Yj electrical help - JeepForum.com
post #1 of 1 Old 09-22-2013, 07:31 PM Thread Starter
brickonaskate
Yj electrical help
Nutter bypassed motor craft 2150 87 4.2 25,000 miles on a rebuild. Runs great.
Today I got to church and shut her off with the key and the engine stayed running. Not like it was dieseling but I could have kept driving. Stalled it and restarted it just to check if it worked and it still started fine so I went into church. I came out and everything seemed fine. Key turned the starter over fine but it had no spark and would not run. Started by replacing the ignition switch
Then the icm
Then the coil.
Both wires at the coil have power. when you unhook the top price only the positive does. The coil tests right for resistance but as far as I can tell that's as far as the power gets it never leaves the coil going into the wire to the distributer when you try to start it. Any help is greatly appreciated.
I'm thinking power going to the ignition wih the key off could have burned up a relay or in line fuse somewhere
Please help me.
brickonaskate is offline
