YJ Frame Rail Size 2"x4" 2.5"x4"? - JeepForum.com
post #1 of 6 Old 09-16-2011, 11:44 AM Thread Starter
kcaverly
Hey,
Hoping to pick up some steel on my way home from work but I forgot to measure before leaving home.
What size are the two main frame rails in the YJ? 2"x4" or 2.5"x4" or ...?
Thanks,
Kevin
1993 Jeep YJ - 350 Chevy TBI, SM465, NP241, 14B SF LSD, 10B
kcaverly is offline
post #2 of 6 Old 09-16-2011, 12:55 PM
Joe Dillard
Electric Chair Operator
Joe Dillard's Avatar
2.5" x 4"
Joe Dillard is offline
post #3 of 6 Old 09-16-2011, 01:30 PM Thread Starter
kcaverly
Right you are. Grabbed some steel and just got my frame back from sandblasting. Actually was very pleasantly surprised at how solid the frame is. It's a great start, and once I reinforce it, it'll be even better.
Thanks,
Kevin
kcaverly is offline
post #4 of 6 Old 09-16-2011, 06:53 PM
Copperhead89
Thanks,
Kevin
Just out of curiosity, how much are you being charged for sandblasting your frame? I'm going to get my frame blasted in a few weeks, and a local shop quoted me $250.
Copperhead89 is offline
post #5 of 6 Old 09-16-2011, 07:45 PM Thread Starter
kcaverly
That's pretty much what I was quoted. I was told $115/hour and it would take 2-2 1/2 hours.
It ended up being 226$ all in including taxes and everything. I think it's worth it. Now I'm ready to weld and I can clearly see what I'm working with.
Kevin
kcaverly is offline
post #6 of 6 Old 09-17-2011, 02:57 AM
Copperhead89
Kevin
Thanks. Those are the exact reasons why I'm sending mine out for a good blasting, to have clean surfaces to work with.
tires size? Will 35x12.50 fit TJ with 2.5" SL, 1.25" BL, and 1.5" wheel spacers crusaderstar TJ Wrangler Technical Forum 1 05-07-2011 05:40 PM
Dealer says "dirty throttle body" and needs "to flush/clean the injectors"..... WheelinTJ2004 TJ Wrangler Technical Forum 18 05-17-2010 11:54 AM
Plastic Soft Top Rail "stoppers" mogrefy YJ Wrangler Technical Forum 1 10-19-2004 09:14 AM
Can't locate "Switched" and "unswitched" wire leads behind the glove box on 04 TJ Sparty TJ Wrangler Technical Forum 4 04-03-2004 01:24 PM
