YJ Extended Brake lines - JeepForum.com
post #1 of 21 Old 02-24-2010, 04:08 PM Thread Starter
mntbkrguy
I know this topic has been beet to death but..... after an hour or more of searching I am not finding the exact answer to my question.
I see many times over that the front brake lines from a Chevy C1500 truck and are longer than a TJ's and XJ's, and that a Dodge Dakota's rear lines are longer than that of a TJ and an XJ. I also see that the front and rear lines on a YJ are longer than both.
But what lines are longer than a YJ????? It looks as though the Chevy ones are a little longer, 2" maybe.
What is a good alternative to spending a fortune on stainless lines that are bound to break like the ones I have seen on the trail?
If there is a thread on this please direct me.
Mntbkrguy
1994 YJ 4.0
8.8 rear, 35's
mntbkrguy is offline
post #2 of 21 Old 02-24-2010, 06:40 PM
timatoe
timatoe's Avatar
I asked this a long time ago, and was told there were some Ford lines available (maybe 80's model F250's, don't remember), anyhow, I just ended up ordering a set from 4WD. You can get the same set cheaper through Summit though.... Russell Performance 695940 - Russell Street Legal Brake Line Kits - Overview - SummitRacing.com
You might also check and see if there's a truck hydraulic shop near you. I went to one by me and could've got a set made up for less than half the cost of what I paid, but they ticked me off, so I took my money elsewhere.
timatoe is online now
post #3 of 21 Old 02-24-2010, 06:51 PM
Louie4
"You pass butter"
Louie4's Avatar
I just got the Russel kit today. Going to put it on this Sunday. I'll have to check back in to see how they do. As long as they don't break when I push the pedal in, I think I'm good.
Lou
YJOTM July 2012
YJOTM February 2014
Louie4 is offline
post #4 of 21 Old 02-24-2010, 08:50 PM
ritjobbie
IMO, don't buy Goodridge lines. I've had two _pairs_ fail over the last year. Boo. They look nice and seem to be solid, but all of the ones I've had (except what's on my Jeep now) have sprung leaks near the top fitting. I don't have enough flex to tug on the lines.
1995 YJ Rio Grande, 2.5L Low Output Engine
ritjobbie is offline
post #5 of 21 Old 02-24-2010, 08:55 PM
YJ Ynot
You can have ss ones made for about $35 each
TOMMY
1994 YJ
4inch Suspension Lift, 35x15x14,2.5
I'll stop procrastinating tomorrow...
YJ Ynot is offline
post #6 of 21 Old 02-24-2010, 10:11 PM
timatoe
timatoe's Avatar
I haven't had any issues with the Russel ones.
I don't think that's gonna save him any money, a kit's cheaper.
post #7 of 21 Old 02-25-2010, 12:05 PM Thread Starter
mntbkrguy
I am going to see if I can get a helpful parts person to help me compare (I know good luck) but there is a Jeep guy at the local advance that may not mind taking the time. My brake lines are not being stretched but they are not in the best of shape so I figured why not replace them and upgrade since I am already going to bleed the whole system. Thanks for the F-250 info I will look into that.
Mntbkrguy
1994 YJ 4.0
8.8 rear, 35's
post #8 of 21 Old 02-25-2010, 01:03 PM
instg8tor
I posted this in the other brake thread...
try this NAPA part number 38622 - it's 27"s
'91 Renegade - Waggy 44/20 (F/R Aussie) SOA, E350 MC, York OBA, Custom F/R bumpers
instg8tor is offline
post #9 of 21 Old 02-25-2010, 03:56 PM Thread Starter
mntbkrguy
is that napa part for the front?
Mntbkrguy
1994 YJ 4.0
8.8 rear, 35's
post #10 of 21 Old 02-25-2010, 04:03 PM
instg8tor
It is, but the rear from the same truck is what I used. I'll try and find the part number
post #11 of 21 Old 02-25-2010, 04:59 PM Thread Starter
mntbkrguy
Thanks, your part number helped a lot! I did some searching with that number and found this page http://www.grobe.us/Jeep/Tech/Drivet...BrakeHoses.htm
It gives many examples but all are front hoses.
I used that and dug some more on Napa's site and found some info for the rear.
The rear hose from a 1990 Dodge Ram 1500-3500 NAPA part #UP38744 looks to be a match and is 26.25" $35
The rear hose from a 1995 Dodge Dakota NAPA Part #UP38636 also looks to be a match and is 22.125" $30
The rear stock hose for a YJ is 17" and $17
I decided I am going w/ the Dakota rear and the 1990 Chevy 1500 which are both about 5" longer than stock
The one mentioned in the post above part#38622 is from a suburban and is $8 more and not any longer.
I appreciate the help maybe this can help others.
Mntbkrguy
1994 YJ 4.0
8.8 rear, 35's
post #12 of 21 Old 11-14-2011, 02:21 PM
amigogq
1987 YJ Wrangler
This really has helped me and I know its been some time. How did the rear Extended Brake lines (1995 Dodge Dakota NAPA Part #UP38636 ) work? Thank you for sharing!
amigogq is offline
post #13 of 21 Old 11-14-2011, 04:15 PM
Hard_oNe
I agree, a follow up to your decision is what is missing from this great topic. I'm in the market for either a hard-line extender or just longer brake lines.
+1
Hard_oNe is offline
post #14 of 21 Old 11-14-2011, 05:52 PM
4.7stroker
I gained about 6 " of extra flex line by removing the torx bolt that holds the hard line to the frame and pulling the hard line through giving it a little bend and re bolting it to the shock tower so the soft line is pointing straight down.
Sorry for the run on sentence.
Cost $0 brake bleeding 0 cool factor 0 got the job done fast priceless.
Dwayne
[url]
Prevent Flat Tappet Cam Failure.
[url]
4.7stroker is offline
post #15 of 21 Old 11-16-2011, 06:56 AM
amigogq
1987 YJ Wrangler
4.7stroker thats what I had to do ment.after soa.. But the rear I am afraid wont last with flexing n front lines look like they need replacement. So I would like to get newer extended ones.
amigogq is offline
Extended brake lines. vosevichs TJ Wrangler Technical Forum 14 01-25-2010 07:40 PM
Extended brake lines,what about abs? jeep2008 TJ Wrangler Technical Forum 2 11-30-2009 06:13 PM
Extended brake lines ninemili22TJ TJ Wrangler Technical Forum 2 12-15-2008 08:37 AM
Extended Brake Lines JeepPirate TJ Wrangler Technical Forum 13 12-27-2007 08:35 PM
extended brake lines shinigami YJ Wrangler Technical Forum 6 07-05-2007 11:26 AM
