YJ D35 Disc brake Conversion Question - JeepForum.com
post #1 of 67 Old 09-23-2013, 06:17 AM Thread Starter
Robob69
I know this has probably been asked a gagillion times but I could not find the information to answer my question..
I have 1 D35 in my YJ.. I want Disc Brakes on the rear.. Can I take the brakes from a XJ or other GC to retro on my D35?
If so what will fit or is it worth it?
Complications of such a retro?
Thanks
Robob69 is offline
post #2 of 67 Old 09-23-2013, 07:02 AM
Eron
About 15 seconds of searching on the forums resulted in numerous results.
try " yj disk break conversion " in the search bar.
Eron is offline
post #3 of 67 Old 09-23-2013, 07:05 AM
StanF
Ford 8.8...the best disc brake conversion for your Jeep, and the bonus is a much stronger rear axle
StanF is offline
post #4 of 67 Old 09-23-2013, 07:10 AM
ionakana
Grand Poobah
ionakana's Avatar
This!... don't throw money in to a Dana 35. It's in the bible, Exodus I believe. Thou shalt not build a dana 35.
Psalm 14:1
Live in Georgia? click here-->
ionakana is online now
post #5 of 67 Old 09-24-2013, 01:25 PM
ldso
Thanks
Hey Bud,
I think that the ZJ Grand Cherokee ran the Dana 35 and had the 5on4.5 wheel pattern that you want. I have not done the swap, but from what I understand it is a bolt-on. What's nice is while it doesn't make the axle semi- or full-floating, if you break an axle shaft on the rear end your wheel will stay on. Hopefully at least long enough to get off the trail. I was planning on doing the same thing before I did my axle swap.
Rear discs are nice, my rig has bigger rear brakes than front ones currently. The brake pedal went from a "whoa" pedal to a "stop" pedal
You will need to research the lines, but I would suspect that the ZJ axle has soft lines from the calipers, then connects to hard lines that connect to a tee. I would imagine that you could just connect the Wrangler tee to the ZJ lines, if the fittings turn.
It is a noob question, but my old lady let me get lucky last night so I'm in a generous mood. Great day ain't it?
1995 YJ "Mabel", 2.5L Muncie SM465 np231j 4.88's HP30 Lockright JK 44 Detroit 33s CJ clip
Actually, it's pronounced "mill-e-wah-que" which is Algonquin for "the good land."
ldso is offline
post #6 of 67 Old 09-24-2013, 01:30 PM
squarelite
I would go straight for an 8.8. The d35 is not worth doing that type of upgrade to.
squarelite is offline
post #7 of 67 Old 09-24-2013, 10:08 PM
deathtrap
93-98 zj stuff should work. (I did it on a tj) And as a added bonus when the d35 grenades the calipers will help hold the wheels on.
deathtrap is offline
post #8 of 67 Old 09-25-2013, 01:49 AM
n9oig
Of all the disk brake conversions I've read no one had a good solution for the parking brake. That's the major reason I didn't do the convertion. Since I have a 5 speed that's a must
88 Jeep Wrangler
95 Jeep Wrangler
SE Wisconsin
n9oig is offline
post #9 of 67 Old 09-25-2013, 06:02 AM
SeanB95YJ
for the money you spend getting all the necessary parts for a disc swap, you should be able get yourself an 8.8 and have a better setup all-around
Sean B. - Schenectady, NY - 95 YJ, 350/700r4/NP241, JB Shorty SYE, 8.8 rear, 2" BDS, 1" homebrew shackles, Daystar 1" BL, TJ flares, 35x12.50 General Grabber AT2 on 15x10 Bart D-Truckers, Polyshield polycarbonate windshield, HD over/under crossover steering
swap/build thread:
SeanB95YJ is offline
post #10 of 67 Old 09-25-2013, 12:05 PM
calvynandhobbs
calvynandhobbs's Avatar
If you can get the parts cheap it is pretty much a bolt on except for the parking brake. I don't think it's worth the price of those kits though.
I picked up a 95 ZJ front and rear axle from one that blew the transmission for $125. I stripped the disc brake stuff off the rear and pulled the axleshafts out of the front since it was ABS and had 297 joints.
94 YJ - work in progress
calvynandhobbs is offline
post #11 of 67 Old 09-25-2013, 04:21 PM
metalhead
2011 WK
I want to convert my yj to rear disc brakes. I think its more work than I can handle to install a ford 8.8 rear. Besides I didn't buy a jeep to throw ford parts on it. There is a web site that has instructions on how to do the conversion using parts from a zj. Hope someone on here has a link to it because I can't find it. Its called stu's something.
metalhead is offline
post #12 of 67 Old 09-25-2013, 04:49 PM
remmons
X2. The 8.8 is THE only way to go, not only for the disc brakes, but also for the strength.
X2. I totally agree. Don't throw money into junk, it will still only be junk.
Hey Bud,
You will need to resarch the lines, but I would suspect that the ZJ axle has soft lines from the calipers, then connects to hard lines that connect to a tee. I would imagine that you could just connect the Wrangler tee to the ZJ lines, if the fittings turn.
True. Eveything from a 93-98 GC will transfer right over, except for the parking brake lines, except....look at the post below the next quote;
M.O.R.E. sells a parking brake conversion for the 8.8, and since there have been others who have said that the brake cable mountings seem to be identical, I see no reason why they shouldn't work on a D35 as well. I have compared the brake-ends of the 8.8 and the GC cables, and they were identical in every way that I could see. But, this doesn't mean that I am supporting anyone on keeping their D35, unless they don't plan on wheeling it too hard. In which case, if you can do a rear disc brake conversion on the cheap, then by all means go for it. I almost did until I had realized that I can get a whole 8.8 axle with discs for less ($200.00 pulled and out the door) than what it would have cost me just for a disc brake conversion for a D35.
Robert.
remmons is offline
post #13 of 67 Old 09-25-2013, 04:59 PM
Sparrows
The 8.8 swap is easy. Not much more work than doing the brake conversion. Yeah you bout a jeep, but one with a few little flaws like a retardedly weak rear axle.
Why waste any time and money polishing a turd? Grab an 8.8, take your time cleaning it up and gathering parts, then get it put in over a weekend.
Don't be scared. You can do it.
Cheers
June '13 YJOTM
Sparrows is offline
post #14 of 67 Old 09-26-2013, 07:06 AM
StanF
The 8.8 swap is easy. snip
Agreed, but you need to be able to weld or have a friend who can weld. There's a ton of info here in the forum on doing the 8.8 swap.
StanF is offline
post #15 of 67 Old 09-26-2013, 10:58 AM
Sparrows
Even if you can't find a friend whom can weld, a local shop shouldn't charge much to burn in the perches/mounts.
Cheers
June '13 YJOTM
Sparrows is offline
