yj door frame pieces - JeepForum.com
post #1 of 37 Old 12-26-2013, 08:50 AM Thread Starter
mipstien
I am trying to figure out what the pieces are and where to get them for the door.
I have hard bottom door and the soft upper square frame. The part I need to find is the metal frame that the upper half of the door seals onto and the back half of the top attaches to when all sealed up. It's not exactly the frame although I think it attaches to the frame.
Hopefully that makes sense to someone.
97 Jeep Wrangler
2.5 4 Cyl w/ AX5 trans
31 inch AT Falken Tires.
mipstien is offline
post #2 of 37 Old 12-26-2013, 09:04 AM Thread Starter
mipstien
I'm going with door surrounds as a technical name. It is Besttop top. But I think it is oem replacement.... I think
97 Jeep Wrangler
mipstien is offline
post #3 of 37 Old 12-26-2013, 09:07 AM
johnboy68
HIP2BSQR
johnboy68's Avatar
Not making much sense to me...
The soft upper doesn't have anything attached to it other than the soft upper frame inside the soft upper canvas/cloth door. It has weather stripping as part of the upper door. The soft upper door seals against the OEM soft top frame (top and rear side) and the windshield frame. The windshield frame has a vertical plastic piece attached that seals the front of the upper door.
You can get an idea of the way it seals in this picture on Amazon:
http://www.amazon.com/Rampage-Produc...art/B001EU7OJK
Hope this helps...
-John-
johnboy68 is offline
post #4 of 37 Old 12-26-2013, 09:12 AM Thread Starter
mipstien
the outlined part in the picture.
http://www.jeep4x4center.com/bestop-...-55004-01.html
mipstien is offline
post #5 of 37 Old 12-26-2013, 09:16 AM
johnboy68
HIP2BSQR
johnboy68's Avatar
The top and rear is part of the OEM soft top frame and the front is the plastic piece attached to your windshield. It's not a part of the soft upper door.
-John-
post #6 of 37 Old 12-26-2013, 09:17 AM Thread Starter
mipstien
ok. so where can you get a replacement plastic piece? i didn't want to have to build this stuff outa fiberglass myself but if it comes to that i might have to. anyone have any better pictures of it so i can get an idea of what i need to build?
mipstien is offline
post #7 of 37 Old 12-26-2013, 09:21 AM
johnboy68
HIP2BSQR
johnboy68's Avatar
So, do you have the OEM soft top? If you have the Bestop "replace a top" you have the OEM frame with new cloth that only replace the soft parts of your top and doors. It doesn't come with any of the hard parts.
-John-
post #8 of 37 Old 12-26-2013, 09:24 AM Thread Starter
mipstien
if only i knew exactly what i had. it was pieced together and im pretty sure the frame is a bestop replacement frame and top. i never had the original stuff. i am assuming that if i contact bestop they can probably get me a part?
mipstien is offline
post #9 of 37 Old 12-26-2013, 09:40 AM
johnboy68
HIP2BSQR
johnboy68's Avatar
Maybe if you had a picture of what you have we could tell you what you're missing.
I will say that if you have square corners on your soft upper doors you have the OEM style soft top.
-John-
post #10 of 37 Old 12-26-2013, 10:08 AM Thread Starter
mipstien
here are a couple of images.
mipstien is offline
post #11 of 37 Old 12-26-2013, 04:00 PM
Berniebikes
yep, looks like an oem replacement top. Here's a ;link for the part that fits on your windshield frame
http://www.4wd.com/Doors-Door-Access...FZKGfgod50gASw
not sure where you get the other pieces without buying the whole frame kit
Berniebikes is offline
post #12 of 37 Old 12-26-2013, 04:57 PM
kjg26
kjg26's Avatar
Are those pieces needed for hard doors?
Black 1993 YJ 4.0, 5 Speed
Slowly but surely getting better and better. Trailer build soon!!
kjg26 is offline
post #13 of 37 Old 01-13-2014, 08:47 AM Thread Starter
mipstien
so i never did find the pieces for this. only the windshield part. the rest of the surround doesn't seem to be something you can buy alone except on maybe a part out.
mipstien is offline
post #14 of 37 Old 01-13-2014, 09:41 AM
xeroid81
I was a bit confused about this post at first but I now see the OP'S quest. I have a Besttop Supertop I bought from ebay years ago. I believe it was listed as being for full steel doors,which I had. I remember seeing a door surround built into the roof frame itself. It hinged where that hole is in your the picture on the door upright. I 'm thinking maybe there is a model for soft doors and a separate one for steel doors. I'm not too sure. All I know is mine has a door surround as part of the roof frame. Maybe PO broke it off. I don't have the top anywhere on the property so I can't take a pic. That frame doesn't look like mine does. Mine had a horizontal piece with a 1/4 turn wing/ring nut thingy that connected to an upright on the other end which fit in a bracket screwed on the tub at the fabric lip. There was also a bracket which fit between the windshield and rollbar horizontal tube(triangle shaped) IIRC. Hope this helps you out. Keep in mind that mine was a Supertop.The vertical rod had the side fabric wrap around it and sealed against itself with velcro. Could that be a supertop fabric on a besttop replacement frame?
xeroid81 is offline
post #15 of 37 Old 01-13-2014, 09:48 AM Thread Starter
mipstien
these are the windshield surround pieces which have another piece that attaches to the top where the tab is. I am pretty certain the top piece has buttons on it. the rear piece, like you said, just attaches to those holes and the door pushes against it and keeps the seal. i have a lot of gap around the door which i packed full of a blanket. it worked but its no where near perfect and still gets quite cold.
mipstien is offline
