Quantcast YJ Dovetail Build - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > YJ Dovetail Build
TJ WW2WW rockers on sale with free gaskets this month.DISCOUNT - Chromoly Front Axle Shaft Kits, 87-95 YJ's, 97-JcrOffroad new Crusader TJ/YJ/CJ Bumpers available!!
Old 02-27-2008, 01:06 PM   #1
YJ_Aaron
YJ Dovetail Build
Well it has officially begun.... OJTV8XJ and I have started disassembly of my jeep to dovetail it and in the process its also getting a new paint job , and most likely herculiner sprayed in.
Here is what I have for pics so far... more to come this weekend.
PICS:
Heres the jeep after the basics have been removed
Old Damage that is going to be fixed before hidden with rockers:
Cage we built over the summer getting cut out to be narrowed:
91 YJ rebuild! Rush to get it driving/wheeling.
http://ozarksjeepthing.com/c/index.php
YJ_Aaron is offline   Reply With Quote
Old 02-27-2008, 01:08 PM   #2
YJ_Aaron
Now the custom Brake Lights: (steel to make brake light buckets)
Finally the CJ gate I'm going to use unless I find one in better shape on the cheap:
Old 02-27-2008, 01:30 PM   #3
Pyrate_7
Aaron...I'm loving the taillights, but what do you mean by "dovetailing" your Jeep?
"I was remembering the words of Socrates, when he said, 'I drank what?'." - Val Kilmer
"I do not feel obliged to believe that the same God who has endowed us with sense, reason, and intellect has intended us to forgo their use."
-- Galileo Galilei
Pyrate_7 is offline   Reply With Quote
Old 02-27-2008, 01:34 PM   #4
BlackRhino
Narrowing the rear end.
Black '91 YJ, pretty much stock for now. Finished engine rebuild. Runs beautifully.
BlackRhino is offline   Reply With Quote
Old 02-27-2008, 01:38 PM   #5
YJ_Aaron
I'll be narrowing the rear section of the tub. The sides from the end of the center hoop of the cage to the back of the jeep with angle in. We'll be cutting out 14" from each side were the old brake lights were. Actually I don't remember exactly how much we're cutting out.
I also don't think i'll ever pass another jeep running those tail lights.
Old 02-27-2008, 02:07 PM   #6
Pyrate_7
Cool! Can't wait to see the "After" photos!!
-- Galileo Galilei
Old 02-27-2008, 02:12 PM   #7
doug_1994
Looks good Aaron.
Are you going to stretch it out along with the dovetail?
Doug
Wise men speak because they have something to say;
Fools because they have to say something.
Plato
doug_1994 is offline   Reply With Quote
Old 02-27-2008, 02:20 PM   #8
YJ_Aaron
No, the stretch isn't in the budget just yet. It is one of the "long-term" plans though. Doug you should throw up a pic of yours so those who haven't seen a dove tail before will know kinda where mine is going. I think ours will look diff since mine is getting lots of body work.
Old 02-27-2008, 03:21 PM   #9
sam.b.
dovetails are pretty sweet
cant wait to see it done
98 TJ Mild DD
90 YJ Sold
88 Samurai slowly being built for the rocks
www.kifourwheelers.com << Louisville Ky. based 4x4 club
sam.b. is offline   Reply With Quote
Old 02-27-2008, 04:14 PM   #10
doug_1994
No problem.
And mine is very hack. I can't do bodywork if my life depended on it!
Can't wait to see it done.
Doug
Plato
Old 02-27-2008, 06:51 PM   #11
djcondo
im new to this kind of stuff... is doin this just to get better tire clearance and to avoid hitting things as much?
- Dan
djcondo is offline   Reply With Quote
Old 02-27-2008, 07:10 PM   #12
YJ_Aaron
It has multiple benefits. The body is out of the way so less likely to get damaged on obstacles. It allows for more tire clearance since it gives more room for compression since the body isn't over the tire. When you run very little lift (me 5.5" and 36's) this is necessary if I want much compression.
Truth be told I'm also doing it because no one else around here ever has.
Doug thanks for the pics, we'll see how mine turns out. It should look at least decent we're taking our time. Besides in your case no need for body work isn't yours strictly trail?
Old 02-27-2008, 07:19 PM   #13
djcondo
thats what i thought, thanks
- Dan
Old 02-27-2008, 07:33 PM   #14
doug_1994
Yeah, mine doesn't see any pavement. I think if I put any time into the body, I know I'd crunch it the next time out! So I don't bother wasting my time.
Doug
Edit: How do you plan on doing the cage?
Plato
Old 02-27-2008, 07:49 PM   #15
richharr
http://pirate4x4.com/forum/showthread.php?t=658313 my favorite build right now, second pic.
http://pirate4x4.com/forum/showthread.php?t=626346 good in progress pics
http://pirate4x4.com/forum/showthread.php?t=553746
http://pirate4x4.com/forum/showthread.php?t=552224
one of the many plans for my jeep
93 4.0l 5 spd, 33s 4" lift
1. This forum requires that you wait 60 seconds between posts. Please try again in 1 seconds.
richharr is offline   Reply With Quote
Glock Forum
