YJ Engine Issue - JeepForum.com
post #1 of 6 Old 08-11-2011, 11:39 AM Thread Starter
mbgencon
YJ Engine Issue
This is a strange problem that I can't seem to fix. When I am driving for about 45min to an hour, if i give the engine any more than 1/4 throttle it will hesitate, sputter, backfire, etc. It does not do this under the time stated above. If I turn the engine off for a few seconds then turn it back on, it runs fine for about 10-15min then it acts up all over again. I have changed the fuel filter, throttle position sensor, cap & rotor, plugs, plug wires, and O2 sensor.
Any insight anyone may have is appreciated.
1994 YJ
2.5L
mbgencon is offline
post #2 of 6 Old 08-11-2011, 11:57 AM
Xpress
Could be a few things... Might want to start with your fuel pump...
All about that unibody life.
Xpress is offline
post #3 of 6 Old 08-11-2011, 12:10 PM
Matt24138
Vacuum leaks are also known to open up and close with heat. Check when the issue occurs.
Matt24138 is offline
post #4 of 6 Old 08-11-2011, 12:34 PM
Que89YJ
Welcome to the forum. Start by checking for fault codes:
Read this post:
http://www.jeepforum.com/forum/f12/1...issue-1251610/
Que89YJ is offline
post #5 of 6 Old 08-12-2011, 05:31 PM Thread Starter
mbgencon
Thanks guys, I'll try those.
mbgencon is offline
post #6 of 6 Old 08-12-2011, 05:38 PM
Darold
1994 YJ
2.5L
Check sparkplug gaps, set to .035.
Darold is online now
4.0 Engine Issue clyderains TJ Wrangler Technical Forum 3 07-05-2009 06:44 PM
89 wrangler engine issue link4889 YJ Wrangler Technical Forum 4 05-29-2008 10:38 AM
Engine mount issue... tj7695 YJ Wrangler Technical Forum 7 04-08-2008 10:36 AM
Engine/AC issue 06WranglerX TJ Wrangler Technical Forum 1 07-29-2007 07:51 PM
engine issue? adp5025 TJ Wrangler Technical Forum 9 07-19-2006 09:33 PM
