YJ coil over conversion - JeepForum.com
post #1 of 27 Old 12-01-2009, 07:32 PM Thread Starter
OldManHavasu1
Newbie
First post new guy play nice!!! I usually hang out on boat forums!
Thinking of putting a 5" coil over conversion from Pro Comp on my 94 YJ.
Anyone done this?
Opinions good or bad before I drop dollars?
Speak your mind!
Thanks!
Gary
OldManHavasu1 is offline
post #2 of 27 Old 12-01-2009, 07:41 PM
Tom95YJ
[] Eye'd Jeep Connoisseur
Tom95YJ's Avatar
I work for 4wheel Parts trust me Do not do this kit ! They have lots of Ride/ Steering issues
My basis for this comment is : We have done this conversion on about 5 YJ's and no one is happy with it. I will tell you flat out if you want coils Sell the YJ and get a TJ or if you really want coils spend the $ for a Genright conversion but that will run you about $5,500 + labor
Link to Genright kit :
http://www.genright.com/ProductInfo....ductid=GRCSKIT
'89 YJ The Smurf
'99 XJ Black Betty
Tom95YJ is offline
post #3 of 27 Old 12-01-2009, 07:45 PM
TSEJEEPERS
Do a search their are alot of opinions on this kit.
A guy in our club had one of these kits on his Jeep. He was not happy with it. From what he told me it was pretty hard to swap out any other axles beside the stock ones.
I have read post though where people said you could.
He ended up taking his off and going SOA. He also traded axles for a Dana 60 and 44.
I do know of a couple of people that did the Black Diamond kit. They were happy with them. I am not sure if they make them anymore though.
93 YJ SOA 2" springs front, XJ springs rear w/main leaf added, High pinon 9 inch rear detroit locker front Dana 44 ARB 4.56 Gears, 36 inch Irok tires too much to list.
TSEJEEPERS is offline
post #4 of 27 Old 12-01-2009, 09:03 PM
Joe Dillard
Electric Chair Operator
Joe Dillard's Avatar
Not one reputable shop near me will either sell you one - or install one.
Joe Dillard is offline
post #5 of 27 Old 12-01-2009, 09:54 PM Thread Starter
OldManHavasu1
Newbie
This is the type of info I was looking for!
I don't really want to sell the YJ because of the ARB lockers and all the other mods I bought it with.
I never break anything on this jeep so I might just leave it alone??
post #6 of 27 Old 12-02-2009, 01:04 AM
HilltopperYJ
yeah nothing wrong with leafs
K Σ
A-E-K-Δ-B
ΜΟΛΩΝ ΛΑΒΕ!
HilltopperYJ is offline
post #7 of 27 Old 12-02-2009, 06:45 PM Thread Starter
OldManHavasu1
Newbie
So what is the cleanest way to increase suspension travel? I'm looking for more articulation.
Thanks!
post #8 of 27 Old 12-02-2009, 07:11 PM
Joe Dillard
Boat =
Break
Out
Another
Thousand
Gary, if you are satisfied or convinced that your Currie SUA set-up has not provided you with enough travel & articulation, there are a few things that can sometimes help in fine-tuning it to get a bit better, but I wouldn't expect huge improvements if you have already done some things.
Better greasable shackles, better bushings, different spring rate, better shocks, better swaybar set-up, better tracbar/panhard bar set-up, better steering set-up that allows for the steering links to "twist" more freely & without bind, plus a few other things is about all there is for a SUA set-up.
Unless you are possibly looking to go SOA, the above is about all you can look into for potential improvements. Sometimes the shocks are limiting things & often if the tracbar and swaybar are still in use, those will hamper travel & articulation.
What types of improvements have you done to the Currie suspension?
Are you still running the F&R tracbars & front swaybar? If so, are they stock?
post #9 of 27 Old 12-02-2009, 09:13 PM Thread Starter
OldManHavasu1
Newbie
Boat =
Break
Out
Another
Thousand
Yes the Jeep is SO MUCH cheaper to operate than the boat. Gets more use too!
post #10 of 27 Old 12-03-2009, 04:17 PM
KMA Krawler
your pm box is full...clear them out.
Co-Founder/ Administrator
KMA Off-Road Jeep Club
KMA Krawler is offline
post #11 of 27 Old 12-03-2009, 04:27 PM
Bajachief
Coil conversion
I have the Procomp conversion on my 1988 wrangler and think it works.
Ride issue? I don't know, my jeep ride like a JEEP so I am not expecting too much.
Steering? same thing, 35" tires and no sway bar. Steers like a JEEP
Problem area - putting in 8.8 rear axle caused the "bolt" on parts to now be "welded" on parts so that might create issues in the future.
Maybe if I drove one of the newer ones I might think I have a problem, but for now it does what I want and goes where I want.
Bajachief is offline
post #12 of 27 Old 12-03-2009, 05:46 PM
bigredcherokee
Right nothign wrong with leafs or SOA.
For those of you in Louisiana visit
bigredcherokee is offline
post #13 of 27 Old 12-28-2009, 07:22 PM Thread Starter
OldManHavasu1
Newbie
Anyone have any input on a reliable jeep/offroad place in so.cal? Inland Empire Upland San Bernardino area?
Anyone had experience with 4 West in Colton?
post #14 of 27 Old 12-28-2009, 10:44 PM
Joe Dillard
Without reservation - John Lemieux of All Four Wheel Drive, in Corona is as good as it gets. Stellar reputation. You will be hard pressed to find a superior gear guy.
21765 Temescal Canyon Rd
Corona, CA 92883
(951)277-1037
Johns motto:
Quality is like buying oats. If you want clean, fresh oats you must pay a fair price. If you want oats that have already been through the horse, those are a little cheaper.
I know of a couple closer to me (San Diego area) but John is as good as it gets.
post #15 of 27 Old 12-29-2009, 01:23 AM
navman
I went with a RockKrawler coilover kit on the front and kept the rear sua leaf. It gives you a bunch of travel and drop out in the front to maintain traction, but retains some stability in the rear on the off camber stuff. So far I'm really happy with it and would recomend it to anyone. Here's a link to my build to see what I'm talking about http://www.jeepforum.com/forum/f12/m...-build-931241/
95 YJ 5.0 linked etc
navman is offline
My YJ Coil Conversion CrazyCooter YJ Wrangler Technical Forum 71 11-20-2011 05:31 PM
Coil Conversion Kit For YJ '90 Urb4nTr0ll YJ Wrangler Technical Forum 4 07-08-2008 04:58 PM
coil over conversion revrider9 YJ Wrangler Technical Forum 21 11-01-2007 07:05 AM
YJ Coil Conversion??? markburtenshaw YJ Wrangler Technical Forum 22 06-08-2004 08:02 AM
coil conversion Meister_jeep YJ Wrangler Technical Forum 4 10-06-2002 04:19 PM
