yj coilovers - JeepForum.com
post #1 of 19 Old 01-29-2009, 08:16 AM Thread Starter
jeepwyj94
yj coilovers
has anyone done a right up on how they did there coilovers with any pictures
jeepwyj94 is offline
post #2 of 19 Old 01-29-2009, 08:23 AM
Axl Jack
Search google. A lot of magazines have done articles.
In reality, it would be cheaper to go out and buy a used TJ and start on that than it would be to convert a YJ into a coilover system.
On a side note, I think Chrysler really dropped the ball when they didn't make the YJ with coils up front and leafs int he rear.
94 YJ w/ stuff. All the work/money I put into it, and the comment I get most is my $20 mod: "Hand throttle?!? That's awesome."
Originally Posted by dmcanally View Post
You know you drive a YJ when it is no longer getting older, but slowly becoming brand new part by part.
Axl Jack is offline
post #3 of 19 Old 01-29-2009, 09:09 AM
1 ton yj
1 ton yj's Avatar
no because there are a million different ways to do it.
1 ton yj is offline
post #4 of 19 Old 01-29-2009, 09:19 AM
Douglas S.
Is it really that much harder to convert a YJ to coilovers than a tj? I thought you needed all new brackets anyway?
1991 Land Cruiser HDJ81
Douglas S. is offline
post #5 of 19 Old 01-29-2009, 11:25 AM
1 ton yj
1 ton yj's Avatar
Only reason a TJ would be easier is because you can bolt on a longarm lift kit and skip the less-easy part.
Still with the amount of pre-made brackets and tabs availible, its not hard on a YJ or a TJ.
1 ton yj is offline
post #6 of 19 Old 01-29-2009, 03:06 PM
Ben_88Jeep
2010 JK Wrangler
The cheapest way I've seen it done is with a 3-link kit up front... requires fab work and welding to get 'er done right...
Here's an article talking about it:
http://www.bc4x4.com/inthenews/default.cfm?ID=251
Ben_88Jeep is offline
post #7 of 19 Old 01-29-2009, 09:40 PM
jeeepguy
jeeepguy's Avatar
Heres a link to the Black Diamond X2 system but 1 Ton is spot on... there are a million ways to do a coilover and plenty of builder kits as well. The Genright kit is pretty good. Just add the coilovers of your choice.
"Si Vis Pacem Para Bellum"
"Great danger lies in the notion that we can reason with evil"
Doug Patton
...We use words like honor, code, loyalty. We use these words as the backbone of a life spent defending something. ...I have neither the time nor the inclination to explain myself to a man who rises and sleeps under the blanket of the very freedom that I provide, then questions the manner in which I provide it. I would rather you just said thank you, and went on your way, Otherwise, I suggest you pick up a weapon, and stand a post...
I bought the HI-WAY BLASTER HORN that's 139dB and every time I honk the horn an Angel dies.
Revelation 13:16-18
16 - He causes all, both small and great, rich and poor, free and slave, to receive a mark on their right hand or on their foreheads,
17 - and that no one may buy or sell except one who has the mark or the name of the beast, or the number of his name.
18 - Here is wisdom. Let him who has understanding calculate the number of the beast, for it is the number of a man: (Real ID and RFID chips)
Think about it...
jeeepguy is offline
post #8 of 19 Old 01-29-2009, 10:06 PM
yjcrawlr
When you really get serious about crawling a tj the mounts have to all be re-done and and the axles aren't even close to being strong enough unless it is a rubi. In my mind you might as well start with a yj.
90 YJ 102 in wb stretch, SOA, dana 60, 14 bolt welded,4.56s, 37in Parnelli jones dirt grips, currie twin stick dana 300, york oba, tractor link traction bar, full custom armor,poison spyder tube fenders, 95Cherokee High Output 4.0
2014 JKU, modified Rubicon Rails, RC stubby with warn 8000m, 2" leveling springs and OME trim spacers, Superchips Flashcal, Spidertrax wheel spacers, rubi shocks, and Lots more mods soon!!!
yjcrawlr is offline
post #9 of 19 Old 01-31-2009, 09:02 PM
mattman320
Geeze, for 1500 bucks on most of these kits just for parts, thats steep seems to me.
this may be a completely stupid question, but i'm not a genious about a lot of things, especially really technical stuff BUT ... could someone not just go to a salvage yard, find a totaled whatever truck or somethin that has relatively long springs and shocks and all, take it and transplant it to a YJ if you just make custom mounts and stuff???
(until about a week ago i had a 93 bronco, it has a D44 front axle and if it wasn't in such good shape and someone wanted to buy it, i'd considered throwing the rear axle in my jeep, an taking the front suspension and somehow making it fit the YJ)
94 Red YJ, 2.5, 4.5" BDS lift, intake, exhaust, 33" Goodyear Wrangler Duratrac tires. I think i have the slowest car on the planet.
mattman320 is offline
post #10 of 19 Old 01-31-2009, 09:46 PM
leftlanetruckin
XJ on 37's
leftlanetruckin's Avatar
good idea IMO,.
a good candidate would be a xj, if it had the long arms.
shouldnt be too hard to modify to fit a yj i dont think.
grab the arms and brackets, then the coilovers....
just a thought from a previous yj owner that now has a long arm'd xj!
martin
1998 XJ on 37's.JK Rubi axles with chromo shafts and ctm's, 4:1 transfer case, etc etc etc.
2003 Range Rover HSE, 4.4 Quad Cam.
1998 Range Rover with a 6.0 LSx
1994 YJ, 4.3/700R4/OME SOA, etc
Western Star 4900EX 4 axle.
4.3/700r4/new frame buildup (YJ)....
leftlanetruckin is offline
post #11 of 19 Old 01-31-2009, 09:50 PM
mattman320
thanks, i'd definitely thought about trying to find an xj just for that, but didn't know how crazy of an idea it was, but when i think about it, seems like almost any kit could fit with a little cutting, shaving, and making some mounts.
BTW, you've got 1 bad xj there, not many at all around here, just a few with full width axles, i love xj's, you still get the good clearance and approach and departure angles, but it easy to haul aorund the crew in .. if the top only came off...
post #12 of 19 Old 01-31-2009, 09:58 PM
leftlanetruckin
XJ on 37's
forgot to mention, the xj is radius arms, not a true 3 or 4 link.
i haev no problems with flex, to say the least. seems an easier way around it to me.
need a trac bar, and thats it.
thanks for the compliment!
martin
post #13 of 19 Old 02-06-2009, 03:52 PM
Ben_88Jeep
2010 JK Wrangler
Has anyone tried putting coilovers in the YJ?
http://www.genright.com/ProductInfo....uctid=KING20CO
Ideally I'd like to keep the same ride height as my current 3" lift allows. (any higher for example and I wouldn't be able to get in underground parking stalls).
I'd also be curious to get an idea of how it drives...
post #14 of 19 Old 02-06-2009, 09:42 PM
95wrangler4life
search back through the YJ section, someone recently did a coilover on a YJ, pretty lengthy thread with great pics, i will try to locate it as well.
95YJ 2.5 AX5 NP231 HP30 4.88 and aussie, 8.8 4.88 mini spool, 4" RC, 1.5" Boom shackles, 1" BL, 1" rear stretch, 36 12.5 15 TSL SX's, trimmed front fenders, bedlined exterior, comp cut coming soon!
Build thread:
95wrangler4life is offline
post #15 of 19 Old 02-06-2009, 09:48 PM
95wrangler4life
here it is: http://www.jeepforum.com/forum/showt...=603701&page=3
dang sweet setup!
Build thread:
tj coilovers? 0IIIIII0 TJ Wrangler Technical Forum 36 06-10-2014 06:53 PM
Why does no one run coilovers w/ SA's? CCJ TJ Wrangler Technical Forum 33 10-02-2009 07:53 PM
Coilovers JCM TJ Wrangler Technical Forum 4 10-19-2006 07:18 AM
Coilovers TJJPNUT TJ Wrangler Technical Forum 1 12-08-2004 09:48 AM
Coilovers? Who What When Where???? stjjames TJ Wrangler Technical Forum 15 12-06-2004 05:16 PM
