Yj Driveline vibration help? - JeepForum.com
post #1 of 2 Old 01-18-2013, 06:38 PM Thread Starter
Radiohead1231
So it started vibrating a couple months ago, dash and everything shakes. Its mainly there from 25-45 mph. After it started i did a motor swap so
It has new motor mounts and trans mounts. A new front right axel ujoint. I also took out the front driveshaft and drove it. Still vibrated. Also got a new(brand used) set of tires mounted and balanced and put on today and its still just as bad. Cant figure it out and its driving me nuts. 4 inch lift with transfer case drop. Had the lift for 2 years without a problem. Rear ujoint looks good to
Me? Any help is appreciated.
Radiohead1231 is offline
post #2 of 2 Old 01-19-2013, 04:36 PM Thread Starter
Radiohead1231
Fixed. Rear shaft trans side ujoint. I heard chipmunks too.
