Quantcast YJ front coil conversion - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > YJ front coil conversion
Old 06-14-2006, 06:24 PM   #1
YJscott2
where can i get the coil buckets that come out of the frame that holds the top of the coil?
what are they called and how much are they and where can i get them
YJscott2 is offline   Reply With Quote
Old 06-14-2006, 06:26 PM   #2
YJscott2
Originally Posted by JOKER4INK
heres a not-so-good pic of my coil conversion on my YJ:
the things at the top of the coil????
Old 06-14-2006, 06:38 PM   #3
Joel77
where are you located???
Joel77 is offline   Reply With Quote
Old 06-14-2006, 06:45 PM   #4
JOKER4INK
HEY! Thats my frame! Sweet! My frame is getting exposure! WOO HOO! Anyway, call Clayton Off-Road. They are like 5 minutes away from me. The number is (203) 757-0339 or visit them at www.claytonoffroad.com They can sell you all pieces you need. Just so you know, they cut the frame where the spring mount goes so the springs fit in. if you dont cut into it, the spring will not fit right. Basically, my 44 can come out and be bolted under any TJ or XJ. If you werent to cut into the frame, the lower spring buckets would need to be moved out slightly so they are in the same position as the uppers. Then again, the control arms would be off. I think they need to be in as mine is, but Im sure someone will argue the opposite. Just so you know, where the frame is cut is, has 1/4" steel in there for strenght, its not open or exposed. Here are a couple more pics of what it looks like close up. Dont mind the rain drops on it:
Here is a pic of the rear shocks mount. As you can see, the cut into it also to make room for the long travel shocks.
88 YJ...kinda. Clayton Hard Arms, V8, 1 tons running gear, twin sticked, Irok's, fuel cell, multi-colored
JOKER4INK is offline   Reply With Quote
Old 06-14-2006, 07:13 PM   #5
YJscott2
haha joker i pmed you but your box was full. and i new you would see it on here!
Old 06-14-2006, 07:14 PM   #6
JOKER4INK
just cleared it! send pm's or post questions here that could possibly help out other Jeepers
Old 06-14-2006, 07:18 PM   #7
YJscott2
what track bar are u runing also?
Old 06-14-2006, 07:25 PM   #8
JOKER4INK
Its an adjustable Clayton track bar up front. There is no track bar in the rear with the 4 link.
Old 06-14-2006, 07:48 PM   #9
YJscott2
do u remeber how much just the front portion cost you?
Old 06-14-2006, 07:52 PM   #10
JOKER4INK
Nope, no idea. I bought it complete. If you decide to call Clayton, there is a guy name Adam there. He is very knowledgeable! He or Clayton can tell you more than you'd want to know.
Old 06-14-2006, 08:01 PM   #11
YJscott2
oh ok yeah i have been askin them ?s when are u goin to have the complete truck done?
Old 06-14-2006, 08:08 PM   #12
JOKER4INK
That is the question of the damn century! I have nooo idea. I still have a lot more to go. Its stupid stuff too. For instance, I couldnt put the tranny in until I got the correct flywheel bolts (1st time was wrong), then I found out the clutch fork was bad and couldnt get a new one for like 3-4 days. Even the dealership would have had to order one. then its like oh, the motor mounts need to have a spacer in between them and the frame, and then its one thing after another... oh yeah, i need money. thats a key too! and new england weather has cooperated so any time id go out to do something, it'd end up raining. but i still have stuff to buy :fuel cell, radiator and driveshafts. other than that, i have everything else. It took me a little while to get the motor all set with new seals and gaskets and cleaned and what not too. its all prep that slowed me down
Old 06-14-2006, 09:11 PM   #13
YJscott2
Cant Wait To See It.
Glock Forum
