-   -   YJ Engine compartment MESS (http://www.jeepforum.com/forum/f12/yj-engine-compartment-mess-1540665/)
nwengcarpenter 06-24-2013 08:35 AM
I need some bearings, a general direction. My newly aquired 1987 YJ, although she looked relatively clean at dusk, proved to be a purchase which came with "strings attached". An anxious first look in the light of day delivered one sinking feeling after another. I wonder how long the adjustable wrench has served diligently as a motor mount shim. Where are all the vacuumm lines? That hose clearly doesn't belong there. I imagine this situation, albeit adulterous, is not unique.
Some info:
4.2 L Reman
2bbl Holley carb
Missing vacuum lines
Open vacuumn portm
Chopped wires
Dangling connectors
Tie wraps, tie wraps and did I mention tie wraps?
Could someone provide me with some direction? Where do I start? For now, I'd like to put it back as close to stock as possible.
Thanks
Old4X 06-24-2013 12:09 PM
http://home.sprynet.com/~dale02/list.htm
geusey 06-24-2013 01:04 PM
Got any pics?
roadyrob 06-24-2013 01:11 PM
first you need to figure out what has been done to the jeep. the first clue is the holley carb, not stock. alot of people do carb swaps along with eliminating the stock computer by doing the nutter bypass or changing the distributor. the original emission system is then disabled and most of the stock vacuum lines, etc. can be capped off or removed.
if you post some pics of the engine compartment we should be able to help.
honestly, it sounds like putting it back to stock would be a major job and really not worthwhile as the system was very problematic to begin with.
don't give up hope, the 4.2 actually runs better without all that stuff.
nwengcarpenter 06-24-2013 03:50 PM
Pics
Here are some picture. I am all for disabling, removing and whatnot. I suppose I am just unclear as to what is what.
https://www.dropbox.com/s/ktpqaxuxhm...2019.16.48.jpg
https://www.dropbox.com/s/pcq3haeaic...2019.17.04.jpg
https://www.dropbox.com/s/m7xqw3vv3o...2019.17.08.jpg
https://www.dropbox.com/s/18xftgit28...2019.17.21.jpg
roadyrob 06-24-2013 04:16 PM
okay. most of the emissions have been removed, probably has had the nutter bypass done. here's some threads on it.
https://www.google.com/webhp?source=...w=1360&bih=643
I guess the big question is how does the jeep run? if your happy with that part spend some time reading up on the 4.2 to learn whats needed for every thing to work, its amazing how much can be eliminated. I filled a large trash bag with the stuff I removed.
hopefully all your seeing is the previous owners sloppy work and after straightening every thing up you will have a great running jeep.
the 4.2 has a lot of potential if you like to tinker and modify, heres some threads to get you started.
nwengcarpenter 06-24-2013 04:19 PM
I'm thinking that the pics I posted are most likely not so good. I will get some better, more detailed ones.
Am I right in my assumption that the computer is completely disabled?
I suppose I will have to rework the vacuumm systemfor the remaining components which need lines. Is that correct?
Thanks everyone for all the help thus far!
roadyrob 06-24-2013 04:28 PM
heres some images of the 4.2 vacuum lines, it will give you an idea of what was there originally.
the one in the third row, 4th pic is all thats needed for the motor itself. there are also images for the CAD for the 4 wheel drive.
woops wrong link
roadyrob 06-24-2013 04:39 PM
try this
https://www.google.com/search?hl=en&...mg.S2bf98QNGSU
CBinDC 06-24-2013 04:51 PM
Can I ask why you want to put all the vac lines back? Just curious is all.
nwengcarpenter 06-24-2013 05:12 PM
Thanks again!
After my research here, I DON'T want to put the vacuumm lines back........It just seemed like that might be the best place to start.
It turns out that I have a Holley 350CFM carb. Manual choke at the moment. In this whole process, do any of you have any input as to whether or not I should get the Holley elec choke kit?
dancytron 06-24-2013 06:01 PM
If you can get the vapor canister and egr valve working, it will pollute less and it won't hurt how it runs. Looks like the pcv valve is already hooked up. Make sure it works.
Make there isn't anything sucking vacuum or leaking it.
Give the manual choke a chance. You might like it.
If you look on this page, http://home.sprynet.com/~dale02/control.htm in the third column, it will tell you what you could possibly get to work without the computer. A service manual for a 1979 or so CJ7 might help out some too.
nwengcarpenter 06-24-2013 07:38 PM
Thanks. I appreciate the advice. I'll relocate the choke cable, which was ridiculously run through the center bezel to the left of the heater controls, and give it a go.
I think the evap canister is simply gone. Should be an easy junk yard find.
All of the input thus far has been very helpful. I feel far less intimidated by the task ahead.
nwengcarpenter 06-25-2013 05:02 PM
So.....
I am still struggling to understand all of this. I'll try to explain and hope for any acknowledgement of right or wrong from all.
The vac system mostly controls the emissions system and the related funtion of the carter carb. Mine has a Holley 350 CFM so most of the lines are not needed. I only need vac for the PCV, EGR and the wheel lock motor. The lock motor missing a metal vac connection and needs to be replaced. What should I do? So do I have this right?
nwengcarpenter 06-25-2013 05:04 PM
Also......Do I need the pulse air system?
The time now is 05:06 AM.
