What's the best clutch kit to buy. I was thinking of buying a luk heavy duty clutch kit off rock auto. The standard is 12 1/2, the heavy duty is 12 3/8. Will the heavy duty work? Bolt up? What about the slave cylinders? Are the luk brand any good.?
Luk is good and pretty standard, i'm sure its what a lot of us use. Theres a few parts house brands that use luk components as well. Don't spend the extra money for a centerforce.
There's a huge thread on this somewhere in YJ Tech. Actually I think that's more of an internal slave thread, but you should probably do that while you're in there. I had good luck with the Luk, actually pretty sure that's what's in there now. I replaced the one previously thinking it was going back, but it turned out to be something else all together, the one I took out I bought 10 years ago on eBay, and it was a "Grip Force" clutch and it lasted about 8 years with lots of trail use and was actually still good when I pulled it.
Luk makes good clutches, they're what I install, exclusively. With your 87 if it's not already modified you have the Peugeot BA 10/5 transmission and internal slave system. Your clutch will not be the weak point of your driveline, no matter what you install.
Before you consider other upgrades, get an AX15 or NV3550 in there that will provide a foundation for whatever else it is you're planning on building.
I installed a Luk clutch last winter with my new trans. Along with a new slave and flywheel.
No problems here. Very cost effective too for all of those parts from Rock Auto.
Related Threads
Jeep Enthusiast Forums
18.5M posts
726.8K members
Since 2000
