yj frame is it 4 or 6 - JeepForum.com
post #1 of 5 Old 04-17-2010, 07:56 PM Thread Starter
mcintry
1987 YJ Wrangler
i searched in google and i searched in a couple different forums and i cant find what i am looking for
i bought a new frame for my yj and the guy i bought it from couldn't tell me what kinda engine it had on it my yj has a 6 how can i tell if this frame was for a 4 or a 6 i looked at mine and it seems like the mounts are in the same place, any info would be greatly appreciated
mcintry is offline
post #2 of 5 Old 04-17-2010, 08:14 PM
RedlineRyan
im pretty sure the frame is the same
RedlineRyan is offline
post #3 of 5 Old 04-17-2010, 08:27 PM
MoparFreak69
The frame is the same, the only difference is the placement of the motor mounts. The four bangers sit farther back than the sixes. I dont know the measurements at this time but can take some off my four in a bit if needed. If the new one looks like your old one you should be just fine.
90 YJ 5.2 Magnum, AX-15, 231 SYE'd
D44 front, welded/trussed AMC20HD rear. 4.56 gears soonish.
Western 6 lug aluminum wheels, with 35x12.50x15 Wrangler MTRs
MoparFreak69 is offline
post #4 of 5 Old 04-17-2010, 09:22 PM Thread Starter
mcintry
1987 YJ Wrangler
i would really like to know the placement of the 4 bangers, and is it an obvious difference and i knew the frame it self was the same my questioning was on the motor mount brackets
mcintry is offline
post #5 of 5 Old 04-17-2010, 10:33 PM
87YJBill
1987 YJ Wrangler
the 6 cyl mounts are approx. 34 inches back from the front of the frame horn to the center of the mount.
87YJBill is offline
Frame-frame distance RockScar TJ Wrangler Technical Forum 2 03-05-2010 06:41 PM
bestop frame better than stock soft top frame? goose142004 YJ Wrangler Technical Forum 10 11-24-2009 12:34 PM
rigid frame or flexible frame blackcat471 TJ Wrangler Technical Forum 8 08-12-2009 02:18 AM
swap wrangler frame with cj7 frame midgetdog YJ Wrangler Technical Forum 7 04-15-2009 10:58 AM
How diff is TJ windshield frame and YJ frame? darioc YJ Wrangler Technical Forum 6 02-09-2008 04:30 PM
