Yj clutch problems - JeepForum.com
post #1 of 3 Old 06-01-2013, 11:13 AM Thread Starter
FUBAR86
Yj clutch problems
Ok so I have a 95 yj 4.0, the other day I was
Driving and noticed the clutch was acting different, I noticed because I stalled , but what I experienced or seams like what is going on is when I hold the pedal down for a long periods of time( such as reversing out a parking space) when I put it back in 1st it seams different. I guess the beat way I can diacribe it is, most the time the clutch disengages about a inch or two from the top of the pedal and with what I have been experiencing web holding the clutch down it seams to engage at the bottom of the pedal.. Witch is not normal. I had a clutch replaced about 3000 miles ago and have not had a problem untill the other day. If you have other questions I will be happy to try and answer them for you. Thanx in advance!
FUBAR86 is offline
post #2 of 3 Old 06-01-2013, 12:49 PM
Mark05059
check the fluid level in your clutch master.
1998 ZJ 5.2 Auto
1989 Wrangler Black Bone Stock 2.5l 5spd
/l , [____],
|---L--[]lllllll[]-
()_) ()_)==O=)_)
Mark05059 is offline
post #3 of 3 Old 06-01-2013, 01:10 PM Thread Starter
FUBAR86
Fluid was full. I already suspected the master cylinder was going bad because of some other stuff I had read. So I replaced it this morning and seams to have fixed the problem. Thank you for the reply..
FUBAR86 is offline
clutch , YJ
