YJ dashboard lights went out--fuse blew - JeepForum.com
post #1 of 4 Old 07-23-2012, 07:29 PM Thread Starter
hotzy21
Hey all!
So I needed help with something. My wife and I were recently on a road trip when I heard a click and all of a sudden my dashboard lights went out. It was night time and my headlights were fine but all of the gauge lights were out. It was the middle of the night and we hardly had any traffic, but a cop stopped me when we were nearly home and told me my back lights were out too. My turn signals and brake lights work, but my back driver and passenger lights and dashboard lights are out. I checked the "dome" fuse and it was blown. I replaced it, and the gauge lights came back on, but 5 min later the fuse blew again. Anyone know where I should check and see where the problem is? I have no idea which wires to check or what. I read in my Chilton's manual that often a wire's coating will break down and cause a fuse to blow. Help!!!
hotzy21 is offline
post #2 of 4 Old 07-23-2012, 07:37 PM
jbolty
jbolty's Avatar
pretty common for the headlight switch to go bad. There are no relays in the circuits and the switch carries the whole load of the lights.
jbolty is offline
post #3 of 4 Old 07-23-2012, 07:47 PM Thread Starter
hotzy21
so would I just replace the switch then? Can I buy that at an auto parts store?
hotzy21 is offline
post #4 of 4 Old 07-25-2012, 10:48 AM Thread Starter
hotzy21
So if the switch doesn't fix the problem, what routes of wiring do I need to check for corrosion and shorts?
hotzy21 is offline
blown , dash , fuse , lights , wire
i blew a fuse and not sure where to look? gattaca37 TJ Wrangler Technical Forum 4 10-17-2010 05:08 PM
Blew a fuse, cant find it ArrizX TJ Wrangler Technical Forum 2 04-03-2009 01:47 AM
Blew a fuse citigirl JK Wrangler Technical Forum 7 08-28-2008 08:37 AM
Blew fuse, now no power inside cab whitewrangler YJ Wrangler Technical Forum 4 09-22-2004 06:30 PM
