YJ Front Axle Swap - JeepForum.com
post #1 of 18 Old 02-05-2012, 08:47 PM Thread Starter
eharper
YJ Front Axle Swap
Hey guys of course i broke my dana 30 and now that its broke i might as well upgrade it while ive got it out. I bought a set of dana 44 front and rear that came out of a jeep wagoneer 1977 with locked front. With that being said i needed the left side drivers drop for the differential and the ones that i bought are both pass. side drop. Rookie mistake i know.
So what i am trying to figure out is. .
Can i flip them over? will they oil correctly upside down?
I know the Ford 8.8 will work as well. . What is better or easier ?
Can i find a locked larger front end and leave the back the same witihout messing with gear ratio?
Also since i am where i am i was thinking about doing SOA while ive got it all broke down. What do you think ?
eharper is offline
post #2 of 18 Old 02-05-2012, 09:03 PM
Irongrave
get a dana 300 and run what you've got
also easy and axle swaps do not go hand in hand
Current
2002 WJ 2wd DD
Irongrave is offline
post #3 of 18 Old 02-05-2012, 11:41 PM
vwtipeii
vwtipeii's Avatar
Go big or go home.... I mean if u are going to swap axles spend the money and do it right or you will just spend more money again later. I recommend just buying a set of chromoly shafts and keep what ya got till you r ready to go to a hi 9 or 60.
I am running my d 30 w Yukon chromo 4 piece shafts 27 spline still w arb and stock outers w 17" wheels and 37" tires. No problem yet and I ran the rubicon this summer and several other decent trails over the past year is social.
vwtipeii is offline
post #4 of 18 Old 02-06-2012, 05:11 AM
Louie4
Originally Posted by vwtipeii View Post
I recommend just buying a set of chromoly shafts and keep what ya got...
This. Unless you're running something larger than 35's they should do the job. I would probably try to sell the front D44 you have and look for a Wagoneer front D44 with the drivers side drop.
Lou
YJOTM July 2012
YJOTM February 2014
Louie4 is online now
post #5 of 18 Old 02-16-2016, 05:59 AM
StanF
Are you really just running 31" tires, as mentioned in your profile? If so, there is NOT any reason to do an axle swap. Chromoly shafts, as recommended above, is all you need. This will also give you stronger, larger U-joints that came on later Dana 30s.
What did you break on the Dana 30?
StanF is online now
post #6 of 18 Old 02-16-2016, 08:56 AM
Shadownwpa
... not if you want to do anything other than go straight.
http://www.jeepforum.com/forum/f22/shadownwpa-91ish-yj-build-thread-1857154/
Shadownwpa is offline
post #7 of 18 Old 02-16-2016, 09:02 AM
Randonexplosion
Deplorable
Randonexplosion's Avatar
Dang Stan, how did you find this thread?
Randonexplosion is offline
post #8 of 18 Old 02-16-2016, 10:37 AM
ed4banger
What do you guys think of the G2 crate D44s?
ed4banger is offline
post #9 of 18 Old 02-16-2016, 11:57 AM
Sprungover
2012
1989 YJ, 1977 CJ-7
Sprungover is offline
post #10 of 18 Old 02-16-2016, 02:21 PM
StanF
Lol - oops!
StanF is online now
post #11 of 18 Old 02-16-2016, 02:32 PM
Randonexplosion
Deplorable
Originally Posted by StanF View Post
Lol - oops!
post #12 of 18 Old 02-16-2016, 06:48 PM
Feetwet
Enjoying the Ride
Feetwet's Avatar
Started by some drive-by one poster asking a convoluted question while supplying little info. We beat our heads together trying to help.
Then they disappear.
Seems to be a lot of that around here lately...
Fight Crime...Shoot Back
Friends don't let friends roll over without a negative-G strap
Feetwet is online now
post #13 of 18 Old 02-16-2016, 07:11 PM
Joe Dillard
Electric Chair Operator
Joe Dillard's Avatar
I've been weeding some of them out as I see them.
Joe Dillard is offline
post #14 of 18 Old 02-16-2016, 08:18 PM
jsawduste
2006 YJ Wrangler
Was one the guy that was saying his 4 cylinder would do a 100 mph ?
I miss that one.........
jsawduste is offline
post #15 of 18 Old 02-17-2016, 06:10 AM
Feetwet
Enjoying the Ride
Feetwet's Avatar
Thankless job you Mods do, Joe, but Thank You anyway...
Spammers gonna spam, Trolls gonna troll. Fact of life these days...
Front Axle swap hester88 YJ Wrangler Technical Forum 6 09-21-2011 12:41 PM
front axle swap redrubi03 YJ Wrangler Technical Forum 11 06-11-2011 11:07 AM
94 YJ front axle swap xponce YJ Wrangler Technical Forum 0 06-10-2011 10:16 AM
Front Axle Swap munroejp TJ Wrangler Technical Forum 15 12-11-2009 11:51 AM
Front Axle Swap Wynne TJ Wrangler Technical Forum 4 11-20-2008 03:35 AM
