tom Woods Shaft, 33" BFG T/As, 4" lift, Warn VR10000s.
AF Jeep Club Tail #184
jokerchief462 is offline
post #5 of 48 Old 04-12-2013, 09:24 PM Thread Starter
jakethemuss
Ok. Got it all down and apart. It's the connector coming out of the fuel pump. Any tricks to keeping the connector from separating the pins/wires? Or is a better connector the answer?
post #6 of 48 Old 04-14-2013, 06:36 PM
Braindeadly
At the wire terminal on the pump, or the 3 pin connector outside of the tank?
Braindeadly is offline
post #7 of 48 Old 04-14-2013, 07:55 PM Thread Starter
jakethemuss
@ the 3pin. Plug won't stay together within the plastic housing on the fuel pump end. The wires pull right out of the back.
post #8 of 48 Old 04-14-2013, 08:56 PM
Que89YJ
Go to any of the parts store and get a 3 pin weather pack connector.
Fault codes:
Mean Max pics of everything:
No Start:
Que89YJ is offline
post #9 of 48 Old 04-18-2013, 01:44 PM Thread Starter
jakethemuss
Can anyone draw me the schematic of the plug connecting the fuel pump to the system. Wires pulled out of the plug and I'm lost!
post #10 of 48 Old 04-18-2013, 01:46 PM Thread Starter
jakethemuss
Both ends, please...
post #11 of 48 Old 04-18-2013, 04:40 PM
Que89YJ
You can get a generic weather pack plug from the parts store and match the wire colors. If the wires pulled out the detent that hold the wire is probably shot.
Fault codes:
No Start:
Que89YJ is offline
post #12 of 48 Old 04-18-2013, 05:06 PM Thread Starter
jakethemuss
But what wire colors go to what?
post #13 of 48 Old 04-18-2013, 05:10 PM
Que89YJ
now I understand the pump harness is different color then the vehicle wiring and they don't match up?
Fault codes:
No Start:
Que89YJ is offline
post #14 of 48 Old 04-18-2013, 05:25 PM Thread Starter
jakethemuss
Correctamundo!
post #15 of 48 Old 04-18-2013, 05:45 PM
Que89YJ
do you have a meter?
Fault codes:
No Start:
Que89YJ is offline
