YJ Experts Help. It is grinding going into gear. - JeepForum.com
post #1 of 10 Old 09-27-2011, 08:25 PM Thread Starter
target4fun
I have a 91 wrangler 5 speed 6 cyl and about a month ago I changed out the clutch master cylinder and bled it and it worked fine until now. All of a sudden it started grinding going into all gears so i checked master cylinder... it was low so i added fluid and bleed the clutch better as it would let me into gear but would still grind. When i am stopped it will go into every gear fine no problem ... I always start in 2nd and it doesn't grind at all but when the jeep gets going I try to shift to third gear and it grinds unless i pump the clutch then it goes in fine no problem. This makes me think the clutch master is out? It isn't leaking so don't think it is the slave.
Any help would be greatly appreciated.
target4fun is offline
post #2 of 10 Old 09-28-2011, 10:49 AM Thread Starter
target4fun
Anyone?
post #3 of 10 Old 09-28-2011, 11:38 AM
Louie4
I would change the fluid in the transmission if you haven't done so yet and be sure to check for glitter. Then I would check the fluid level in the clutch master cylinder. If it's already a little low maybe it's leaking?
You also might want to consider the hydraulic throwout bearing. It could be leaking as well.
Lou
YJOTM July 2012
YJOTM February 2014
Louie4 is offline
post #4 of 10 Old 09-28-2011, 12:45 PM Thread Starter
target4fun
Last night I changed the tranny fluid. That didnt seem to fix it. I have not checked the hydraulic throwout bearing. Its just weird that when the jeep is going its hard to put into gear and grinding. When stopped it goes into all gears no problem i start off in 2nd (no grind) then once moving it will grind on each gear unless i pump the clutch.
Im going to do research to find and check the hydraulic throwout bearing. If thats it only think I could think would be the Clutch master is defective or weak.
post #5 of 10 Old 09-28-2011, 02:44 PM
Louie4
If your hydraulic system is solid and you're having trouble shifting into gear while moving it sounds like your syncro's are bad. They allow the different gears spinning at different speeds to sync up when shifting.
Lou
YJOTM July 2012
YJOTM February 2014
Louie4 is offline
post #6 of 10 Old 10-03-2011, 11:48 AM
ROKNDJ
I think I may have the same trouble. I get a slight grind going into third.
Is replacing the syncro's an expensive repair. I have abuddy who owns a repair shop who treats me well. I just want to be sure what I'm getting myself into. Not sure if this means a whole clutch replacement or what. I want to get out of this as cheap as possible.
ROKNDJ is offline
post #7 of 10 Old 10-03-2011, 11:59 AM
Spuznick242
Why go through all that work to just figure out the problem? Go to a trans shop and let the experts diagnose the problem, they will be able to know if you need a rebuild, just a flush, a better bleed, or something else that no one on here would be able to think of because of your problem. My family owns a trans shop, usually the people are good and will diagnose it with just a test drive but I only have experience with my trans shop. Changing the fluid or doing anything else for that matter is pointless because the problem could be much worst and it might just throw the work and money you did right out the window. Get it diagnosed right and then throw money at the real problem instead of throwing money at something that MIGHT be the problem.
DD- 1995 YJ 2.5L, Cat delete, 19lb injectors, 30/9.5r15
Trail Rig- 1994 YJ 4.0L, Rubicon Express 4.5inch lift, 1inch body, D30 Aussie, 33/12.5/r15 Cooper Mud Terrains, front bumper, rocker guards
Spuznick242 is offline
post #8 of 10 Old 10-03-2011, 12:53 PM
moonshinefuel
If you are pumping the clutch, and then it works fine, its your master, slave, or air in the lines.
AX5/NV3550 Conversion Thread.
Bow Hunting
moonshinefuel is offline
post #9 of 10 Old 10-03-2011, 01:33 PM
moonshinefuel
Unless.. say if the clutch is good, then while moving from gear to gear while driving, you are experiencing grinding, but, by pumping the clutch, you are slowing the rotation down, allowing it to go into gear easier due to bad syncros. That's about the only other thing I could think of really. Maybe it would explain why it goes in good at a stop.
Bow Hunting
post #10 of 10 Old 10-03-2011, 01:56 PM
jhumphrey
It could be a couple of things...some minor, others major. I agree with Spuz, take it to a tranny shop to see what it is. If you dont want to go that route, look under your dash where the top of the clutch pedal attaches to the master cylinder. If its leaking there, you have a bad master...replace.
Your slave could be leaking. I dont know if 91's had an external or internal slave. My 89 has an internal (PITA!) and if the slave is leaking, its hard to catch. The only thing you could do there is pop the dust cover and stick your finger in...if its dry, thats a good sign. But, thats not the best method of eliminating. The problem could also be your clutch itself. If the clutch is worn out, it may not be engaging right and causing the grind. I had an issue with mine "shuddering" on takeoff. I changed my master cylinder and had the shop put in a new clutch (that came with a new slave). After I got it back, problem solved.
Worst case is its the syncros. If they are toast, youre looking at some cash to fix it. My first bet is that either your slave or clutch is going/gone out. Have a shop inspect it and report back....
jhumphrey is offline
gear ratio experts needed..? QCDoc TJ Wrangler Technical Forum 7 07-07-2011 08:55 PM
RP Syncromax, 3rd Gear Grinding In Gear 242TJ TJ Wrangler Technical Forum 8 10-25-2009 01:06 PM
gear experts help cmc1 TJ Wrangler Technical Forum 3 05-25-2008 08:25 AM
gear grinding LIVE2SURFAZ TJ Wrangler Technical Forum 3 01-09-2006 10:36 AM
OK Gear experts...I didnt know this!!! numnuts TJ Wrangler Technical Forum 3 01-03-2006 12:42 PM
