YJ front rollbar that bolts to dash? - JeepForum.com
post #1 of 4 Old 05-01-2001, 06:02 PM Thread Starter
JW
Is anyone aware of the manufacturer of a YJ front rollbar that replaces the factory unit but reaches down and bolts to the dash-just below the windsheild? Also, how well does it fit?
JW is offline
post #2 of 4 Old 05-01-2001, 06:26 PM
jeffy
jeffy's Avatar
I've got a J&L bolt in cage. M.O.R.E sells the exact same kit. You can also go get a Smittybilt CJ weld in kit too.
*** www.4BangerJP.com ***
jeffy is offline
post #3 of 4 Old 05-02-2001, 07:54 PM
rayray
rayray's Avatar
I have the MORE kit. It doesn't replace the dash. It goes to the floor, and then you have to weld some braces to the frame under the floor. I'm not sure why you would want to bolt near the dash. The stress would be placed on the cowl and would crumple.
Earth First! We can wheel the other planets later
rayray
rayray is offline
post #4 of 4 Old 05-03-2001, 08:29 PM
RatherBeJeeping
Is this what you want?
John
95.5 YJ with "stuff"
RatherBeJeeping is offline
Through the dash rollbar pics . G Beasley TJ Wrangler Technical Forum 8 02-19-2010 03:41 PM
Mounting Soundbar in front of Rollbar als2000 TJ Wrangler Technical Forum 3 04-25-2006 08:02 PM
Moving soundbar in front of rollbar? als2000 TJ Wrangler Technical Forum 7 04-14-2006 12:38 PM
Bolt size for the 4 bolts attach softtop bow to rollbar? jzmtl TJ Wrangler Technical Forum 3 03-03-2006 06:47 PM
Raingler Grips on Front Rollbar? moitura TJ Wrangler Technical Forum 8 08-02-2004 02:30 PM
