YJ Engine swap - JeepForum.com
post #1 of 17 Old 01-18-2012, 10:51 PM Thread Starter
MrBlah
YJ Engine swap
So, my buddy has a '90 YJ with the lowly and weak 4 cylinder engine. I'm tired of hearing him doing 25mph up I-70 to the Eisenhower Tunnel, so I want to replace his engine. I am looking at either a 4.0L I6 from maybe a Cherokee or a small block chevy or small block ford. Also looking at a 403 olds.
We can both weld so replacing engine mounts isn't an issue.
First, what do you guys suggest? What is easier to do? Will a 4.0L I6 from say an 89 Cherokee bolt on and fit as a direct replacement(therefore maintaining the original transmission)? Anything I do will be purchasing a core or long block and rebuilding, so performance isn't an issue with the replacement. I am more interested in the actual act of doing the swap, and want to do the least moving of other parts, like the transmission and transfer case.
MrBlah is offline
post #2 of 17 Old 01-18-2012, 10:53 PM
Ripper3494
anything larger than the 4 cyl will destroy that tranny, really they're all about the same difficulty when you get down to it, id say the best balance between work and outcome would be doin a 350 sbc
build thread:
1997 ZJ limited - BONE stock
RC vs BDS
Ripper3494 is offline
post #3 of 17 Old 01-18-2012, 11:10 PM
Plato2k5
if you go other than chevy, you will spend a lot of money. I did a mopar 360 swap and it cost tons more than going chevy.... but I love saying "**** no!" to the question of "oh does that have a 350 in it?"
I like being the odd one with a non chevy engine. However, if I did another v8 swap or buggy build, I would go Ls1 or other LS series engines. Can't beat the power to cost.
I've spent a lot of money on building power with my mopar. Could of been half the cost with a chevy...but i'm happy
the trans for the chevy are cheap and you can do an OD auto very cheapy and easily, not to mention EFI
Plato2k5 is offline
post #4 of 17 Old 01-18-2012, 11:20 PM Thread Starter
MrBlah
Well, my goal is keep try and keep it under $1000, so we'll see how that goes.
Would a 4.0L swap with a 5 speed that was designed for a 4.0L be a good choice? I know it's easy to spend just $1000 on a 350 which would leave me not much room left over for a 5 speed transmission.
MrBlah is offline
post #5 of 17 Old 01-18-2012, 11:23 PM
Ripper3494
you wont stay under 1000 bucks. not a chance lol, between engine mounts, engine, transmission, t case, shifters, linkages, cooling, wiring harness, pcm, gauges, fuel system, intake, drive shaft modifications. going from a 4 cyl to anything else will include at minimum all of this
build thread:
RC vs BDS
post #6 of 17 Old 01-18-2012, 11:28 PM Thread Starter
MrBlah
If he has an AX-15 and NP-231, why should I need to change them?
I understand the need for new engine mounts, fuel system ,intake, exhaust, and cooling, but I guess my inexperience with doing an engine swap now comes into play.
MrBlah is offline
post #7 of 17 Old 01-18-2012, 11:43 PM
Ripper3494
the 4cyl engine comes with the ax-5 trans which is literally the weakest trans on earth, ask me how i know, and the 231 that is behind that is weaker than the normal 231. there are 2 kinds of 231s, one kind is behind the 4 cyl and that has 21 splines, and there is one that comes behind the 6cyl which has 23 splines, from my experience the 23 splined case is far stronger than the 21
build thread:
RC vs BDS
post #8 of 17 Old 01-19-2012, 02:11 PM
bmgadg
Going from a 4cyl to anything else means replacing the trans and transfer case, no way around it.
Chevy swaps aren't always cheaper either. An ax-15 will bolt up to a mopar v8 without any special adapters, just a junkyard bellhousing. For someone going from a 4.0 to v8, I don't see how a chevy swap could possibly be cheaper than a mopar swap.
bmgadg is offline
post #9 of 17 Old 01-19-2012, 04:06 PM
oteps
1980 CJ5
I did my 4.0 swap for a lot less than $1000. I bought a running xj for $600. Pulled the engine and tranny, sold the rest. Sold the yj 4 cylinder and ax5. Some 231's mated to an ax5 are 23 splines. You can use the 4 cylinder rad, and you can make the 6 cly fuel pump work in your tank. For driveshafts, you can use stock yj 6 cly shafts. I put an auto in mine so they were different.
It all depends if you can do the work yourself and how much you can get another engine and tranny for.
oteps is offline
post #10 of 17 Old 01-19-2012, 05:37 PM
attentionwhore
^^^what he said
I picked up my 4.0 motor, trans, transfer case, harness, ecu, both driveshafts for $500 for a guy at work. Once I sell the 4 cyl parts I should be up some money, not much....but some. Just keep your eyes open for deals, they ARE out there.
attentionwhore is offline
post #11 of 17 Old 01-19-2012, 11:24 PM
Ripper3494
i guess i just ran into more issues than you guys did,
1000 for the 6.0
900 for fully built 4l60e
free t case
500 d shafts
200 radiator
300 linkages
100 engine mounts
200 DOM tubing to make crossmembers and wrap bar (yes even with sua)
400 for dana 44 front and rear
700 exhaust system
150 wiring harness and pcm
it can be done cheaper yes, but doing things right usually tends to be slightly more expensive. i didnt say chevy swaps were the cheapest, i just said i think they were the best balance between price, work and outcome performance
take whatever you plan to spend and add 1/3 is what everyone always told me. very rarely do things work flawlessly, there will be problems and usually problems cost money
build thread:
RC vs BDS
post #12 of 17 Old 01-23-2012, 12:32 PM
bmgadg
Words of wisdom. There are a ton of little things that you never think about.
bmgadg is offline
post #13 of 17 Old 01-23-2012, 08:58 PM
dodger889
This is what I did I found a xj that was in bad shape body wise. Use the complete drivetrain 92 4.0 and wiring from it. Yes including TC. Installed and SYE kit. Used the front driveshaft from the xj had it re-sized to fit for the YJ rear shaft. Since you have a fuel pump in the tank already that will work. There should be no reason to rebuild the motor unless it is well past the 150k mile mark or it has some strange sounds. You may just replace the bearings and change the oil pump. Now I did change the water pump to a yj style pump. That was so I could still use a stock fan setup. depend on what year the YJ is and if it is cable driven speedo you might need and cable with electronic speedo unit. Here is something to since it is a 4 banger then you will have more than likely 4.10 gears which will give him all the gearing he should need unless again he has 33 or larger tires. Now I know what I spent doing my swap was close to about 1500. You could get by with a little less or more depending on what it cost for getting XJ for and what you can recover back out of the left over parts.
A 89 yj with a 4.0 aw4 sye out of an 92xj. Now the hard part is done time to get it up in the air just a bit. Working on 8.8 with 3.73 and lsd for the rear. and new D30 hp with 3.73 .
For those who have not figured this out I'm old school but can handle the new too.
Originally Posted by bigsquat View Post
im just cheap, and cheap makes you creative.
dodger889 is offline
post #14 of 17 Old 01-23-2012, 09:01 PM
czjeeper
My Dodge 5.2 swap wasn't terribly expensive.
Dakota bellhousing to the AX15/231 was $50 from the junk yard. Conversion radiator was about $200 from Oconee. Novak mounts about $150. Dodge 5.2 clutch kit at the parts store. $400 for complete 5.2/harness/PCM.
Also, all the gauges work w/the Dodge powertrain.
The rest was just hard work for the most part.
US Army combat vet
2011 Grand Cherokee Laredo 3.6
Armed Forces Jeeps Member #125
Red Jeep Club Member #251
In the Portland/Vancouver area? Check 'em out!
czjeeper is offline
post #15 of 17 Old 05-22-2015, 07:44 PM
Jbanks
2.5 to 258CID engine mounts?
I have a 90 YJ bad motor and trany. I have a 6 cly out of a 76 cj (258 cid) motor, trany and transfer case, Need advise on engine mounts to install it in the YJ
Jbanks is offline
Auto to manual swap, and engine swap JacKedUP4x4 TJ Wrangler Technical Forum 1 07-03-2011 08:09 AM
My Jeep ate its engine ! - need advice on engine swap... ymibuyingmore YJ Wrangler Technical Forum 5 05-03-2011 04:31 PM
Another 4.0 Swap question...head swap vs. full engine swap Mol YJ Wrangler Technical Forum 11 10-18-2010 05:11 AM
1984 CJ7 6 cyl 258 engine swap into 1988 wrangler with 6cyl 258 engine? xavier27 YJ Wrangler Technical Forum 0 07-29-2010 03:08 PM
