Yj frame & mount swaps - Page 3 - JeepForum.com
post #31 of 68 Old 05-21-2015, 09:56 AM Thread Starter
OrbisofVita
I do have a cherry picker that I can use to pull out the engine and trans and to even take the tub off if needed but these are the photos of the major crack I'm dealing with no one around me would mess around with it so I was left with limited options. I'm now thinking I might just buy a project Jeep or a TJ project jeep and just finish the project one after I coat it to keep it from rusting. Gotta love the rust belt. Also you can tell by the bottom of the frame majority of it was crappy welding too, theirs hand size rust holes in the rear driver side too.
OrbisofVita is offline
post #32 of 68 Old 05-21-2015, 10:11 AM Thread Starter
OrbisofVita
Originally Posted by ckruzer View Post
Here is this in ann arbor. Why not get this and then sell the axles? make back maybe 500. Craiglist Post
And here is this one in Grand Rapids. Needs some welding, but that is the easy and fun part. Craigslist Post
Another Grand Rapids one for only 400 bones. Craigslist Post
Keep shopping man
Thanks for that man I saw the one for 850 but then I saw these that I wanted to look into
The red CJ for 700
http://detroit.craigslist.org/mcb/tag/4991596375.html
The Gun Metal Blue TJ $950
http://detroit.craigslist.org/wyn/cto/5029964779.html
1990 White Wrangler $1000
http://detroit.craigslist.org/mcb/cto/5017661182.html
1994 White Wrangler Running 1100
http://detroit.craigslist.org/okl/cto/5033417822.html
93 Rust bucket shaky on
http://detroit.craigslist.org/wyn/cto/5033203623.html
Or the 97 Jeep TJ/YJ hybrid Project Id ask 700 for just because imma need new everything in the front
http://detroit.craigslist.org/wyn/cto/5019635121.html
I know now this is alot of work to ask to help me choose for me but Im undecided and I dont want to screw myself over guys.
post #33 of 68 Old 05-21-2015, 10:18 AM
Shadownwpa
I wouldn't try fixing the one you posted the pictures of... can only imagine how bad it is in the normal trouble spots. Is your tub in good condition?
http://www.jeepforum.com/forum/f22/shadownwpa-91ish-yj-build-thread-1857154/
Shadownwpa is offline
post #34 of 68 Old 05-21-2015, 10:37 AM Thread Starter
OrbisofVita
Thanks for your input Shadow what do you think about the CL posts do you think trying to fix that 02 TJ would be good? and my tubs sitting in pretty good condition from the looks just a crack on the driver side in the door crease it has cracked the tub on the driver side and one crack by the rear passenger corner.
post #35 of 68 Old 05-21-2015, 11:34 AM
HaskiE
(is your jeep made of limestone?? what's with all the cracks? no rot?? )
What's scary about that is how thick the metal is at the crack. You had to have applied some serious amount of force to crack it like that, or it's just really soft right there, doesn't look it though.
you can test for frame softspots by whacking it with a hammer or stabbing it with a drift or a screw driver, should get a nice 'ping' not a crunch/poke thru/etc.
I'm guessing this jeep was just like mine, had the freakin crap kicked out of it for years and years and the suspension is completely shot? (or ridiculously stiff) then a highway pot hole at speed? you're lucky it didn't flip the jeep!
I'd still think about fixing it, although the jeep may never be perfectly square again, it'll be more square than that abomination you almost bought!!
lets see the rest of the frame!
#theneverendingaxe
HaskiE is offline
post #36 of 68 Old 05-21-2015, 11:42 AM Thread Starter
OrbisofVita
Lol Michigan roads are terrible. The suspension might be shot and that might have done it because theirs no rock crawlin around me to be doing. But, I'll have to get you photos later tonight my jeeps at my other house and I won't be able to get over there til later but i'll be sure to upload some photos but do you think buying a project Jeep could be a possibility HaskiE? I only ask because by the time I buy another welder and all the materials for the frame patching i'd be spending about the same as one of the project Jeeps.
post #37 of 68 Old 05-21-2015, 11:49 AM
Shadownwpa
My phone is kinda screwed up at the moment, haven't looked at the links. If you haven't already I'd really go over the tub and see if its worth saving, take a screwdriver and a hammer. Pull all the carpet, flares, armor, scrape any rust bubbles, etc... only picking the scabs will tell.
I pulled my tub off to fix the frame, found alot more areas with the tub off... fixed those, then found the tub to be too big of a pile of crap to put back on so I replaced it too. I dont regret any of it, but I would suggest you make sure you get the parts you need on whichever donor/ replacement you choose.
post #38 of 68 Old 05-21-2015, 11:51 AM
Shadownwpa
Either way you're eventually gonna need a welder... or money to pay one to do your work.
post #39 of 68 Old 05-21-2015, 01:43 PM Thread Starter
OrbisofVita
You're right and I ripped out all my carpet to prep for lining it and I can see what all is bad on the inside on the outside its more just rust bleeding through the paint and those bubbles were from the crack. That being said, I guess using parts of the tub from the donor will help one of the white project YJ Jeeps tub looks immaculate how do I inspect to see this is true when I go to purchase this donor? Any tips or anything for me to look out for? I really appreciate you and HaskiE's help and wisdom lol.
post #40 of 68 Old 05-21-2015, 03:27 PM
Shadownwpa
Just decide how much rust you're willing to fix before you buy it.
post #41 of 68 Old 05-21-2015, 05:31 PM
HaskiE
listen to yourself, you've already got a project jeep and you're going to buy another one?????
use your money to fix your jeep. buy a used frame if you need to... if you need tools buy them first, when you're broke you'll be surprised what you can fab up from scrap, or what you can repair - just takes will power & time.
Heck, people build these things from catalogs...
you could start saving your pennies and get a brandy new frame:
http://www.throttledownkustoms.com/jeepFrames/yj
I wanna say I've heard of people ordering just frame rails and doing the cross members & mounts themselves to save some money - What you feel you're capable of is what you should do. If you trust your welds and want the glory of saying you did it, then get a welder and have at it.
You know your budget, space/tools, time table and capabilities. Don't lie to yourself! is this a dream??
#theneverendingaxe
HaskiE is offline
post #42 of 68 Old 05-21-2015, 06:50 PM Thread Starter
OrbisofVita
I would love to weld it myself but I feel the backlash from my peers deeming the jeep a "Death Trap" would prevent me from being able to do so. HaskiE do you think I should just cut off the bad chunks of the frame and buy replacement sections? and man I would love to start saving my pennies for a frame like that.
post #43 of 68 Old 05-22-2015, 02:22 AM
cKruzer
cKruzer's Avatar
1987 YJ Wrangler
I typed a nice reply for you and JF goes and 404s on my post. Oh well. Like Haskie said. Why buy a whole another pile? That ad for the 400 bone frame is awesome priced. The best looking one had those 10 bolts and you dont want those. That TJ - TJ tubs do not line up with YJ front. The whole body is different from the YJ era to the TJ. Prob why the guy is selling it, and you can see the front is not bolted in.
1987 YJ - Aka; SpeedBump.
Target: 5.3L; AX15; NP231; D44/D60; 4.88s; 36s
הָיָה הָיָה הָיָה
YJOTM AUG '17
cKruzer is offline
post #44 of 68 Old 05-22-2015, 02:27 AM
cKruzer
cKruzer's Avatar
1987 YJ Wrangler
Well then your peers can suck it. Often, the apparent negative comment of others is from ignorance. Usually those with knowledge know how hard it was to obtain, and would not ever be so negative with someone attempting to gain that knowledge.
There is no engineering involved if you mod a existing frame. If you build your own, you better know about crumple zones, fold points, etc.
Build from the ground up. its exhilarating. Shoot, you could even mod a YJ frame, and stick a TJ body on it!!!!
Lots of people on here have turned JEEP into a religion. If you become a asker of questions, and spearhead your way into new understandings - you will always have zealots who dub you a "blasphemer".
הָיָה הָיָה הָיָה
YJOTM AUG '17
cKruzer is offline
post #45 of 68 Old 05-22-2015, 07:39 AM Thread Starter
OrbisofVita
Lol, I like your thinking. What do you suggest then? just welding it all around and then fishplate every side? Would I want to use an arch welder for this or a mig? That frame for 400 looks killer! I didn't even see that!
frame swap , help needed , jeep yj , lift help , shock mount
