-   -   ► YJ Frequently Asked Questions (FAQ), Write Ups & stock specs. Look here first (http://www.jeepforum.com/forum/f12/yj-frequently-asked-questions-faq-write-ups-stock-specs-look-here-first-580536/)
rustywrangler 07-09-2008 07:42 PM
WRITE-UPS, TECH HELP AND BASIC MAINTENANCE ARTICLES INDEX:
Engine Tech / Engine Swap / Carb Section:
Transmission:
Transfer Case:
Axles / Steering / Brakes / Drive Shafts:
Suspension:
Body / Frame:
Exhaust / Emissions:
Armor / Recovery:
Interior:
Electrical/Lighting/Audio:
Heating and A/C:
rustywrangler 10-15-2009 06:40 AM
Basic Maintenance- Engine Oil Change
Basic Maintenance- Fuel Filter replacement
Basic Maintenance - 4.0L serpentine belt tension adjustment
Basic Maintenance - Carter Carb Tear Down and basic rebuild kit, How-To
Team Rush Mod Write-up with pics
Howell TBI Fuel Injection Kit Install
4.2 ECU repair, how-to
Hard or No Start/Long cranks in the cold explained
Weber 32/36 Install
Weber 34/34 Tuning
Diesel 4Bt Cummins Swap
Chevy 4.3/700R4/231C Swap Details
4.0 Swap, Everything You Need To Know Is Here
The Original Nutter Bypass
A Picture Guide To the "Nutter Bypass"
The "Nutter Bypass" The JeepForum Way
Hummer Style Intake Write-Up
How to tell what water pump you need
Blazin Den Hand Throttle Write Up
Feetwet's Hand Throttle Install
Grand Cherokee 136A Alternator Write Up
rustywrangler 10-15-2009 06:41 AM
Transmission:
Basic Maintenance - BA-10 Oil Change
Basic Maintenance - AX-15 Oil Change
Basic Maintenance - Trans Mount Replacement
Basic Maintenance - The External Clutch Slave Unit Replacement
Basic Maintenance - Removing the shifter knob, How-To
Separating The Upper Shift Lever From The Lower, How-To
Clutch Master Cylinder Replacement Write-Up
How To: Remove Clutch Pedal assembly for repair/replacement
AX-15 Internal to External Slave Cylinder Swap, Write Up
AX-15 Shift Tower Bushing Replacement, How-To
BA-10/5 To AX-15 Trans Swap, How-To
Peugeot BA10/5 to NV3550 Trans Swap, How-To
AX-5 TO AX-15 Swap Behind A 2.5L Swap
AX-5 TO NV3550 Swap
NV3550 Shifter Removal
How to Add A Breather Line to Your AX-5 Transmission
AX-5 5th gear clip/collar repair without trans removal
TF999 became the 32RH
Interlocks/shift rails for the AX 15
Swapping the NV3550 to the AX15
Transfer Case:
Basic Maintenance - 231 Fluid Change, How To
NP231 Output Shaft/Seal Leak, How-To Repair Write-Up
NP231 and Dana 300 Combo Write-Up
T-Case Shifter Z-Gate Elimination Write-Up
NP 231 rebuild/SYE install, How-To
How-To Install An SYE With The Tcase In The Jeep
RikRotorHead ~True Neutral Plate~
rustywrangler 10-15-2009 06:44 AM
Basic Maintenance - Diff Fluid Change/Service
Basic Maintenance - Front end alignment check
Basic Maintenance - Wheel stud removal/replacement
How-To Gear Install, By Joe Dillard
Lower Steering Shaft Bearing Replacement
Steering Gear Box Adjustment, How-To
Home Made Posi-Lok Setup, Install
How to: Vacuum Disco Elimination, Axle Tube Sleeve Fix, ubolt eliminator - 56K beware
Ford 8.8 E brake solution, install
How to decipher what disk brakes you need in your stock rig
Dana 30 Axle U Joint Replacement, How-To
TJ Dana 30 Solid Axle Shaft Conversion
Durango Steering Box Writeup, In a ZJ but the same concept
Do It Yourself Dana 44 Axle Truss, How-to
How To: Remove Brake Pedal assembly for repair/replacement
DIY XJ Front Driveshaft Shortening
Dana 30 Passenger CAD Seal Install
Suspension:
http://www.jeepforum.com/forum/f12/everything you need know about shocks work why you need them
SOA Parts List/Reference Guid
Rough Country 2.5" Lift Kit Install
Rough Country 4" Lift Kit Install
BDS 2" Lift Kit Install, Detailed
S10 "Bastard Pack" spring lift. Budget lift.
Shackles and Shackle Lifts, Everything You Need To Know
How-To Extend Your Rear Upper Shock Mount
Sway and Track bar removal, How-To
rustywrangler 10-15-2009 06:45 AM
Body / Frame:
Basic Maintenance - How To Clean Cloudy Turn Signal Lenses
write-up: how to install TJ uppers on YJ 1/2 doors w/ YJ hard top
Bestop Fiberglass Upper Door Sliders Install
WHY is there water under my dash, Troubleshooting water under the dash, write-up, how-to......
YJ Tub Removal, How-To
Body Mount Bolt Locations (For BL) - Detailed Write-Up W/ Pix
CJ Front End Install On A YJ
Mirror Mount Mod
Fuel Door Filler Relocation, Write-Up
Gas Tank/Fuel Pump Access Panel, How-To
Rear Frame Rot Repair
Custom Rear Frame Cross Member
How To Replace Nutsert For Transfer Case, Removal and Install
15-20 Gallon Tank Conversion
How-To Fill Holes In The Tailgate When You Remove The Stock Tire Carrier
YJ To TJ Front Grill Swap, Fabrication and Write up
TJ Flares on a YJ
Replacing Your Cracked Exhaust Manifold - HOW-TO
4.2 manifold gasket replacement
Armor / Recovery:
Home Made Winch Plate Write-Up, Install I
Home Made Winch Plate Write-Up, Install II
Front Tow Hook Install
rustywrangler 10-15-2009 06:46 AM
Interior:
Basic Maintenance - Seat belt reel service
Basic Maintenance - Bikini top velcro repair
Replacement YJ Seat Swap Master List, How-To's
Herculiner How To, with questions and answers
CJ Dash Into A YJ Swap Write-Up
How-To Remove the metal dash support frame
Ammo Can Center Console Install, How-To, Tips
TJ upper sliders on YJ half doors, How-To
Custom back seat cargo rack
Basic Maintenance--Ignition switch
Ford Taurus Wiring Solution Cheap
Basic Maintenance - Headlight switch inspection/replacement
Dual battery and High Amp alternator write-up
E Rock's Sanden On Board Air (OBA) Write-Up
York On Board Air (OBA) In A 4.2 W/Serp Belt Write-Up
Replacing Capacitors in a 2.5L ECU, A Crash Course In Brain Surgery
OFFROAD LIGHT wiring, dual purpose How-To
Taurus Electric Fan Install, Write-Up
Home Brew Speaker Pods
Dash speaker install
Polk Dash Speaker install, write-up
Custom Wrangler Sound System Write-Up and Install
Radio Delete plate/Double switch panel install
Custom center dash switch setup/headlight switch relocation.
LED Dash Lights, Write-Up
Home Brew YJ switch panel
LED Tail Lights. Write-Up/Install W/Pics
4" LED Tail Light Install, write up
LED Side marker light write up
Head light relay mod write up with pics...WOW what a difference
rustywrangler 11-03-2009 06:33 AM
Heating and A/C:
Chevy blower motor install
This is replacing your stock blower motor with one from a Blazer (about 15 bucks new) for appx 5x airflow
*note on blazer motor upgrade
Heater Upgrade
Heater upgrade (amazing)
Heats kinda blaa....
Sentinal's Heat Deflectors
I put these in every YJ I've had, best heat mod ever, with or without the Blazer motor upgrade. Not sure if he's still making them though
Better Heat in a YJ!
Heat in a YJ
dash air vents
Heater/vent vacuum connections to get flaps opening / closing correctly
Top thread in progress on how the vac system can open, close the right flaps, producing more airflow
My heater blower puts out more air when not running, here's why
Defrost ductwork hose install
heater gone dead
heat doesnt seem warm enough
Heater Control
More airflow using hood scoop on cowl vent
Hood scoops worth the money?
Hard and Soft top insulating ideas and write ups
Soft or Hard top insulator
Cheap soft top padding replacement
Hard Top Headliner
Hardtop Headliner??
Hard top heat insulation. I need some hint for a friend please
Hard Top Insulation
Additional aux heaters for rear seats and supplimental heat
anyone use this heater?
Electric heater?
Thermostat, Waterpump, Coolant, Heater Core related info to get max heat
No Heat
Fusible Link?
Temperature gauge
Jeep still over heating even after head job
2.5 YJ overheating
Heater
Wrangler has poor heat and runs cool
heater gone dead
Heater Core
Cracking windows in butal cold temps
Damn cold weather!
Frost on Plastic Windows
Trans issues in the cold
need help please (manual tranny shifting difficult when cold)
Jeep troubles continue... shifting
cold weather, stuck in gear
Jeep hates the winter
shifting in winter
Extreme Cold Weather
Shrinking top, snow care for soft top
Cheap wal-mart remedy for a prop top?
Snow on soft-top
ice/snow + Soft Top
Softtop & winter
first cold weather with jeep - question?
Rear defroster wiring
wiring needed for rear defroster
95 Wrangler Rear Defroster?
Hardtop wiring
rear defroster
light and defroster on hardtop
Windshield thawing without cracking it when cold
Are my wife and I so ugly we crack glass?
Unlimited Back Window exploded
Defroster breaks windshield
Hard starting in the cold
hard to start when she sits for a day
Cold Start Turned Into No Start...Problem Resolved...Lesson Learned...
rustywrangler 11-12-2009 04:11 PM
IF YOU DID NOT FIND THE WRITE-UP YOU ARE LOOKING FOR, WHY NOT REQUEST A WRITE-UP ABOUT WHAT YOU NEED: Link to location where you can do just that
rustywrangler 10-07-2010 12:00 PM
Added a few more links. Looking for anyone with an exhaust write up at all.
The time now is 12:07 PM.
Resources saved on this page: MySQL 0.96%
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2017 DragonByte Technologies Ltd.
