Quantcast YJ coilover buildup - Page 5 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > YJ coilover buildup
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineBLOWOUT SALE -- SYE Slip Yoke Eliminator Kits, NP231 TransNEW BOLT-ON Dash CB Mount 97-06 TJ Wranglers
Old 01-01-2009, 03:17 PM   #61
1 ton yj
How do you plan on building it yourself? I have yet to see a straight junkyard housing. Currie has the best deals on housings with C's welded on from the little research I've done.
1 ton yj is offline   Reply With Quote
Old 01-01-2009, 03:29 PM   #62
fratis
fratis's Avatar
i have a currie housing myself, but for my 609 project i grabbed a junkyard one. i think if i were doing it again id go with one of the many like spydertaxs or balistic fabs. they really arent all that expensive when looking at the bigger picture. a pair of matching hi9s with arbs are the big expense.
fratis is offline   Reply With Quote
Old 01-01-2009, 08:22 PM   #63
JJ-4
JJ-4's Avatar
1987 YJ Wrangler
i planned on using the spidertrax housing and going hi 9's
87 YJ, 07 JK 5.3 Vortec
Firefighters Jeep Club
http://groups.jeepforum.com/Firefighters_Jee p_Club
JJ-4 is offline   Reply With Quote
Old 01-01-2009, 11:22 PM   #64
1 ton yj
Nice. I'd like to build a 9" for the back of my rig, get rid of the 14 bolt and it's dead weight, and also gain some clearance too.
The Spidertrax housings get expensive when you use their Ford F350 unit bearing ends with the fancy Wilwood brakes. The bare housings themselves are actually very resonable, $399 ea. High9's are nice in the front, nice but not necessary in the rear IMO.
What do you plan on for the rear? Semifloat with pressed on bearing ends, or full float with the F350 unit bearing outers?
Old 01-01-2009, 11:49 PM   #65
YJyoungster
I'd like to buy your old lift kit parts, shackles, shocks leafs, ect.
Shoot me a PM
Also That coilover setup looks kickass
YJyoungster is offline   Reply With Quote
Old 01-01-2009, 11:56 PM   #66
1 ton yj
lol this thread is full of circling vulchers
I wish I knew about JF when I built my Jeep, nothing left but scrap now
Old 01-02-2009, 09:30 AM   #67
jason m
i started building this and it really pretty straight forward http://s150.photobucket.com/albums/s89/420willys/?action=view&current=9-2.jpg . i made my own inner axle seal reatiners http://s150.photobucket.com/albums/s89/420willys/?action=view&current=9-1.jpg . i used a 1.5" chrome rod as a line up bar http://s150.photobucket.com/albums/s89/420willys/?action=view&current=9-3.jpg and two 1.5" HIEM http://s150.photobucket.com/albums/s89/420willys/?action=view&current=9-5.jpg bodys as a way of centering the bar in the housing http://s150.photobucket.com/albums/s89/420willys/?action=view&current=9-4.jpg .
i cut two 60 C's off a housing with a crack in it and will use all the outers from that axle. the short side axle is stock chevy and the long will be a custom cut one. so far im into this for nothing but labor. at some point this axle will replace the 60 front in the jeep.
sorry for the high jack but even if you buy a spider trax axle you love the fact you can lift the housing over your head with no effort.
jason.
1993 YJ 4.0 60 Front, Rear steer 60, bolth spooled, 5.38's, 700r/241 39.5 iroks and beating it like it owes me money.
jason m is offline   Reply With Quote
Old 01-02-2009, 03:35 PM   #68
1 ton yj
I've wondered what happened to that. Do you have a pic with the C's welded on?
Want to build me a FF rear? I've got the parts just no alignment tools.
If you want to build more fronts I have a source for junkyard 60 outers from the inner C's out.
Old 01-02-2009, 05:38 PM   #69
jason m
i never got the C's board open to 3 1/8, other than that its all set and ready to go. a rear FF, i will PM you what i figured out using 14 bolt junk and i would love to build a few more steer axles. i will PM ya.
jason.
Old 01-02-2009, 05:58 PM   #70
JJ-4
JJ-4's Avatar
1987 YJ Wrangler
Ya its gonna be expensive but i figured it would be worth it. Its gonna take me a while to get all the parts but im hoping in can have these axles in by early summer maybe spring depending on how much ot is available at work. As for the hi 9 im only gonna put it in the front no real need for it in the rear plus they are expensive. The rear axle im not quite sure what i want for that yet but i'll probably end up full float.
Old 04-12-2010, 05:47 PM   #71
clemsonfan16
Good job on the coilovers. I am going to do the same thing this summer and have a few ?s.
How do you like the fox coilovers?
Around how much was just the suspension set up and coilovers total. (Ive already got the same steering and axles under the jeep)
Thanks
-Hunter
clemsonfan16 is offline   Reply With Quote
Old 04-12-2010, 06:43 PM   #72
Blstr88
No Spark
Blstr88's Avatar
Geez talk about an old post?
Blstr88 is offline   Reply With Quote
Old 08-19-2010, 05:10 AM   #73
LKrux
that looks so sweet. wat a beast
nice work
4.0, 5sp, bfg33's, 3 1/2 lift
LKrux is offline   Reply With Quote
Old 08-19-2010, 09:38 AM   #74
E_ROCK
Looks great! Nice work!
Garage Monkey, Wheeling Junkie
www.rockfrogs.org
E_ROCK is offline   Reply With Quote
Old 02-16-2011, 01:05 PM   #75
JJ-4
JJ-4's Avatar
1987 YJ Wrangler
Well its been awhile since ive worked on the Jeep so i decided to go ahead and start building my new front axle. I bought a spydertrax housing, Reid inner C's, stock D60 knuckles, and outers for a 5x5.5 bolt pattern. I'm also gonna be ditching my steering setup and run PSC full hydro so i can stretch the front a little more and remove some of the clutter under the front end. Dont have very many pics right now as im at work but ill take more as i move along.
Glock Forum
