YJ D35 Disc brake Conversion Question - Page 4 - JeepForum.com
post #46 of 67 Old 10-05-2013, 12:56 PM
squarelite
Originally Posted by Apollo12227
Since you like numbers, lets break it down a little further. If 80% of all axles that were repaired were D35's.... you dont see that as an issue? I mean for christ's sake, we have a blown up d35 ring gear as a mint-candy bowl for our customers lol... Guess how many Ford F150, 250 or 350 axles came in blown up? Or toyota? Or Suzuki? GM? I missed SL making this point ^^^ The D35 is about the only rear end we work on at Jeeper's Den & Truck Accessories. The dodge 9 1/4 rear end has issues with the pinion nut comming loose, but thats about the only other problem child we dealt with. Trucks and Jeeps come in at about the same rate, the only ones that need rear end work are the turdy5's.
Point being that they are a more appropriate rear end. Not many guys are repeat customers once they go to something that actually is suited for their application
squarelite is offline
post #47 of 67 Old 10-06-2013, 09:08 PM
n9oig
You don't get very much work then if 80% of your work is 1 d35 a month!!!!
88 Jeep Wrangler
95 Jeep Wrangler
SE Wisconsin
n9oig is offline
post #48 of 67 Old 10-06-2013, 10:21 PM
n9oig
I won't argue that an 8.8 or d60s are far more superior axles but, if you don't have the $ or resources to weld or fabricate you can't handle an 8.8 or d60 swap. You can direct bolt in multiple d35s cheaper that doing an 8.8 swap. Sure you can get an 8.8 for $200 now you got to buy spring perches shock mounts gear sets address the parking brake. Some people would argue you don't need it well in some states if your vehicle needs a state inspection it may be required. The same parking brake issue comes up with doing the disk brake upgrade where this thread started there no good solution to the parking brake doing this conversion. If there is, the last time I did the research on this there wasnt an easy solution. The D35s with disk brakes all had the parking brake lever in the center console and the cables were too short to go to our foot pedal brake.
This all comes down to application is it your daily driver? Off-road once a year? Off-road every weekend? If its you daily driver what ate you doing off-road with it when you need in the next day to get to work or school?
88 Jeep Wrangler
95 Jeep Wrangler
SE Wisconsin
n9oig is offline
post #49 of 67 Old 10-07-2013, 08:11 AM
Apollo12227
80% percent of Exploded rear ends/rear end repair were d35... Obviously the overwhelming majority of our time went to other things like installing lifts for people, bed liner applications, adjusting pinion angles, selling/balancing/mounting off road tires, alignments... etc...
And I repeat, most of the exploded d35's that came into the shop were on bone stock daily drivers. Most manual transmissions, but all had the d35. Again, zero offroading, driving a to school, then to work, blown rear end.
Defend it all you would like. Running the d35, especially if you aren't the original owner of a 13+ year old vehicle is playing Russian roulette. Will you be fine going easy on it? MAYBE...
Apollo12227 is offline
post #50 of 67 Old 10-07-2013, 08:51 AM
squarelite
80% percent of Exploded rear ends/rear end repair were d35... Obviously the overwhelming majority of our time went to other things like installing lifts for people, bed liner applications, adjusting pinion angles, selling/balancing/mounting off road tires, alignments... etc... And I repeat, most of the exploded d35's that came into the shop were on bone stock daily drivers. Most manual transmissions, but all had the d35. Again, zero offroading, driving a to school, then to work, blown rear end. Defend it all you would like. Running the d35, especially if you aren't the original owner of a 13+ year old vehicle is playing Russian roulette. Will you be fine going easy on it? MAYBE...
I got lucky with mine. I got free parts for it and I eliminated two of the weakest links, axles and carrier. I beat on it hard for years, but I was always concerned about it. My yj was as light as I could get it too. I rest easy with an 8.8 with chromos now.
post #51 of 67 Old 10-07-2013, 11:45 AM
Tyler980
I was thinking of doing the disc brake conversion on my stock axle, I have no welder/welding skills and don't know anyone to weld an 8.8, as I would rather do that but it all comes down to doing what you can do, and paying for what you can pay for, you guys are all arguing about it, its almost like a religion argument in here, is god real or not?
Tyler980 is offline
post #52 of 67 Old 10-07-2013, 12:36 PM
Sparrows
Really there shouldn't be an argument at all. The d35 is terrible and there is NO arguing that FACT. The only "argument/discussion" I see going on is a select few depending their (factually) wrong OPINION.
In essence they're saying "I think toilet paper is stronger than plywood when used in a specific application" when the reality of the situation is, the application is irrelevant and and one is without question stronger than the other.
Disc brake conversions are spendy. I was into my last 8.8 swap no more than $450.00. How much are you "saving" by converting the d35s to disks, only to later have to replace an axle shaft or a pinion or a ring gear or carrier? And when you pay to fix that and it breaks again?
Is peace of mind not worth something?
Cheers
June '13 YJOTM
Sparrows is offline
post #53 of 67 Old 10-07-2013, 12:44 PM
Tyler980
Like I said. Capability and possibility... since you're capable is it possible you'll come here and weld me up an 8.8? Probably not even though it'd be pretty nice
Tyler980 is offline
post #54 of 67 Old 10-07-2013, 12:56 PM
Tyler980
I wasn't looking to argue a side either Sparrows, I just saw this guy asking for help and everyone turned it into an argument. It's not just about the money but the ability to do it as well.
Tyler980 is offline
post #55 of 67 Old 10-07-2013, 01:00 PM
Sparrows
We're pretty far apart.
But I guarantee that if you look, even a little, you can find someone to do the welding for you. Whether it be a local fab shop, spring shop, off road shop, etc. Or you can post an ad on CL; "looking for a welder for 2 hours. Paying $100.00. Need two spring perches and two shock tabs welded to an axle." Or post in your local "wheeling neighborhood" section of JF and find a local guy that wouldn't mind sharing a beer, talking Jeeps, and setting you straight.
None of that would cost you much. Certainly much, much, much less than someone replacing your R&P or burning through used d35s, or a set of new shafts. Right? Right.
Your excuses are pretty weak man. Will meet Way.
Cheers
June '13 YJOTM
Sparrows is offline
post #56 of 67 Old 10-07-2013, 01:05 PM
Tyler980
Haha, no excuses. Was just saying... maybe I don't want to meet any of the possible internet weirdos around my area... lol
I plan to buy a welder at some point and teach myself anyways, the jeeps taught me everything else, might as well learn that on it as well.
Tyler980 is offline
post #57 of 67 Old 10-07-2013, 01:06 PM
Sparrows
That right there, is the correct attitude!
Cheers
June '13 YJOTM
Sparrows is offline
post #58 of 67 Old 10-07-2013, 01:08 PM
Tyler980
now send me a darn /f12 sticker!
Tyler980 is offline
post #59 of 67 Old 10-07-2013, 01:15 PM
Sparrows
Lol
PM me your address and if you want black or white.
Cheers
June '13 YJOTM
Sparrows is offline
post #60 of 67 Old 10-07-2013, 02:21 PM
Tyler980
Lol
Cheers
Did you get my PM?
Tyler980 is offline
