YJ death wobble after bump - JeepForum.com
post #1 of 34 Old 07-16-2013, 03:28 PM Thread Starter
Corvo838
Hello people. So I have experienced death wobble after hitting a large bump and it scared the hell out of me. It didn't do this for a while after and now has been happening more regularly. Its a 95 yj, 2.5, 4 inch RC lift. It only happens at slower speeds when I hit a good bump and starts with a slight wobble and progresses into a violent wobble until I slow down to where I am almost stopped. I am thinking about taking it to go get aligned because my steering wheel is like upside down to drive straight. It has always been like that even before the wobble episodes started. I have heard of removing the trac bar which I plan to do for ride quality but could that be something causing death wobble? A little help here guys. Thanks!
Corvo838 is offline
post #2 of 34 Old 07-16-2013, 03:55 PM
superj
Check the steering stbilizer. I ha the same issue on a commanche, would only start after hitting a bump and I would have to slow below 25 or so for it to stop. For me, a new steering stabilizer and I never had the issue again.
My dad had the exact same issue and his went away with a new steering stabilizer, also
I don't feel like working on anything at this time so i sold my yj.
superj is offline
post #3 of 34 Old 07-16-2013, 04:38 PM
jokerchief462
The steering stabilizer is part of the solution but will mask other bad parts. Take it to a shop and have it inspected for bad steering parts as in ball joints, tie rod ends, wheel hub unit bearings, bad tires, wheel balance, steering gear box play, steering column lower bearing loose etc. Get a written estimate and decide who is going to do the work. It could be the very simple to the very expensive and this is not something you want to ignore or delay fixing it will only get worse.
Good luck!!
89YJ 2.5L TBI, AX-5, NP231 SYE, Ford 8.8, Yukon Grizzly, Tom Woods Shaft, 33" BFG T/As, 4" lift, Warn VR10000s.
AF Jeep Club Tail #184
jokerchief462 is offline
post #4 of 34 Old 07-16-2013, 05:32 PM Thread Starter
Corvo838
Of course I can bring it to a shop but I don't want to spend all this money to get something fixed that is something I can do myself...jeeps kill the bank account
Corvo838 is offline
post #5 of 34 Old 07-16-2013, 06:07 PM
jokerchief462
Use their expertise get a written estimate. Then you know what pats are bad and then go home make a plan and replace them as the budget allows.
It could be something simple or a long list you don't know so leg them figure it out and you fix it.
I did my entire front end for less than$300. eBay is your friend and only buy free shipping parts. If you shop wisely you can save a lot.
Special tools are free if you return them at most parts stores. Ball joint press tie rod puller etc.
Once you know what parts you have to replace use YouTube to learn the how there are some great videos.
post #6 of 34 Old 07-16-2013, 06:52 PM
102joe
I am struggling with a very similar issue !
You can align it your self . It should have 1/8" - 1/4" toe in . You can jack up your front end , use a nail or screw sharp end sticking out of a board to scribe a straight line around your tire as someone spins it for you . Compare the distance from line to line front to back with a tape measure . Adjust with the tie rod . the front should be 1/8" - 1/4" narrower . Camber can't really be adjusted . Caster can be adjusted with degree shims . As for your steering wheel you can center it by adjusting your drag link .
Some possible Death wobble causes
Bad spring bushings
Broken Spring center pin
loose Shackle bolts
worn Unit bearings
worn ball Joints
worn tie rod ends
bad shocks
bad steering stabilizer
bad wheel balance
Loose or worn steering components
Loose U bolts
Sounds like I would look at your suspension first by your symptoms .
That said I still can't nail the cause of mine down .
REAL JEEPS HAVE LEAF SPRINGS
NO REALY ,, IT IS HIP TO BE SQUAIR
102joe is offline
post #7 of 34 Old 07-16-2013, 06:55 PM Thread Starter
Corvo838
OK I think I will take it to the shop for a little inspection. I was just underneath and noticed that my sway bar bushings were bad..like torn bad. Im not entirely sure if this can cause this terrifying death wobble. So many places say how rare death wobble is in a yj and I'm just a lucky owner :/
Corvo838 is offline
post #8 of 34 Old 07-16-2013, 07:35 PM
Old4X
1990 CJ7
Is your drag link parallel to your tie rod, or are they at an angle?
418 miles on 19 gallons of gas. Can't beat the BBD !
Old4X is offline
post #9 of 34 Old 07-16-2013, 09:53 PM
rambo3489
I don't get it. I am without shocks. My drag link is no where near the same angle that my tie rod is. I run 35s with no steering stabilizer. And I have no steering issues on the freeway.
Is there something wrong with me?
Sent from my phone because I'm doing something "more important"
89 YJ.. My first jeep and I won't let it go. ▀||||▀
Current Project: None... I disgust myself.
<a href="
THE YJ MY WAY</a>
rambo3489 is offline
post #10 of 34 Old 07-17-2013, 04:48 AM
superj
my current yj has never had the issue but those previous jeeps had it. i am glad this one doesn;t have it but i feel like my wife's 07 jku is going to get it soon. i can feel it trying to start sometimes.
superj is offline
post #11 of 34 Old 07-17-2013, 05:47 AM
Rproject
1987 YJ Wrangler
I experienced death wobble once. Scared the ever living daylights out of me. Happened at 70mph on the Indiana Toll Road. I thought I was going to die - literally. Thankfully my daughter was asleep and didn't see it or she would have been screaming in fear.
For me, death wobble was a combination of dead springs and a blown steering stabilizer. So many things go into the front end system of a vehicle that a single item, or a perfect storm of items, can create death wobble and it may never be exactly the same from vehicle to vehicle. If you can't figure it out for yourself, talk to several shops in your area, start the conversation with "I was going down the road and experienced Death Wobble", if they look at you funny - move on. If they jump in on the conversation and start talking about potential causes and solutions, let them see your vehicle. Do it face-face, that way you can see their reaction and be able to read if they're blowing smoke or actually know what they're talking about.
1996 White ZJ
1987 Maroon YJ (sideways build)
1996 Forest Green XJ
The "sideways" build thread:
Rproject is offline
post #12 of 34 Old 07-17-2013, 06:51 AM
102joe
Of all the things I have read the above statement is true Death Wobble in a leaf spring vehicle is usually caused by more than 1 component failing . Making it very difficult to diagnose , especially in a 20 year old vehicle that is taken off road & UB-USED . I agree with the other posters that getting as many opinions is very helpful . Also consider any recant component changes that could affect the condition . Steering is such a safety concern any questionable components should be replaced .
I pulled my shocks & stabilizer they have resistance, But not sure exactly how much they should have . I have RS 9000 how stiff should they be ?
102joe is offline
post #13 of 34 Old 07-17-2013, 07:30 AM
czjeeper
I never had it until I installed the narrowed HP dana 44 up front.
I can't figure out what's going on.
US Army combat vet
2011 Grand Cherokee Laredo 3.6
Armed Forces Jeeps Member #125
Red Jeep Club Member #251
In the Portland/Vancouver area? Check 'em out!
czjeeper is offline
post #14 of 34 Old 07-22-2013, 03:05 PM Thread Starter
Corvo838
I just drove her down the street and hit a bump and immediately got DW. Was kinda classic because of the lady walking down the street saw this happen I thought she was gonna **** her pants. But I took it home and went under and started shaking and yanking at parts to look for play. I noticed that on the steering shaft it was lose at both ends where I can wiggle it around. My trac bar seems a little loose if I am talking about the right thing. I might just take that sucker out. But would bad ends of the steering shaft at the steering box be able to cause my DW?
Corvo838 is offline
post #15 of 34 Old 07-22-2013, 03:24 PM
Rproject
1987 YJ Wrangler
The steering shaft being loose could give you a very loose wheel, but you would feel that at speed, regardless of a bump or not. Do you have a lot of wheel play to begin with? As for the "trac bar", it should not contribute to death wobble. Lots of people with YJ's run without them, me included, and have no death wobble.
jaycal3 posted this pic up a while back. Granted, it's from a TJ, but the only real difference is the upper/lower control arms and coil springs versus our leaf springs Please identify, from the pic below, which part seems a little loose.
1996 White ZJ
Rproject is offline
