yj front axle engagement - JeepForum.com
post #1 of 5 Old 10-24-2011, 02:56 PM Thread Starter
hurricane99
ive got a 89 wrangler with a 4.2 and a 5-speed. i have it stored outside and last year when it started to snow i need it to get around. well long story short i put it in 4 hi and low but the light would not come on at all and i just sat there spinning my rear wheel. i had to get pulled out by my friends tj and it kinna pissed me off. i dont think my vaccum motor works my question is what is a great way to lock the front axle without a lot of money. i want to have it work before it snows again it will not be a dd it will just be for emergency snows .ive done a search but i just need a simple fix. thanks
1989 jeep wrangler. bone stock jeep 4.2l inline 6 backed by a peugeot 5 speed and np231 tcase.
hurricane99 is offline
post #2 of 5 Old 10-24-2011, 03:05 PM
94chb
if you did the search you would have seen the answer
1: pull cover off and slide fork over by hand and lock it in Cost : 0$
2: buy a axle from a cherokee or tj and swap it into your housing and change seal Cost: about $40-50
3: buy a cable locker, instead of it vacum locking you can pull a cable and manually lock it. cost: $30-100
94chb is offline
post #3 of 5 Old 10-24-2011, 03:32 PM
8yj9
Where did you find the manual cable lock for 30?
8yj9 is offline
post #4 of 5 Old 10-24-2011, 04:09 PM Thread Starter
hurricane99
i found those writeups on here i just was not sure if they would be right thing. thanks for the answer ill check the junk yards for the axles and go from there
post #5 of 5 Old 10-24-2011, 04:12 PM
94chb
some people have made their own cable locker thats where the $30 comes in, and some people just buy the kit for $100
have you checked your vacum lines to see if one is broke or got a hole? i have the whole complete vacum line harness ill sell for $35 shipped.
94chb is offline
Front axle engagement staush YJ Wrangler Technical Forum 7 09-22-2010 07:59 AM
shafts in front axle moving at engagement point schizm99 YJ Wrangler Technical Forum 3 05-06-2009 02:00 PM
Front axle engagement alternative pajeep YJ Wrangler Technical Forum 0 01-25-2009 12:15 PM
TJ front axle engagement??? julietkilo TJ Wrangler Technical Forum 14 11-03-2004 03:37 AM
Posi-Lok axle engagement system JKNIPE2000 YJ Wrangler Technical Forum 2 09-24-2004 04:28 PM
