yj dash lights always on no key in. wont start. plz hlp. - JeepForum.com
post #1 of 4 Old 01-19-2014, 07:20 PM Thread Starter
kaosyj26003
So just replaced the 2.5 motor in my 95 yj after finding the bottom end toast. Sat and got it all back together hooked battery up and check engine ebrake and seat belt light are on wont shut off even with key removed. Wont start but cranks. Any ideas? Checked grounds all are tight.and beileve are in correct places. Clueless... haynes manual (useless junk btw) is helpless. Thanks
Please help!
kaosyj26003 is offline
post #2 of 4 Old 01-20-2014, 08:03 PM
laybackman
Bikini Bridge Inspector
laybackman's Avatar
2010 JK Wrangler
Please help!
That means those circuits are still getting power. Normally that goes away when you turn the key to the off position.
The actual ignition switch is a slide mechanism attached to the steering column The key portion is attached to it with an actuator rod. It is adjustable.
Can't figure how that problem popped up after the engine swap??
As far as the engine swap goes it is plug and play, so I can't figure how one is connected to the other.
Do you know what was good about the good old days? I wasn't good, And I wasn't old!
Senators and Congressman should wear uniforms like NASCAR drivers so we could identify their corporate sponsors....
laybackman is offline
post #3 of 4 Old 01-20-2014, 08:05 PM
laybackman
laybackman's Avatar
2010 JK Wrangler
Did you attach the ground strap that goes from the firewall to the oil dip stick bolt?
post #4 of 4 Old 01-20-2014, 08:15 PM
kjg26
kjg26's Avatar
Did you use the engines main wiring harness or reuse the harness that was in the jeep already. The bulkhead connectors are slightly diff from year to year I believe. When I swapped interior dash harness I had strange issues like that. Don't know what the solution is though.
Black 1993 YJ 4.0, 5 Speed
Slowly but surely getting better and better. Trailer build soon!!
kjg26 is offline
